Topic "using remote custom command in script"
endo5
I've got thousands of files to upload using a script, and to speed things up a bit, I'd like to zip locally and transfer the file (which I know how to do), then unzip the file remotely once it has been transferred. Using the GUI I can unzip the file by using a custom command, but I've not found any documentation indicating how to execute a custom command with a script.
Would appreciate any pointers.
thanks.
endo
You can use call command.
endo5
Great, thanks for your help.
