Topic "Timeout when synchronize command is run"
BenJ
I'm having a problem where every time I run the synchronize command it times out and the transfer fails. The script I run is:
option batch on
option transfer binary
open ftp://username:pass@12.34.56.78
synchronize remote ..\..\site_backups\site_backup-2009-10-13-235902 /httpdocs
close
This always produces the following output in the windows command prompt:
batch        on
confirm      off
transfer     binary
Connecting to 12.34.56.78 ...
Connected with 12.34.56.78. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] username@12.34.56.78
Comparing '..\..\site_backups\site_backup-2009-10-13-235902' with '/httpdocs'...
Lost connection.
Timeout detected.
Opening ASCII mode data connection for /bin/ls.
Error listing directory '/httpdocs/study/courses/undergraduateCourses/SchoolOfHe
althScienceAndSocialCare/CourseInfoSheets'.
Session username@12.34.56.78' closed.
No session.
No session.
This was working fine for the past few months, so I'm not sure why this has now stopped working and is timing out. Could this be due to a local or remote network issue, or some other issue with the FTP software at the remote host?
I'd be very grateful for any pointers anyone has.
Many thanks
BenJ
Thanks - I'll email the log to you.
Ive tried upgrading to version 4.2.3, but the same issue still occurs.
Timeout seems to usually occur on the same directory - I've tried navigating to the directory via the WinSCP GUI and it can list the contents OK.
BenJ
Thanks for the pointer - I've tried increasing the timeout via the /timeout switch, but it seems to have no effect, even when I give it a large value such as 1000 seconds.
Does the timeout then occurs after the 1000 seconds?
BenJ
No, it happens quicker than that - within about a minute.
So can you post a log file?
