Topic "Error: (ESshFatal) Connection failed"
Norky
Hello.
I try to connect WinSCP to my IPBOX 350prime. I do get connected, but then the connection fail. When I use PuTTYtel I do not have anny problems with the connection. The IPBOX and the PC is both connected to my home network.
The firewall is turned off.
The log is:
2009-10-15 14:25:30.766 --------------------------------------------------------------------------
. 2009-10-15 14:25:30.766 WinSCP Version 4.2.3 (Build 494) (OS 6.0.6002 Service Pack 2)
. 2009-10-15 14:25:30.766 Login time: 15. oktober 2009 14:25:30
. 2009-10-15 14:25:30.766 --------------------------------------------------------------------------
. 2009-10-15 14:25:30.767 Session name: 10.0.0.30
. 2009-10-15 14:25:30.767 Host name: 10.0.0.30 (Port: 23)
. 2009-10-15 14:25:30.767 User name: root (Password: Yes, Key file: No)
. 2009-10-15 14:25:30.767 Tunnel: No
. 2009-10-15 14:25:30.767 Transfer Protocol: FTP
. 2009-10-15 14:25:30.767 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2009-10-15 14:25:30.767 Proxy: none
. 2009-10-15 14:25:30.767 FTP: FTPS: None; Passive: No [Force IP: No]
. 2009-10-15 14:25:30.767 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-10-15 14:25:30.767 Cache directory changes: Yes, Permanent: Yes
. 2009-10-15 14:25:30.767 DST mode: 1
. 2009-10-15 14:25:30.767 --------------------------------------------------------------------------
. 2009-10-15 14:25:30.838 Connecting to 10.0.0.30:23 ...
. 2009-10-15 14:25:30.849 Connected with 10.0.0.30:23. Waiting for welcome message...
< 2009-10-15 14:25:30.994 !
< 2009-10-15 14:25:30.994 *********************************************************
< 2009-10-15 14:25:30.994 ** **
< 2009-10-15 14:25:30.994 *** Welcome on your dreambox! - Kernel 2.6.17-cubecafe-prime ***
< 2009-10-15 14:25:30.995 ** **
< 2009-10-15 14:25:30.995 *** Nabilosat Image DARKSTAR II 0.1 ***
< 2009-10-15 14:25:30.995 *** Compiled 18 Aug 2008 ***
< 2009-10-15 14:25:30.995 *********************************************************
< 2009-10-15 14:25:30.995 Thursday, 15 October 2009 Time: 14:26:40
> 2009-10-15 14:25:30.995 USER root
. 2009-10-15 14:25:30.995 Connection failed.
* 2009-10-15 14:25:31.006 (ESshFatal) Connection failed.
* 2009-10-15 14:25:31.006 Connection failed.
* 2009-10-15 14:25:31.006 !
* 2009-10-15 14:25:31.006 *********************************************************
* 2009-10-15 14:25:31.006 ** **
* 2009-10-15 14:25:31.006 *** Welcome on your dreambox! - Kernel 2.6.17-cubecafe-prime ***
* 2009-10-15 14:25:31.006 *** Nabilosat Image DARKSTAR II 0.1 ***
* 2009-10-15 14:25:31.007 ** **
* 2009-10-15 14:25:31.007 *** Compiled 18 Aug 2008 ***
* 2009-10-15 14:25:31.007 *********************************************************
* 2009-10-15 14:25:31.007 Thursday, 15 October 2009 Time: 14:26:40
. 2009-10-15 14:25:36.191 Connecting to 10.0.0.30:23 ...
. 2009-10-15 14:25:36.203 Connected with 10.0.0.30:23. Waiting for welcome message...
< 2009-10-15 14:25:36.335 !
Using PuTTYtel I get this connection
Thursday, 15 October 2009 Time: 15:02:01
dreambox login: root
Password:
BusyBox v1.2.1 (2006.10.11-21:54+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
Best regards
Petter
Norky
Sorry,
I know what to do.
I had the wrong port. The port I used was not a FTP server.
It works now.
Best regards
Petter
