Topic "A call to an OS function failed error"
We have one person that cannot open a file from a remote site. She gets an error message that says it can't create the file in C:\Docs & Settings\user name\...It says, a call to an OS function failed. It is only this one particular document. She can open all other documents. I am able to open the same file from a different computer without any issues.
WinSCP version: 4.1.9 (Build 416)
OS: Windows XP SP2
Transfer Protocol: SFTP
GUI Interface: Commander
I will e-mail you a screen shot of the error as well as the log file.
Thanks for your post. This issue has been added to tracker.
I have also this problem with WinSCP. The 255 limit is not however a limit due to NTFS.
Other software manage the situation and allow writing files with a filename (including path) longer. Example : teracopy with an option in .ini file :
0: Allow to create extra long paths (> 255 characters).
If you could consider again this issue ...
Best regards,
Frdric Bernard
n Winscp Go to Options-->Preferences-->Endurance-->Enable transfer resume--> All files Click on OK and then refresh Winscp. The error should not come.
