Topic "Explicit Path to Winscp.com Causes Host Does not Exist Error"
Homer
First some environment info:
WinSCP Version: 4.1.9
OS: MS Server 2003 R2 - Enterprise x64 Edition SP2
Now the issue:
When I run winscp without explicitly naming the path it works as designed:
C:\Program Files (x86)\WinSCP>WinSCP.com myuser:mypass@myserver.mydomain.com /command  "option confirm off" "get myfile.txt F:\Staging\oracle_xfer\myfile" "exit"
Searching for host...
Connecting to host...
Authenticating...
Using username "myuser".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] myuser@myserver.mydomain.com
confirm      off
myfile |          1 KiB |    0.0 KiB/s | ascii  | 100%
However if I run it with the path explicitly listed it fails with a Host Does Not Exist Error:
C:\Program Files (x86)\WinSCP>C:\"Program Files (x86)"\WinSCP\WinSCP.com myuser:mypass@myserver.mydomain.com /command "option confirm off" "get myfile.txt F:\Staging\oracle_xfer\myfile" "exit"
Host does not exist
winscp> exit
Any thoughts?
Regards,
Homer.
Marcio H.
Hi Homer,
I think that problem occurs because your path: "..... (x86)".
I suggested you try move folder WINSCP to another folder and try again.
Regards,
Marcio H
