Topic "windows 7 compatibile version"
cniry
Have you plan to create version for windows 7?
Actual version freezing while copying files
WinSCP works on Windows 7.
Dear prikryl
I have a simlar problem (also reported today under "Support and Bug Reports"):
When trying to install WinSCP 4.2.4 beta OR WinSCP 4.1.9 on Windows 7 Home Premium edition you will immediately get an access violation error, before starting copying any files. The pop-up error message box is:
"Access violation at adress 00409942, Write of adress 00400000"
Best regard
Christian Dalsgaard
Anonymous wrote:
Dear prikryl
Crosspost
