Topic "I CANT LOGIN IN I NEED HELP BAD!!! PLEASE HELP!!!!"
camoflage
When ever i login i always get the error "Server Unexpectedly closed network connection" ive went to the help button and tryed to fix the problem. the problem is still there so i went to my IP and did port forwarding. no help.
PLEASE I NEED HELP THIS IS FOR A SCHOOL RELATED AND NEED HELP BADLY!!!!
