Topic "Custom command patterns insert local filesystem slash"
Using 4.2.3, I'm trying to synchronize a local directory (Windows XP) onto a remote one (RHEL).
In Synchronize options, I checked "Preview changes", and from the resulting list, I selected an entry, then Custom Commands -> File Compare (which I defined as w "!" "!^!", and which works in the regular file panels). The problem is that when called from the Synchronization checklist, there seems to be a Windows backslash inserted in front of the remote file:
Cannot open remote file '/homes/dandv/bonita/workflow-head/bugflow/bonita-runtime/\License.txt'.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 3
Thanks for your post. This bug has been added to tracker.
