Topic "Auto compress files"
ks
Hi.
Is it possible to set up autopacking downloaded files? For ex., before downloading, run
tar -cvj -f tempfilename.tar.bz !&
for the selected files, then do download the tar.bz, then transparently unpack it (or maybe leave as is) with a chosen (local) program.
Both remote and local commands should be configured.
I see it as an extended custom command that applies both remotely and locally.
Point is I do the thing too often manually (pack - download - unpack).
Thanks for your post. This request has been added to tracker.
ks
That's great! Wink
ks
Ok, I read the comments, I tried enabling SSH compression but that just didn't change anything - the number of transferred bytes and the speed are the same. Perhaps compression should be enabled at the server.
As for scripting, I wish I could use it but as far as I understand this is only possible with the console version? I cannot run some script commands in an open WinSCP window, can I?
No you cannot, though you can setup a custom command that executes the script for selected files. I'll try to write a guide for that.
ks
Ok, thanks.
I have realised that you cannot do this with custom commands yet.
I have filed an improvement to allow this. Also I have written guide for accomplishing this using scripting.
ks
Quote:
gzip -d archive.tar.gz
tar -xf archive.tar
You can also extract the files with unrar or unzip.
