Having a bizarre problem with passwords
Vernon
US
I have created encryption keys without any passphrase or password, for a particular SFTP site, and if I use WINSCP windows interface to connect to the site, then the program starts, uses the private key to authenticate, and never asks me for a password/phrase.
However,
When I try to run the SAME ftp connection (as it is the only one so far) from a script, it stops in the DOS window and asks me for a password. I've uninstalled / reinstalled the product, deleted the site information before the reinstall, cleaned out all entries I could find for the WINSCP before the uninstall ended, and then recached the job when I recreated, and I'm still getting the same result...
What gives? Anybody else having the same issue???
Vernon
Re: Having a bizarre problem with passwords
Please post a full log file showing the problem. Both from GUI and script.
