WinSCP 4.2.4 Beta BUG with Permissions
dude
I was just trying out the new beta and noticed that the permissions were not being set properly on my server. What I discovered was that the permissions were set as defined in Preferences->Transfer->Upload options even if the "Set permissions" box is UNchecked. I have another machine running WinSCP 4.0.5 and have confirmed that this problem does not occur with that. Seems like a bug to me. In case it makes a difference, my server is running Centos 5. Thanks...
P.S. Protocol is SCP and Windows version is XP Pro SP3
Re: WinSCP 4.2.4 Beta BUG with Permissions
