Topic "Server sent command exit status 1"
TomC
I continue to have a problem with connecting with WinSCP.
Server: Windows 2003 Server
Accounts: Domain Users
Remote System Environment: Cygwin
All accounts are domain accounts
. Started a shell/command
. Server sent command exit status 1
I can connect SSH to the remote server.
I have seen this mentioned on the forum, but the problem doesn't seem to be the same.
. Server version: SSH-1.99-OpenSSH_3.7.1p2
. We claim version: SSH-2.0-WinSCP-release-3.4.2.197
. Host key fingerprint is:
. ssh-rsa 1024 06:40:4d:db:84:d8:58:b7:12:02:53:ed:b6:8f:eb:f6
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
! Using username "tcanter".
. Keyboard-interactive authentication refused
. Session password prompt (tcanter@66.180.127.142's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
! setgid: Invalid argument
. All channels closed. Disconnecting
* (ESshFatal) Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
* Connection has been unexpectedly closed. Server sent command exit status 1.
Look at topic "WinSCP fails to connect my OpenSSH_3.5p 1(on w2k server w/ sp3). It may help you.
tcanter
Thanks, I did look at that.
I have found an interim solution, but I don't understand why it works:
mkpasswd -d -o 0 > /etc/passwd
mkpasswd -l >> /etc/passwd
It appears that the OpenSSH is returning an error from a domain account UID that is a large number.
Tom
prikryl wrote:
