Topic "WinSCP and AS400"
User1
I just installed WinSCP 4.2.1 on a new pc. On the old pc I was able to configure it to enable me to FTP to/from an AS400. I do not have access to the configuration and was hoping someone could help me out with them? Thanks!
You probably have to specify some post login FTP command to switch to IFS.
Hilger
seems like a new feature of some sort is making problems again. AS400 does not support ls -a, which is exactly what WinSCP is doing all the time. Could you make the list command configurable?
just to be sure...this is what a 'raw' ls looks like:
QSYS 159744 08-02-07 10:36:37 *DIR QOpenSys/
QDOC 8192 01-01-70 01:00:00 *FLR QDLS/
QSYS 16650240 09-02-10 11:12:08 *LIB QSYS.LIB/
QDFTOWN 4096 01-01-70 01:00:00 *DDIR QOPT/
QSYS 2272 09-02-10 06:18:47 *DDIR QFileSvr.400/
QDFTOWN 1200 09-02-10 06:18:47 *DDIR QNTC/
QSYS 40960 16-11-09 13:51:10 *DIR dev/
QSYS 8192 17-11-09 17:45:26 *DIR home/
QSYS 81920 09-02-10 15:46:10 *DIR tmp/
QSYS 8192 16-11-09 14:16:45 *DIR etc/
QSYS 8192 16-11-09 14:21:32 *DIR usr/
QSYS 12288 30-12-09 13:07:02 *DIR QIBM/
Hilgert
I checked again and is configurable except for FTP(S) which is what I am using.
For FTP see Support for listing of hidden files.
Thanks! That was set to On. Problem solved now.
