Topic "Automation Script Failing"
ansonee
I have a very basic script I wrote to SFTP a file to a client. For some reason it refuses to work:
winscp419 /command "option batch on" "option confirm off" "open H1N1 - MD" "put E:\jobs\Maryland\*.csv /*.*" "exit"
Am I missing something? I have double checked the directory names on the source and they are correct and the file does exist. Even when running directly from the command line, the script fails.
It is probably the space in the stored session name. You need to enclose it in quotes. You cannot do this with 4.1.9 from command-line, you need to use beta. Or rename the stored session to avoid the spaces.
