Topic "Problem reading large directory"
I am using version 4.0.7 under WinXP, but I get the same problem with the latest beta version. I get the same problem on 2 PCs.
I am connecting with FTP to my Buffalo LinkStation located at home.
Everything works fine until I try to read a large directory (400-500 files) and then I always get a
"Could not retrieve directory listing Transfer aborted. Link to file server lost."
I cut the directory size in half and it works.
Is there a limit on the size of the directory ?
Rand Batchelder
Please post a full log file showing the problem. Use the latest version if possible.
