Topic "network error: connection refused, but only on certain connections"
namwenkram@...
I connect to two servers, mainly, using ssh and scp.One of them works just fine with WinSCP, but the other one keeps giving me a "Network error: connection refused". I can connect to this same server just fine with the version of ssh that comes with Cygwin (ssh -version returns the following: OpenSSH_3.1p1, SSH protocols 1.5/2.0, OpenSSL 0x0090603f)). I am running Windows 2000, connecting through a wireless firewall to a DSL connection. Why might this be happening?
To sum up the problem again:
Server 1 (Solaris, SSH Version 1.2.26 [sparc-sun-solaris2.6], protocol version 1.5):
* connect via Cygwin/OpenSSH: OK
* connect via WinSCP: OK
Server 2: (Linux, OpenSSH_3.1p1, SSH protocols 1.5/2.0, OpenSSL 0x0090602f)
* connect via WinSCP: DOESN'T WORK!
Please advise. Thanks.
--makr
Please try to connect with Putty SSH client. Let me know the results.
The Putty SSH client (v. 0.53b) works, but pscp and psftp do NOT work from the command line.
namwenkram@...
--mark
PS--sorry for the double post. The first one was posted as "Guest" and that seemed confusing. Trying to keep it consistent.
Why they do not work? Any error message?
namwenkram@...
This is the error message:
Fatal: ssh_init: Network error: Connection refused
Again, the cygwin versions of scp and sftp work just fine. The putty versions and WinSCP do not work.
--mark
OK, can you report this to authors of Putty? WinSCP uses Putty code for SSH, I do not understand it well enough to fix it by myself.
