Topic "message tones gone. help plz"
BIdoubleG
hi, i am using a 3g iphone with firmware 3.1.2 on a vista pc with winscp 4.1.9 i was trying to change message tones an didn't convert to .aiff first, which left me with no tones. i have converted to .aiff then renamed to .caf as i have read to do. but when i use winscp to transfer now the folder UISounds has gone and no message tones at all. i have tried creating new folder in roots/library/audio and transferred into but the tones still don't work in iphone plz help thx
BIdoubleG
found an answer that worked in the end, needed winterboard and used the internals of that.
rueblileu
can you please let me know, how you did it? I am trying to get acess to WinSCP - iphone with FW 3.1.2... but I have no username and password... root / alpine does not work / File Protocol SFTP... There is no login possible - are there some other usernames / passwords I have to use???
Thanks for a quick reply!
Regards,
Patty
