Topic "Resume problem WinSCP and GlobalSCAPE"
mike67379
I have a old GlobalSCAPE Secure FTP Server V3.0.0 and used it with WSFTP in the past. Everything works in this combination. Some days ago I make a test with WinSCP 4.2.3 beta and GlobalSCAPE server. If some data was transfered from the client to the server and the IP change the upload will be resumed. This sounds good but the file have some errors and is not openable.
WSFTP have no problem with the resuming! What do I make wrong?
Michael
mike67379
without IP renew:
. 2009-12-03 22:03:57.359 --------------------------------------------------------------------------
. 2009-12-03 22:03:57.359 WinSCP Version 4.2.4 (Build 610) (OS 5.2.3790 Service Pack 2)
. 2009-12-03 22:03:57.359 Login time: Donnerstag, 03. Dezember 2009 22:03:57
. 2009-12-03 22:03:57.359 Session name: 217.175.205.55
. 2009-12-03 22:03:57.359 Host name: 192.168.1.1 (Port: 22)
. 2009-12-03 22:03:57.359 User name: xxx (Password: Yes, Key file: No)
. 2009-12-03 22:03:57.359 Tunnel: No
. 2009-12-03 22:03:57.359 Transfer Protocol: SFTP (SCP)
. 2009-12-03 22:03:57.359 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-12-03 22:03:57.359 Proxy: none
. 2009-12-03 22:03:57.359 SSH protocol version: 2; Compression: No
. 2009-12-03 22:03:57.359 Bypass authentication: No
. 2009-12-03 22:03:57.359 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-12-03 22:03:57.359 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-12-03 22:03:57.359 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-12-03 22:03:57.359 SFTP Bugs: -,-
. 2009-12-03 22:03:57.359 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-12-03 22:03:57.359 Shell: default, EOL: 0
. 2009-12-03 22:03:57.359 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-12-03 22:03:57.359 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-12-03 22:03:57.359 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-12-03 22:03:57.359 Cache directory changes: Yes, Permanent: Yes
. 2009-12-03 22:03:57.359 DST mode: 1
. 2009-12-03 22:03:57.359 Looking up host "192.168.1.1"
. 2009-12-03 22:03:57.359 Connecting to 192.168.1.1 port 22
. 2009-12-03 22:03:57.375 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2009-12-03 22:03:57.375 We believe remote version ignores SSH-2 maximum packet size
. 2009-12-03 22:03:57.375 Using SSH protocol version 2
. 2009-12-03 22:03:57.375 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2009-12-03 22:03:57.375 Using Diffie-Hellman with standard group "group1"
. 2009-12-03 22:03:57.375 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-12-03 22:03:57.593 Host key fingerprint is:
. 2009-12-03 22:03:57.593 ssh-dss 1024 33:ca:02:18:71:36:7f:be:1c:d6:8c:04:6b:ab:b7:94
. 2009-12-03 22:03:57.593 Initialised Blowfish-128 CBC client->server encryption
. 2009-12-03 22:03:57.593 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-12-03 22:03:57.593 Initialised Blowfish-128 CBC server->client encryption
. 2009-12-03 22:03:57.593 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-12-03 22:03:57.781 Using username "xxx".
. 2009-12-03 22:03:57.781 Prompt (6, SSH password, , &Password: )
. 2009-12-03 22:03:57.781 Using stored password.
. 2009-12-03 22:03:57.781 Sent password
. 2009-12-03 22:03:57.781 Access granted
. 2009-12-03 22:03:57.781 Opened channel for session
. 2009-12-03 22:03:58.000 Started a shell/command
. 2009-12-03 22:03:58.000 --------------------------------------------------------------------------
. 2009-12-03 22:03:58.000 Using SFTP protocol.
. 2009-12-03 22:03:58.000 Doing startup conversation with host.
> 2009-12-03 22:03:58.000 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-12-03 22:03:58.000 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-12-03 22:03:58.000 SFTP version 3 negotiated.
. 2009-12-03 22:03:58.000 We believe the server has signed timestamps bug
. 2009-12-03 22:03:58.000 We will use UTF-8 strings for status messages only
. 2009-12-03 22:03:58.000 Getting current directory name.
. 2009-12-03 22:03:58.000 Getting real path for '.'
> 2009-12-03 22:03:58.000 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-12-03 22:03:58.000 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2009-12-03 22:03:58.000 Real path is '/'
. 2009-12-03 22:03:58.000 Listing directory "/".
> 2009-12-03 22:03:58.000 Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
< 2009-12-03 22:03:58.000 Type: SSH_FXP_HANDLE, Size: 10, Number: 267
> 2009-12-03 22:03:58.000 Type: SSH_FXP_READDIR, Size: 10, Number: 524
< 2009-12-03 22:03:58.000 Type: SSH_FXP_STATUS, Size: 22, Number: 524
< 2009-12-03 22:03:58.000 Status code: 1
. 2009-12-03 22:03:58.000 Listing file "/..".
> 2009-12-03 22:03:58.000 Type: SSH_FXP_LSTAT, Size: 12, Number: 775
< 2009-12-03 22:03:58.000 Type: SSH_FXP_ATTRS, Size: 21, Number: 775
> 2009-12-03 22:03:58.000 Type: SSH_FXP_CLOSE, Size: 10, Number: 1028
. 2009-12-03 22:03:58.000 Startup conversation with host finished.
. 2009-12-03 22:04:18.343 Copying 1 files/directories to remote directory "/"
. 2009-12-03 22:04:18.343 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: Yes; Mask: *.*
. 2009-12-03 22:04:18.343 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-12-03 22:04:18.343 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-12-03 22:04:18.343 File: "C:\Download\Test.pdf"
. 2009-12-03 22:04:18.343 Copying "C:\Download\Test.pdf" to remote directory started.
. 2009-12-03 22:04:18.343 Binary transfer mode selected.
. 2009-12-03 22:04:18.343 Checking existence of file.
> 2009-12-03 22:04:18.343 Type: SSH_FXP_LSTAT, Size: 18, Number: 1287
< 2009-12-03 22:04:18.343 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
. 2009-12-03 22:04:18.343 Discarding reserved response
< 2009-12-03 22:04:18.343 Type: SSH_FXP_STATUS, Size: 33, Number: 1287
< 2009-12-03 22:04:18.343 Status code: 2
. 2009-12-03 22:04:18.343 Checking existence of partially transfered file.
> 2009-12-03 22:04:18.343 Type: SSH_FXP_LSTAT, Size: 27, Number: 1543
< 2009-12-03 22:04:18.343 Type: SSH_FXP_STATUS, Size: 33, Number: 1543
. 2009-12-03 22:04:18.343 Opening remote file.
> 2009-12-03 22:04:18.343 Type: SSH_FXP_OPEN, Size: 43, Number: 1795
< 2009-12-03 22:04:18.343 Type: SSH_FXP_HANDLE, Size: 10, Number: 1795
> 2009-12-03 22:04:18.343 Type: SSH_FXP_WRITE, Size: 4118, Number: 2310
. 2009-12-03 22:04:42.390 10118 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-12-03 22:04:42.390 Type: SSH_FXP_CLOSE, Size: 10, Number: 1298692
< 2009-12-03 22:04:42.390 Type: SSH_FXP_STATUS, Size: 21, Number: 1296390
< 2009-12-03 22:04:42.406 Type: SSH_FXP_STATUS, Size: 21, Number: 1296646
< 2009-12-03 22:04:42.406 Type: SSH_FXP_STATUS, Size: 21, Number: 1296902
< 2009-12-03 22:04:42.406 Type: SSH_FXP_STATUS, Size: 21, Number: 1297158
< 2009-12-03 22:04:42.406 Type: SSH_FXP_STATUS, Size: 21, Number: 1297414
< 2009-12-03 22:04:42.406 Type: SSH_FXP_STATUS, Size: 21, Number: 1297670
< 2009-12-03 22:04:42.406 Type: SSH_FXP_STATUS, Size: 21, Number: 1297926
< 2009-12-03 22:04:42.437 Type: SSH_FXP_STATUS, Size: 21, Number: 1298182
< 2009-12-03 22:04:42.437 Type: SSH_FXP_STATUS, Size: 21, Number: 1298438
< 2009-12-03 22:04:42.437 Type: SSH_FXP_STATUS, Size: 21, Number: 1298692
< 2009-12-03 22:04:42.437 Status code: 0
> 2009-12-03 22:04:42.437 Type: SSH_FXP_RENAME, Size: 40, Number: 1298962
< 2009-12-03 22:04:42.453 Type: SSH_FXP_STATUS, Size: 21, Number: 1298962
< 2009-12-03 22:04:42.453 Status code: 0
> 2009-12-03 22:04:42.453 Type: SSH_FXP_SETSTAT, Size: 30, Number: 2057
< 2009-12-03 22:04:42.453 Type: SSH_FXP_STATUS, Size: 21, Number: 2057
. 2009-12-03 22:04:42.453 Listing directory "/".
> 2009-12-03 22:04:42.453 Type: SSH_FXP_OPENDIR, Size: 10, Number: 1299211
< 2009-12-03 22:04:42.453 Type: SSH_FXP_HANDLE, Size: 10, Number: 1299211
> 2009-12-03 22:04:42.453 Type: SSH_FXP_READDIR, Size: 10, Number: 1299468
< 2009-12-03 22:04:42.453 Type: SSH_FXP_NAME, Size: 112, Number: 1299468
> 2009-12-03 22:04:42.453 Type: SSH_FXP_READDIR, Size: 10, Number: 1299724
< 2009-12-03 22:04:42.453 Type: SSH_FXP_STATUS, Size: 22, Number: 1299724
< 2009-12-03 22:04:42.453 Status code: 1
> 2009-12-03 22:04:42.453 Type: SSH_FXP_CLOSE, Size: 10, Number: 1299972
. 2009-12-03 22:05:18.875 Closing connection.
. 2009-12-03 22:05:18.875 Sending special code: 12
. 2009-12-03 22:05:18.890 Sent EOF message
mike67379
with IP renew:
. 2009-12-03 22:17:15.343 --------------------------------------------------------------------------
. 2009-12-03 22:17:15.343 WinSCP Version 4.2.4 (Build 610) (OS 5.2.3790 Service Pack 2)
. 2009-12-03 22:17:15.343 Login time: Donnerstag, 03. Dezember 2009 22:17:15
. 2009-12-03 22:17:15.343 Session name: 217.175.205.55
. 2009-12-03 22:17:15.343 Host name: 192.168.1.1 (Port: 22)
. 2009-12-03 22:17:15.343 User name: xxx (Password: Yes, Key file: No)
. 2009-12-03 22:17:15.343 Tunnel: No
. 2009-12-03 22:17:15.343 Transfer Protocol: SFTP (SCP)
. 2009-12-03 22:17:15.343 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-12-03 22:17:15.343 Proxy: none
. 2009-12-03 22:17:15.343 SSH protocol version: 2; Compression: No
. 2009-12-03 22:17:15.343 Bypass authentication: No
. 2009-12-03 22:17:15.343 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-12-03 22:17:15.343 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-12-03 22:17:15.343 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-12-03 22:17:15.343 SFTP Bugs: -,-
. 2009-12-03 22:17:15.343 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-12-03 22:17:15.343 Shell: default, EOL: 0
. 2009-12-03 22:17:15.343 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-12-03 22:17:15.343 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-12-03 22:17:15.343 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-12-03 22:17:15.343 Cache directory changes: Yes, Permanent: Yes
. 2009-12-03 22:17:15.343 DST mode: 1
. 2009-12-03 22:17:15.343 Looking up host "192.168.1.1"
. 2009-12-03 22:17:15.343 Connecting to 192.168.1.1 port 22
. 2009-12-03 22:17:15.359 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2009-12-03 22:17:15.359 We believe remote version ignores SSH-2 maximum packet size
. 2009-12-03 22:17:15.359 Using SSH protocol version 2
. 2009-12-03 22:17:15.359 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2009-12-03 22:17:15.359 Using Diffie-Hellman with standard group "group1"
. 2009-12-03 22:17:15.359 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-12-03 22:17:15.531 Host key fingerprint is:
. 2009-12-03 22:17:15.531 ssh-dss 1024 33:ca:02:18:71:36:7f:be:1c:d6:8c:04:6b:ab:b7:94
. 2009-12-03 22:17:15.531 Initialised Blowfish-128 CBC client->server encryption
. 2009-12-03 22:17:15.531 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-12-03 22:17:15.531 Initialised Blowfish-128 CBC server->client encryption
. 2009-12-03 22:17:15.531 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-12-03 22:17:15.703 Using username "xxx".
. 2009-12-03 22:17:15.703 Prompt (6, SSH password, , &Password: )
. 2009-12-03 22:17:15.703 Using stored password.
. 2009-12-03 22:17:15.703 Sent password
. 2009-12-03 22:17:15.703 Access granted
. 2009-12-03 22:17:15.703 Opened channel for session
. 2009-12-03 22:17:15.921 Started a shell/command
. 2009-12-03 22:17:15.921 --------------------------------------------------------------------------
. 2009-12-03 22:17:15.921 Using SFTP protocol.
. 2009-12-03 22:17:15.921 Doing startup conversation with host.
> 2009-12-03 22:17:15.921 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-12-03 22:17:15.921 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-12-03 22:17:15.921 SFTP version 3 negotiated.
. 2009-12-03 22:17:15.921 We believe the server has signed timestamps bug
. 2009-12-03 22:17:15.921 We will use UTF-8 strings for status messages only
. 2009-12-03 22:17:15.921 Getting current directory name.
. 2009-12-03 22:17:15.921 Getting real path for '.'
> 2009-12-03 22:17:15.921 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-12-03 22:17:15.921 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2009-12-03 22:17:15.921 Real path is '/'
. 2009-12-03 22:17:15.921 Listing directory "/".
> 2009-12-03 22:17:15.921 Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
< 2009-12-03 22:17:15.921 Type: SSH_FXP_HANDLE, Size: 10, Number: 267
> 2009-12-03 22:17:15.921 Type: SSH_FXP_READDIR, Size: 10, Number: 524
< 2009-12-03 22:17:15.921 Type: SSH_FXP_STATUS, Size: 22, Number: 524
< 2009-12-03 22:17:15.921 Status code: 1
. 2009-12-03 22:17:15.921 Listing file "/..".
> 2009-12-03 22:17:15.921 Type: SSH_FXP_LSTAT, Size: 12, Number: 775
< 2009-12-03 22:17:15.921 Type: SSH_FXP_ATTRS, Size: 21, Number: 775
> 2009-12-03 22:17:15.921 Type: SSH_FXP_CLOSE, Size: 10, Number: 1028
. 2009-12-03 22:17:15.921 Startup conversation with host finished.
. 2009-12-03 22:17:38.046 Copying 1 files/directories to remote directory "/"
. 2009-12-03 22:17:38.046 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: Yes; Mask: *.*
. 2009-12-03 22:17:38.046 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-12-03 22:17:38.046 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-12-03 22:17:38.046 File: "C:\Download\Test.pdf"
. 2009-12-03 22:17:38.046 Copying "C:\Download\Test.pdf" to remote directory started.
. 2009-12-03 22:17:38.046 Binary transfer mode selected.
. 2009-12-03 22:17:38.046 Checking existence of file.
> 2009-12-03 22:17:38.046 Type: SSH_FXP_LSTAT, Size: 18, Number: 1287
< 2009-12-03 22:17:38.046 Type: SSH_FXP_STATUS, Size: 21, Number: 1028
. 2009-12-03 22:17:38.046 Discarding reserved response
< 2009-12-03 22:17:38.046 Type: SSH_FXP_STATUS, Size: 33, Number: 1287
< 2009-12-03 22:17:38.046 Status code: 2
. 2009-12-03 22:17:38.046 Checking existence of partially transfered file.
> 2009-12-03 22:17:38.046 Type: SSH_FXP_LSTAT, Size: 27, Number: 1543
< 2009-12-03 22:17:38.046 Type: SSH_FXP_STATUS, Size: 33, Number: 1543
. 2009-12-03 22:17:38.046 Opening remote file.
> 2009-12-03 22:17:38.046 Type: SSH_FXP_OPEN, Size: 43, Number: 1795
< 2009-12-03 22:17:38.046 Type: SSH_FXP_HANDLE, Size: 10, Number: 1795
> 2009-12-03 22:17:38.046 Type: SSH_FXP_WRITE, Size: 4118, Number: 2310
. 2009-12-03 22:17:48.203 Network error: Software caused connection abort
. 2009-12-03 22:17:48.203 Connection was lost, asking what to do.
. 2009-12-03 22:17:48.203 Asking user:
. 2009-12-03 22:17:48.203 Network error: Software caused connection abort ()
. 2009-12-03 22:17:58.203 Looking up host "192.168.1.1"
. 2009-12-03 22:17:58.203 Connecting to 192.168.1.1 port 22
. 2009-12-03 22:17:58.218 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2009-12-03 22:17:58.218 We believe remote version ignores SSH-2 maximum packet size
. 2009-12-03 22:17:58.218 Using SSH protocol version 2
. 2009-12-03 22:17:58.218 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2009-12-03 22:17:58.218 Using Diffie-Hellman with standard group "group1"
. 2009-12-03 22:17:58.218 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-12-03 22:17:58.265 Host key fingerprint is:
. 2009-12-03 22:17:58.265 ssh-dss 1024 33:ca:02:18:71:36:7f:be:1c:d6:8c:04:6b:ab:b7:94
. 2009-12-03 22:17:58.265 Initialised Blowfish-128 CBC client->server encryption
. 2009-12-03 22:17:58.265 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-12-03 22:17:58.265 Initialised Blowfish-128 CBC server->client encryption
. 2009-12-03 22:17:58.265 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-12-03 22:17:58.468 Using username "xxx".
. 2009-12-03 22:17:58.468 Prompt (6, SSH password, , &Password: )
. 2009-12-03 22:17:58.468 Using stored password.
. 2009-12-03 22:17:58.468 Sent password
. 2009-12-03 22:17:58.484 Access granted
. 2009-12-03 22:17:58.484 Opened channel for session
. 2009-12-03 22:17:58.687 Started a shell/command
. 2009-12-03 22:17:58.687 Doing startup conversation with host.
. 2009-12-03 22:17:58.687 4253 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-12-03 22:17:58.687 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-12-03 22:17:58.687 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-12-03 22:17:58.687 SFTP version 3 negotiated.
. 2009-12-03 22:17:58.687 We believe the server has signed timestamps bug
. 2009-12-03 22:17:58.687 We will use UTF-8 strings for status messages only
. 2009-12-03 22:17:58.687 Changing directory to "/".
. 2009-12-03 22:17:58.687 Getting real path for '/'
> 2009-12-03 22:17:58.687 Type: SSH_FXP_REALPATH, Size: 10, Number: 547856
< 2009-12-03 22:17:58.703 Type: SSH_FXP_NAME, Size: 23, Number: 547856
. 2009-12-03 22:17:58.703 Real path is '/'
. 2009-12-03 22:17:58.703 Trying to open directory "/".
> 2009-12-03 22:17:58.703 Type: SSH_FXP_LSTAT, Size: 10, Number: 548103
< 2009-12-03 22:17:58.703 Type: SSH_FXP_ATTRS, Size: 21, Number: 548103
. 2009-12-03 22:17:58.703 Getting current directory name.
. 2009-12-03 22:17:58.703 Startup conversation with host finished.
. 2009-12-03 22:17:58.718 File: "C:\Download\Test.pdf"
. 2009-12-03 22:17:58.718 Copying "C:\Download\Test.pdf" to remote directory started.
. 2009-12-03 22:17:58.718 Binary transfer mode selected.
. 2009-12-03 22:17:58.718 Checking existence of file.
> 2009-12-03 22:17:58.718 Type: SSH_FXP_LSTAT, Size: 18, Number: 548359
< 2009-12-03 22:17:58.718 Type: SSH_FXP_STATUS, Size: 33, Number: 548359
< 2009-12-03 22:17:58.718 Status code: 2
. 2009-12-03 22:17:58.718 Checking existence of partially transfered file.
> 2009-12-03 22:17:58.718 Type: SSH_FXP_LSTAT, Size: 27, Number: 548615
< 2009-12-03 22:17:58.718 Type: SSH_FXP_ATTRS, Size: 29, Number: 548615
. 2009-12-03 22:17:58.718 Resuming file transfer.
. 2009-12-03 22:17:58.718 Opening remote file.
> 2009-12-03 22:17:58.718 Type: SSH_FXP_OPEN, Size: 35, Number: 548867
< 2009-12-03 22:17:58.718 Type: SSH_FXP_HANDLE, Size: 10, Number: 548867
> 2009-12-03 22:17:58.718 Type: SSH_FXP_WRITE, Size: 4118, Number: 549382
. 2009-12-03 22:18:13.109 5883 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-12-03 22:18:13.109 Type: SSH_FXP_CLOSE, Size: 10, Number: 1303556
< 2009-12-03 22:18:13.125 Type: SSH_FXP_STATUS, Size: 21, Number: 1301510
< 2009-12-03 22:18:13.125 Type: SSH_FXP_STATUS, Size: 21, Number: 1301766
< 2009-12-03 22:18:13.125 Type: SSH_FXP_STATUS, Size: 21, Number: 1302022
< 2009-12-03 22:18:13.125 Type: SSH_FXP_STATUS, Size: 21, Number: 1302278
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 1302534
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 1302790
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 1303046
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 1303302
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 1303556
< 2009-12-03 22:18:13.140 Status code: 0
> 2009-12-03 22:18:13.140 Type: SSH_FXP_RENAME, Size: 40, Number: 1303826
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 1303826
> 2009-12-03 22:18:13.140 Type: SSH_FXP_SETSTAT, Size: 30, Number: 549129
< 2009-12-03 22:18:13.140 Type: SSH_FXP_STATUS, Size: 21, Number: 549129
. 2009-12-03 22:18:13.140 Listing directory "/".
> 2009-12-03 22:18:13.140 Type: SSH_FXP_OPENDIR, Size: 10, Number: 1304075
< 2009-12-03 22:18:13.156 Type: SSH_FXP_HANDLE, Size: 10, Number: 1304075
> 2009-12-03 22:18:13.156 Type: SSH_FXP_READDIR, Size: 10, Number: 1304332
< 2009-12-03 22:18:13.156 Type: SSH_FXP_NAME, Size: 112, Number: 1304332
> 2009-12-03 22:18:13.156 Type: SSH_FXP_READDIR, Size: 10, Number: 1304588
< 2009-12-03 22:18:13.156 Type: SSH_FXP_STATUS, Size: 22, Number: 1304588
< 2009-12-03 22:18:13.156 Status code: 1
> 2009-12-03 22:18:13.156 Type: SSH_FXP_CLOSE, Size: 10, Number: 1304836
. 2009-12-03 22:18:17.984 Closing connection.
. 2009-12-03 22:18:17.984 Sending special code: 12
. 2009-12-03 22:18:17.984 Sent EOF message
