Topic "XML Log Not Appending in 4.24b"
Chad_C
I'm using a batch file to call WinSCP (with logging enabled. Each time the batch file is run, the XML log is written over. In other words, instead of the log getting appended with each new running of the batch file, it's completely over-written with new information.
Here is the batch file call:
winscp.exe /console /script=winscpscript.txt /log=winscplog.xml
Here are the contents of winscpscript:
option batch abort
open BofA
option transfer binary
put achfile
I would like to either maintain one log file or create log files based on the date if one log file is not possible.
Chad_C
The documentation does not show any configuration settings specific to using a scripted WinSCP session. I see that appending an XML log is not supported. How then can I specify logging, non-XML, using a scripted WinSCP session?
Thanks for the support.
I've posted the link, because it is explained there how to put a date into log file name. It works from the command line the same way as from GUI.
