Topic "Unable to log into alternate account on same server."
mrhope
I'm able to log into a main account on my server, however unable to connect with another account. The server is using TLS encryption on FTP.
I can log into "hope" account and get the below output, however the other account username: "name@domain.com" doesn't seem to be accepted. I've also tried connecting through the command prompt using: "open name40domain.com:password@domain.com" and still am unable to connect.
I verified it's not the account by trying FileZilla and it's capable of logging into both accounts with no issues.
Any help on deciphering this problem would be appreciated.
Can you post a log file both from Filezilla and WinSCP?
