Topic "Command line switch for "Force IP Address for passive mode""
zybroxz
Morning All,
I am able to connect to my FTPS server using WinSCP 4.2.4 using FTPS ExplictTLS, however when I send commands I get an Illegal port command message, this is because I am not specifying "Force IP Address for passive mode connections" in my script. Could anyone let me know the switch for "Force IP address for passive mode connections".
I am currently using the following OPEN command
open ftps://user:password@myserver:2121 -explicittls -passive -certificate="xx:xx:xx:xx:xx:xx:xx:"
Hope someone can help, I have a third party who needs to connect (and the deadline is rapidly approaching Sad )
Thanks in advance
zybroxz
Martin,
Thanks for directing me to the FAQ, I have had a look and need a bit of direction if possible.
If I create an INI file and set
FtpPasvMode=3
FtpForcePasvIp=1
FTPS=3
I am now wanting to open the connection from the command line using
How do I specify what INI file to use.
Thanks in advance
Z
zybroxz
I have found a solution to the problem.
I let the GUI generate a INI file with Passive FTPS and "Force IP Address for passive mode connections".
Then from the command line I call WinSCP like so;
> winscp /ini=PathToIniFile
Sorted !!
JimGriffith
Sorted !!
So did you end up saving a session then exporting the prefs to an ini then calling your session from the command line/script?
JimGriffith
Sorted !!
I was able to do this a different way. I went into the registry and added the DWORD values of FtpForcePasvIp and FtpPasvMode both with values of one to the
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Sessions\Default%20Settings\ key.
The only downside is that anything sent via the FTP protocol (encrypted or not) is affected and will now be sent in Passive mode. This does NOT affect transmissions with SFTP protocol.
Raghav
Sorted !!
Instead of Default%20Settings you could set it for a specific session.
