Topic "bookmark touble if folder contain = in name"
chfaure
I've some local folder that contain = or == in the path and it is very difficult to manage them as each time the path is cut as the first = char.
I use ini file to store all my connection on a usb drive.
As the library cut to the first = char you should change the way to store bookmark. i.e
0001=Path 0002=path ..... or at least encode the '=' intead of path=path
regards.
Thanks for your post. This bug has been added to tracker.
