Topic "Windows 7 taskbar support"
Pr3d
Is there a plan to support a Windows 7 taskbar features?
Im talking about the new right click menu on the taskbar icon, a history of a recent connections would be very useful.
I haven't seen Win7 yet. What's new about the right click menu?
Pr3d
You can use it like a history.
I was thinking to a history for recent connections, just like happen with remote desktop icon. Smile
mikaelmhansen
Actually a bit more could be added. The window shown could also include a section for any stored sessions. It would be really useful in the daily work with WinSCP.
Does the icon stand for running instance of WinSCP or is it an icon that starts WinSCP?
doug
I added support for windows 7 jumplist to winscp, currently it adds all saved sessions to jumplist so it looks like this
with pinned icon and like this with running program
I don't know if it is possible to use windows 7 sdk with borland builder so I am currently doing it through external dll
to make it work you first need to download my version from here, replace old winscp.exe in your install dir and make sure that jumplist.dll is in the same directory as winscp.exe
also you need to unpin previously pinned winscp (if you have it) and pin this new version
modified source is available here
doug wrote:
I added support for windows 7 jumplist to winscp...
Thanks for your contribution! I'll check it as soon as I upgrade to Windows 7.
This request has been added to tracker.
