Topic "Cannot open corresponding panel in opposite directory"
Bugsiee
hi.
i've been using winscp for a year now. never had a problem.
using latest version 425.
i am doing nothing different.
today, i get error "Cannot open corresponding panel in opposite directory"
winscp won't/can't open my remote directory.
it asks if i want to create the directory.
if i open the remote directory first, it DOES/CAN open the correcsponding LOCAL directory.
using latest wixxp. server = lamp vps. linux centos, fairly new server. everything was new a year ago.
Bugsie
I reinstalled v419 and the problem disappeared.
What are the paths you are having problems with?
mdmower
I now see that this is the same issue that I have been experiencing and about which I posted a thread. (Sorry for the repeat post, but I didn't see this thread when I searched for "synchronized")
Thanks for your post. This bug has been added to tracker.
Rad
Just to let you know that 426 fixed whatever was broke in 425.
Thanks.
Great piece of software.
PonchoV
New problem with latest v426. Minor prob. But you may wanna know.
Been using WinSCP over 1 year. Never had this prob before.
When I relaunch WinXP after Standby, I get error:
Assertion failed: random_active > = 0, file putty \SSHRAND.C, line 242
The program crashes/closes after I click the OK button, with another message that tells me:
Abnormal program termination (WinSCP.exe)
I simply restart WinSCP. (No problem.)
PonchoV
Actually, I don't think I was getting this error until AFTER the recent WXP update. Not positive, but I think WinSCP was working fine for a few days there. (No such errors.)
Thanks for your post. This bug is being tracked already.
PonchoV
v427 fixed the 'Assertion failed' problem.
Thank-you.
I use WinSCP nearly every day.
PonchoV
It appears the program now (re)connects to remote server *automatically* after you restart Windows from a standby condition. That is pretty cool.
