Topic "Need to check whether folder is already there or not!"
gopikrishnakomanduri
First of all Thanks for the good prog. It saved my day. My query is " is there anyway to check whether a folder is already presents or not using winscp in remote machine?"
To explain more ,
I need to transfer a file into a particular directory in remote unix machine. So First I need to check whether that folder is there or not in that particular path , if there , I need to transfer the file . If not , I need to create a new one.
I check for the commands available with winscp , but I am unable to find any as such.
Any suggestions ?
See this example.
Thanks man! I will check and let you know Smile btw , wish you a happy new year !
