Topic "Error establish Winscp connection from WinSSHD"
rajpalparyani
Hi All,
I have installed WinSSHD on my machine and am trying to establish a WinSCP Connection to the same machine. The username and password credentials are correct, but the connection just hangs and I ultimately get error message of incorrect BASH Shell "Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended)."
Any help would be highly appreciated
RAJ
Here's the text from the log file -:
. 2009-12-30 16:33:40.183 --------------------------------------------------------------------------
. 2009-12-30 16:33:40.183 WinSCP Version 4.1.9 (Build 416) (OS 6.1.7600)
. 2009-12-30 16:33:40.183 Login time: Wednesday, December 30, 2009 4:33:40 PM
. 2009-12-30 16:33:40.183 Session name: session
. 2009-12-30 16:33:40.183 Host name: 192.168.1.118 (Port: 22)
. 2009-12-30 16:33:40.184 User name: RajPC (Password: Yes, Key file: No)
. 2009-12-30 16:33:40.192 Tunnel: No
. 2009-12-30 16:33:40.192 Transfer Protocol: SCP
. 2009-12-30 16:33:40.192 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-12-30 16:33:40.192 Proxy: none
. 2009-12-30 16:33:40.192 SSH protocol version: 2; Compression: No
. 2009-12-30 16:33:40.192 Bypass authentication: No
. 2009-12-30 16:33:40.192 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-12-30 16:33:40.192 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-12-30 16:33:40.192 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-12-30 16:33:40.192 SFTP Bugs: -,-
. 2009-12-30 16:33:40.192 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-12-30 16:33:40.193 Shell: default, EOL: 0
. 2009-12-30 16:33:40.193 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-12-30 16:33:40.193 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-12-30 16:33:40.193 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-12-30 16:33:40.193 Cache directory changes: Yes, Permanent: Yes
. 2009-12-30 16:33:40.193 DST mode: 1
. 2009-12-30 16:33:40.193 --------------------------------------------------------------------------
. 2009-12-30 16:33:40.234 Looking up host "192.168.1.118"
. 2009-12-30 16:33:40.234 Connecting to 192.168.1.118 port 22
. 2009-12-30 16:33:40.238 Server version: SSH-2.0-1.04 FlowSsh: WinSSHD 5.12: free only for personal non-commercial use
. 2009-12-30 16:33:40.239 We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2009-12-30 16:33:40.239 SSPI: acquired credentials for: RajPC@RajPC-PC
. 2009-12-30 16:33:40.239 Cannot convert IP address to SPN: DNS is not trusted
. 2009-12-30 16:33:40.239 GSSKEX disabled:
. 2009-12-30 16:33:40.240 Using SSH protocol version 2
. 2009-12-30 16:33:40.240 Doing Diffie-Hellman group exchange
. 2009-12-30 16:33:40.240 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-12-30 16:33:40.421 Host key fingerprint is:
. 2009-12-30 16:33:40.539 ssh-dss 1024 ac:e9:bc:87:a5:e6:86:7d:b7:cb:07:8e:28:14:df:5a
. 2009-12-30 16:33:40.539 Initialised AES-256 SDCTR client->server encryption
. 2009-12-30 16:33:40.539 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-12-30 16:33:40.540 Initialised AES-256 SDCTR server->client encryption
. 2009-12-30 16:33:40.540 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-12-30 16:33:40.540 Using username "RajPC".
. 2009-12-30 16:33:40.544 Prompt (6, SSH password, , &Password: )
. 2009-12-30 16:33:40.544 Using stored password.
. 2009-12-30 16:33:40.551 Sent password
. 2009-12-30 16:33:40.558 Access granted
. 2009-12-30 16:33:40.559 Opened channel for session
. 2009-12-30 16:33:40.591 Started a shell/command
. 2009-12-30 16:33:40.593 --------------------------------------------------------------------------
. 2009-12-30 16:33:40.593 Using SCP protocol.
. 2009-12-30 16:33:40.593 Doing startup conversation with host.
. 2009-12-30 16:33:40.597 Skipping host startup message (if any).
> 2009-12-30 16:33:40.597 echo "WinSCP: this is end-of-file:0"
< 2009-12-30 16:33:40.627 Microsoft Windows [Version 6.1.7600]
< 2009-12-30 16:33:40.628 Copyright (c) 2009 Microsoft Corporation. All rights reserved.
< 2009-12-30 16:33:40.629 C:\Users\RajPC>echo "WinSCP: this is end-of-file:0"
< 2009-12-30 16:33:40.629 "WinSCP: this is end-of-file:0"
. 2009-12-30 16:33:55.630 Waiting for data timed out, asking user what to do.
. 2009-12-30 16:33:55.855 Asking user:
. 2009-12-30 16:33:55.855 Host has not answered for 15 seconds.
. 2009-12-30 16:33:55.855 Wait for another 15 seconds? ()
. 2009-12-30 16:34:00.333 Attempt to close connection due to fatal exception:
* 2009-12-30 16:34:00.344 Terminated by user.
. 2009-12-30 16:34:00.344 Closing connection.
. 2009-12-30 16:34:00.344 Sending special code: 12
. 2009-12-30 16:34:00.344 Sent EOF message
* 2009-12-30 16:34:00.350 (ESshFatal) Terminated by user.
* 2009-12-30 16:34:00.350 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Try SFTP instead of SCP.
rajpalparyani
In my case the requirement is to use SCP .. Is their any way I can use that and not SFTP . ?
Raj
See requirements.
