Topic "How to change Time Format?"
Antti
Hello. How can I change the format of the time given in the "Changed" column of the interface? I feel stupid, because I have gone through all the Preferences and Options several times, and cant't find any way of showing the time e.g as 29.12.2009 20:15:50 instead of 12/29/2009 8:15:50 PM, as it is shown now.
I have Windows 7 Professional (64 bit) and WinSCP 4.2.5 (Build 624). In Windows Regional Settings I have defined Date Format as "d.M.yyyy" and Time Format as "H:mm:ss". So e.g. Windows Explorer shows time and date of files exactly as I want. Why doesn't WinSCP?
Antti
I just sent you the email. Thanks for your help.
jamie
How do i change the "Changed" (Modified) date on WinSCP from American to British? eg 8th January 2014 currently showing as 12/08/2014 but want it to display as 08/12/2014.
Version and operating system as per previious posters question.
WinSCP is using system date/time format. So I assume you are American format set in Windows. Just change it to British.
