Topic "Fatal Failure with transfer of large files"
Kimberly713
I am having some trouble transferring large files (~19 MB) without getting a fatal failure error message. I am able to fully transfer smaller files successfully.
I am currently using the latest version of WinSCP, no upgrades. I'm running on a Windows XP OS, version 2002. The transfer protocol is SCP and I am using the GUI commander interface.
After signing in to WinSCP, I type in the directory that contains the .img files on the remote server that I would like to transfer. I click on the 19MB file and drag it over to my local directory on the C drive. The transfer starts to copy and upload to the local directory, but stops about 70,000B into the transfer with the following error:
Error:
Server Unexpectedly closed network connection.
Copying file 'filename.img' fatally failed.
Copying file from remote side failed.
The following is the logging information from the session.
Copying 1 files/directories to local directory "C:\Profiles\User\My Documents\SpecStudy\m029632\"
PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
TM: M; ClAr: No; CPS: 0; ExclM(No):
AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "m029632_090731sc_wat_13_1.img" ; echo "WinSCP: this is end-of-file:$status"
Sending NULL.
T1263476666 0 1263477107 0
Sending NULL.
C0664 19660800 m029632_090731sc_wat_13_1.img
Sending NULL.
Binary transfer mode selected.
Server unexpectedly closed network connection
(ESshFatal) Server unexpectedly closed network connection.
Copying file 'm029632_090731sc_wat_13_1.img' fatally failed.
Copying files from remote side failed.
Looking up host "godzilla.kennedykrieger.org"
Connecting to 12.110.104.149 port 22
Server version: SSH-2.0-Sun_SSH_1.1.2
Using SSH protocol version 2
We claim version: SSH-2.0-WinSCP_release_4.2.5
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange with hash SHA-1
Host key fingerprint is:
ssh-rsa 1024 14:94:3f:68:9a:2c:34:b2:57:36:28:90:59:33:fb:fc
Initialised AES-256 SDCTR client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 SDCTR server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Using username "malle".
Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
Using stored password.
Access granted
Opened channel for session
Started a shell/command
Doing startup conversation with host.
Skipping host startup message (if any).
Warning: no access to tty (Bad file number).
Thus no job control in this shell.
Sun Microsystems Inc. SunOS godzilla 5.10 Generic_141444-09
NOTICE!!!!!!!! ---PLEASE READ--- NOTICE!!!!!!!! ---PLEASE READ---
If you do not understand how files are stored on /g1 and /g2 please read
http://godzilla...... If you do not understand these
operations, contact Joe (j@.edu 443 923).
Tapes can be damaged and data lost by improper use of these filesystems.
Godzilla OS Upgrade - godzilla's operating system is upgraded to Solaris 10.
Please notify me of any problems or issues with applications or data access
Disk quota for /users is 2,000 MBytes.
---------- Total --------- ----- Online ------ ---- Offline ------
Volume MBytes Files Dirs MBytes Files MBytes Files
g1 3,223 409 9 3,223 409 0 0
g2 974,050 2,029,039 4,145 142,132 205,196 831,918 1,823,843
users 97 3,398 393
setenv: Syntax Error.
WinSCP: this is end-of-file:1
Detecting variable containing return code of last command.
Trying "$status".
echo "$status" ; echo "WinSCP: this is end-of-file:$status"
0
WinSCP: this is end-of-file:0
Return code variable "$status" selected.
Clearing all aliases.
unalias "ls" ; echo "WinSCP: this is end-of-file:$status"
unalias "echo" ; echo "WinSCP: this is end-of-file:$status"
unalias "pwd" ; echo "WinSCP: this is end-of-file:$status"
unalias "cd" ; echo "WinSCP: this is end-of-file:$status"
unalias "groups" ; echo "WinSCP: this is end-of-file:$status"
unalias "scp" ; echo "WinSCP: this is end-of-file:$status"
unalias "rm" ; echo "WinSCP: this is end-of-file:$status"
unalias "mv" ; echo "WinSCP: this is end-of-file:$status"
unalias "mkdir" ; echo "WinSCP: this is end-of-file:$status"
unalias "chmod" ; echo "WinSCP: this is end-of-file:$status"
unalias "chgrp" ; echo "WinSCP: this is end-of-file:$status"
unalias "chown" ; echo "WinSCP: this is end-of-file:$status"
unalias "unset" ; echo "WinSCP: this is end-of-file:$status"
unalias "unalias" ; echo "WinSCP: this is end-of-file:$status"
unalias "ln" ; echo "WinSCP: this is end-of-file:$status"
unalias "cp" ; echo "WinSCP: this is end-of-file:$status"
Clearing national user variables.
unset "LANG" ; echo "WinSCP: this is end-of-file:$status"
unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$status"
unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$status"
Changing directory to "/g2/malle/rowland/m029632_090731".
cd "/g2/malle/rowland/m029632_090731" ; echo "WinSCP: this is end-of-file:$status"
Getting current directory name.
pwd ; echo "WinSCP: this is end-of-file:$status"
Cached directory not reloaded.
Listing current directory.
The log goes on to list the current files in the directory.
Is there something else that I can try or some option I can change that will enable the transfer of these larger files?
[/b]
Have you tried SFTP?
Mattes
When using the 4.2.5 build, we encounter the same problem.
This does not happen when using 4.1.8
(However, thanks for that fine program)
Logfile (some information changed for privacy reasons):
. 2010-02-05 10:07:23.173 --------------------------------------------------------------------------
. 2010-02-05 10:07:23.173 WinSCP Version 4.2.5 (Build 624) (OS 5.1.2600 Service Pack 3)
. 2010-02-05 10:07:23.173 Login time: Freitag, 5. Februar 2010 10:07:23
. 2010-02-05 10:07:23.173 Session name: root@myhost
. 2010-02-05 10:07:23.173 Host name: myhost (Port: 22)
. 2010-02-05 10:07:23.173 User name: root (Password: No, Key file: Yes)
. 2010-02-05 10:07:23.173 Tunnel: No
. 2010-02-05 10:07:23.173 Transfer Protocol: SCP
. 2010-02-05 10:07:23.173 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-05 10:07:23.173 Proxy: none
. 2010-02-05 10:07:23.173 SSH protocol version: 2; Compression: No
. 2010-02-05 10:07:23.173 Bypass authentication: No
. 2010-02-05 10:07:23.173 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-02-05 10:07:23.173 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-02-05 10:07:23.173 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-02-05 10:07:23.173 SFTP Bugs: -,-
. 2010-02-05 10:07:23.173 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-02-05 10:07:23.173 Shell: default, EOL: 0
. 2010-02-05 10:07:23.188 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-02-05 10:07:23.188 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-02-05 10:07:23.188 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-02-05 10:07:23.188 Cache directory changes: Yes, Permanent: Yes
. 2010-02-05 10:07:23.188 DST mode: 1
. 2010-02-05 10:07:23.188 --------------------------------------------------------------------------
. 2010-02-05 10:07:23.266 Looking up host "myhost"
. 2010-02-05 10:07:23.266 Connecting to 192.168.47.11 port 22
. 2010-02-05 10:07:23.282 Server version: SSH-2.0-OpenSSH_3.6.1p2
. 2010-02-05 10:07:23.282 Using SSH protocol version 2
. 2010-02-05 10:07:23.282 We claim version: SSH-2.0-WinSCP_release_4.2.5
. 2010-02-05 10:07:23.282 Doing Diffie-Hellman group exchange
. 2010-02-05 10:07:23.313 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-02-05 10:07:23.891 Host key fingerprint is:
. 2010-02-05 10:07:24.001 ssh-rsa 1024 70:b0:43:04:97:ee:8a:f9:aa:4d:01:15:61:a8:85:cb
. 2010-02-05 10:07:24.001 Initialised AES-256 CBC client->server encryption
. 2010-02-05 10:07:24.001 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-02-05 10:07:24.001 Initialised AES-256 CBC server->client encryption
. 2010-02-05 10:07:24.001 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-02-05 10:07:24.001 Reading private key file "C:\Dokumente und Einstellungen\myname\Eigene Dateien\is_dsa.ppk"
! 2010-02-05 10:07:24.001 Using username "root".
. 2010-02-05 10:07:24.016 Offered public key
. 2010-02-05 10:07:24.048 Offer of public key accepted
! 2010-02-05 10:07:24.048 Authenticating with public key "mypublickey"
. 2010-02-05 10:07:24.048 Prompt (2, SSH key passphrase, , Passphrase for key "mypublickey": )
. 2010-02-05 10:07:27.126 Access granted
. 2010-02-05 10:07:27.141 Opened channel for session
. 2010-02-05 10:07:27.173 Started a shell/command
. 2010-02-05 10:07:27.173 --------------------------------------------------------------------------
. 2010-02-05 10:07:27.313 Using SCP protocol.
. 2010-02-05 10:07:27.313 Doing startup conversation with host.
. 2010-02-05 10:07:27.313 Skipping host startup message (if any).
> 2010-02-05 10:07:27.313 echo "WinSCP: this is end-of-file:0"
< 2010-02-05 10:07:27.360 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:27.485 Detecting variable containing return code of last command.
. 2010-02-05 10:07:27.485 Trying "$status".
> 2010-02-05 10:07:27.485 echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2010-02-05 10:07:27.688 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:27.766 The response is not numerical exit code
. 2010-02-05 10:07:27.782 Trying "$?".
> 2010-02-05 10:07:27.782 echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2010-02-05 10:07:27.813 0
< 2010-02-05 10:07:28.126 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:28.220 Return code variable "$?" selected.
. 2010-02-05 10:07:28.220 Clearing all aliases.
> 2010-02-05 10:07:28.220 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:28.251 -bash: line 4: unalias: ls: not found
< 2010-02-05 10:07:28.563 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:28.657 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:28.688 -bash: line 5: unalias: echo: not found
< 2010-02-05 10:07:29.001 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:29.063 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:29.095 -bash: line 6: unalias: pwd: not found
< 2010-02-05 10:07:29.329 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:29.391 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:29.423 -bash: line 7: unalias: cd: not found
< 2010-02-05 10:07:29.657 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:29.720 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:29.751 -bash: line 8: unalias: groups: not found
< 2010-02-05 10:07:29.985 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:30.048 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:30.079 -bash: line 9: unalias: scp: not found
< 2010-02-05 10:07:30.313 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:30.376 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:30.423 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:30.423 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:30.454 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:30.454 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:30.501 -bash: line 12: unalias: mkdir: not found
< 2010-02-05 10:07:30.751 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:30.907 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:30.938 -bash: line 13: unalias: chmod: not found
< 2010-02-05 10:07:31.188 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:31.220 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:31.251 -bash: line 14: unalias: chgrp: not found
< 2010-02-05 10:07:31.516 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:31.595 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:31.626 -bash: line 15: unalias: chown: not found
< 2010-02-05 10:07:31.845 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:31.923 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:31.954 -bash: line 16: unalias: unset: not found
< 2010-02-05 10:07:32.282 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:32.360 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:32.391 -bash: line 17: unalias: unalias: not found
< 2010-02-05 10:07:32.720 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:32.813 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-05 10:07:32.845 -bash: line 18: unalias: ln: not found
< 2010-02-05 10:07:33.157 WinSCP: this is end-of-file:1
> 2010-02-05 10:07:33.251 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.282 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:33.282 Clearing national user variables.
> 2010-02-05 10:07:33.282 unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.313 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.313 unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.360 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.360 unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.391 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.391 unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.438 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.438 unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.470 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.657 unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.688 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.688 unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.735 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.735 unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.782 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.782 unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.813 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:33.813 unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:33.860 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:34.016 Looking up groups and users.
> 2010-02-05 10:07:34.016 groups ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:34.063 root bin daemon sys adm disk wheel
< 2010-02-05 10:07:34.251 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:34.313 Following groups found:
. 2010-02-05 10:07:34.313   "root" [0]
. 2010-02-05 10:07:34.313   "bin" [0]
. 2010-02-05 10:07:34.313   "daemon" [0]
. 2010-02-05 10:07:34.313   "sys" [0]
. 2010-02-05 10:07:34.313   "adm" [0]
. 2010-02-05 10:07:34.313   "disk" [0]
. 2010-02-05 10:07:34.313   "wheel" [0]
. 2010-02-05 10:07:34.313 Following membership found:
. 2010-02-05 10:07:34.313 Following users found:
. 2010-02-05 10:07:34.313 Getting current directory name.
> 2010-02-05 10:07:34.313 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:34.360 /root
< 2010-02-05 10:07:34.688 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:35.141 Listing current directory.
> 2010-02-05 10:07:35.141 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:35.173 total 32
 --- directory information removed ---
 < 2010-02-05 10:07:35.454 WinSCP: this is end-of-file:0
. 2010-02-05 10:07:35.626 Directory listing with --full-time succeed, next time all errors during directory listing will be displayed immediatelly.
. 2010-02-05 10:07:35.626 Startup conversation with host finished.
. 2010-02-05 10:07:57.079 Cached directory change via ".." to "/".
. 2010-02-05 10:07:57.126 Getting current directory name.
. 2010-02-05 10:07:57.126 Listing current directory.
. 2010-02-05 10:07:57.126 Locating to cached directory "/".
> 2010-02-05 10:07:57.126 cd "/" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:57.157 WinSCP: this is end-of-file:0
> 2010-02-05 10:07:57.157 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:07:57.204 total 213
< 2010-02-05 10:07:57.204 WinSCP: this is end-of-file:0
. 2010-02-05 10:08:00.126 Cached directory change via "home" to "/home".
. 2010-02-05 10:08:00.173 Getting current directory name.
. 2010-02-05 10:08:00.173 Listing current directory.
. 2010-02-05 10:08:00.173 Locating to cached directory "/home".
> 2010-02-05 10:08:00.173 cd "/home" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:00.220 WinSCP: this is end-of-file:0
> 2010-02-05 10:08:00.220 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:00.251 total 16
< 2010-02-05 10:08:00.501 WinSCP: this is end-of-file:0
. 2010-02-05 10:08:02.032 Cached directory change via "username" to "/home/username".
. 2010-02-05 10:08:02.079 Getting current directory name.
. 2010-02-05 10:08:02.095 Listing current directory.
. 2010-02-05 10:08:02.095 Locating to cached directory "/home/username".
> 2010-02-05 10:08:02.095 cd "/home/username" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:02.126 WinSCP: this is end-of-file:0
> 2010-02-05 10:08:02.126 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:02.360 WinSCP: this is end-of-file:0
. 2010-02-05 10:08:04.876 Changing directory to "cpinfo".
> 2010-02-05 10:08:04.923 cd "cpinfo" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:04.970 WinSCP: this is end-of-file:0
. 2010-02-05 10:08:04.970 Getting current directory name.
> 2010-02-05 10:08:04.970 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:05.001 /home/username/cpinfo
< 2010-02-05 10:08:05.314 WinSCP: this is end-of-file:0
. 2010-02-05 10:08:05.501 Listing current directory.
> 2010-02-05 10:08:05.501 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:05.532 total 101792
< 2010-02-05 10:08:05.532 drwxrwx---    2 root     root         4096 2010-02-03 12:39:54.000000000 +0100 .
< 2010-02-05 10:08:05.532 drwx------    6 root     root         4096 2008-09-25 15:33:58.000000000 +0200 ..
< 2010-02-05 10:08:05.532 -rw-rw----    1 root     root     51840101 2010-01-08 22:00:34.000000000 +0100 20100108__myhost.gz
< 2010-02-05 10:08:05.532 -rw-rw----    1 root     root     52265496 2010-02-03 12:39:54.000000000 +0100 20100203__myhost.gz
< 2010-02-05 10:08:05.860 WinSCP: this is end-of-file:0
. 2010-02-05 10:08:20.095 Copying 1 files/directories to local directory "C:\Dokumente und Einstellungen\myname\Eigene Dateien\"
. 2010-02-05 10:08:20.126   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2010-02-05 10:08:20.126   TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-02-05 10:08:20.126   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
> 2010-02-05 10:08:20.126 echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "20100203__myhost.gz" ; echo "WinSCP: this is end-of-file:$?"
< 2010-02-05 10:08:20.157 WinSCP: this is begin-of-file
. 2010-02-05 10:08:20.157 Sending NULL.
< 2010-02-05 10:08:20.157 T1265197194 0 1265324714 0
< 2010-02-05 10:08:20.157 C0660 52265496 20100203__myhost.gz
. 2010-02-05 10:08:20.298 Sending NULL.
. 2010-02-05 10:08:20.298 Binary transfer mode selected.
. 2010-02-05 10:08:20.439 Server unexpectedly closed network connection
* 2010-02-05 10:08:20.548 (ESshFatal) Die Netzwerkverbindung wurde vom entfernten Rechner unerwartet geschlossen
* 2010-02-05 10:08:20.548 Kopieren der Datei '20100203__myhost.gz' schlug fehl (aber richtig!).
* 2010-02-05 10:08:20.548 Kopieren von Dateien vom entfernten Rechner schlug fehl.
[/code]
Can you post a log file from 4.1.8?
WinSCP can't anymore transfer large files.
tested with 4.2.5 and 4.2.6
The last correct version was 4.1.9
+1
With 4.1.9 everything works fine, but with 4.2.5 and 4.2.6 from the same server I can't transfer large files. I successfully transfer files of 8 MB, but can't transfer even 16MB, it fails with the error
"Server Unexpectedly closed network connection.
Copying file from remote side failed."
after transferring few bytes.
I tested it on few different servers, all of them running different types of Linux, and in all cases it was just as described above.
Here from 4.1.9
[code:1:5ab6150f26]. 2010-03-04 14:19:40.343 --------------------------------------------------------------------------
. 2010-03-04 14:19:40.343 WinSCP Version 4.1.9 (Build 416) (OS 5.1.2600 Service Pack 3)
. 2010-03-04 14:19:40.343 Login time: יוםחמישי 04 מרץ 2010 14:19:40
. 2010-03-04 14:19:40.343 Session name: ************
. 2010-03-04 14:19:40.343 Host name: ************ (Port: 22)
. 2010-03-04 14:19:40.343 User name: ********* (Password: Yes, Key file: No)
. 2010-03-04 14:19:40.343 Tunnel: No
. 2010-03-04 14:19:40.343 Transfer Protocol: SFTP (SCP)
. 2010-03-04 14:19:40.343 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-03-04 14:19:40.343 Proxy: none
. 2010-03-04 14:19:40.343 SSH protocol version: 2; Compression: No
. 2010-03-04 14:19:40.343 Bypass authentication: No
. 2010-03-04 14:19:40.343 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-03-04 14:19:40.343 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-03-04 14:19:40.343 SSH Bugs: -,-,-,-,-,-,-,-
. 2010-03-04 14:19:40.343 SFTP Bugs: -,-
. 2010-03-04 14:19:40.343 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-03-04 14:19:40.343 Shell: default, EOL: 0
. 2010-03-04 14:19:40.343 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-03-04 14:19:40.343 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-03-04 14:19:40.343 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-03-04 14:19:40.343 Cache directory changes: Yes, Permanent: Yes
. 2010-03-04 14:19:40.343 DST mode: 1
. 2010-03-04 14:19:40.390 Looking up host "***********"
. 2010-03-04 14:19:40.390 Connecting to ************** port 22
. 2010-03-04 14:19:40.421 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:40.421 Detected network event
. 2010-03-04 14:19:40.437 Detected network event
. 2010-03-04 14:19:40.437 Server version: SSH-2.0-OpenSSH_3.6.1p2
. 2010-03-04 14:19:40.437 We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2010-03-04 14:19:40.437 SSPI: acquired credentials for: Michael@MICHAEL
. 2010-03-04 14:19:40.437 Cannot convert IP address to SPN: DNS is not trusted
. 2010-03-04 14:19:40.453 GSSKEX disabled:
. 2010-03-04 14:19:40.453 Using SSH protocol version 2
. 2010-03-04 14:19:40.453 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:40.453 Detected network event
. 2010-03-04 14:19:40.453 Doing Diffie-Hellman group exchange
. 2010-03-04 14:19:40.515 Detected network event
. 2010-03-04 14:19:40.515 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-03-04 14:19:40.656 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.203 Detected network event
. 2010-03-04 14:19:41.343 Host key fingerprint is:
. 2010-03-04 14:19:41.343 ssh-rsa 1024 ca:b1:fa:0e:12:dc:59:3b:4f:d1:9a:ab:8a:10:6f:3a
. 2010-03-04 14:19:41.343 Initialised AES-256 CBC client->server encryption
. 2010-03-04 14:19:41.343 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-03-04 14:19:41.343 Initialised AES-256 CBC server->client encryption
. 2010-03-04 14:19:41.343 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-03-04 14:19:41.343 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.375 Detected network event
! 2010-03-04 14:19:41.375 Using username "********".
. 2010-03-04 14:19:41.375 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.406 Detected network event
. 2010-03-04 14:19:41.406 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.406 Keyboard-interactive authentication refused
. 2010-03-04 14:19:41.406 Prompt (6, SSH password, , &Password: )
. 2010-03-04 14:19:41.406 Using stored password.
. 2010-03-04 14:19:41.421 Sent password
. 2010-03-04 14:19:41.421 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.437 Detected network event
. 2010-03-04 14:19:41.437 Access granted
. 2010-03-04 14:19:41.437 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.437 Opened channel for session
. 2010-03-04 14:19:41.453 Detected network event
. 2010-03-04 14:19:41.453 Primary command failed; attempting fallback
. 2010-03-04 14:19:41.453 Waiting for the server to continue with the initialisation
. 2010-03-04 14:19:41.500 Detected network event
. 2010-03-04 14:19:41.500 Started a shell/command
. 2010-03-04 14:19:41.500 --------------------------------------------------------------------------
. 2010-03-04 14:19:41.500 Using SCP protocol.
. 2010-03-04 14:19:41.500 Doing startup conversation with host.
. 2010-03-04 14:19:41.500 Skipping host startup message (if any).
. 2010-03-04 14:19:41.500 Sent 36 bytes
. 2010-03-04 14:19:41.500 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:41.500 Sent 1 bytes
> 2010-03-04 14:19:41.500 echo "WinSCP: this is end-of-file:0"
. 2010-03-04 14:19:41.500 Waiting for another 1 bytes
. 2010-03-04 14:19:41.765 Detected network event
. 2010-03-04 14:19:41.765 Received 30 bytes (0)
. 2010-03-04 14:19:41.765 Read 1 bytes (29 pending)
. 2010-03-04 14:19:41.765 Read 29 bytes (0 pending)
< 2010-03-04 14:19:41.765 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:41.765 Detecting variable containing return code of last command.
. 2010-03-04 14:19:41.765 Trying "$status".
. 2010-03-04 14:19:41.765 Sent 53 bytes
. 2010-03-04 14:19:41.765 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:41.765 Sent 1 bytes
> 2010-03-04 14:19:41.765 echo "$status" ; echo "WinSCP: this is end-of-file:0"
. 2010-03-04 14:19:41.765 Waiting for another 1 bytes
. 2010-03-04 14:19:41.843 Detected network event
. 2010-03-04 14:19:41.843 Received 1 bytes (0)
. 2010-03-04 14:19:41.843 Read 1 bytes (0 pending)
. 2010-03-04 14:19:41.843 Waiting for another 1 bytes
. 2010-03-04 14:19:41.984 Detected network event
. 2010-03-04 14:19:41.984 Received 30 bytes (0)
. 2010-03-04 14:19:41.984 Read 1 bytes (29 pending)
. 2010-03-04 14:19:41.984 Read 29 bytes (0 pending)
< 2010-03-04 14:19:41.984 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:41.984 Trying "$?".
. 2010-03-04 14:19:41.984 Sent 48 bytes
. 2010-03-04 14:19:41.984 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:41.984 Sent 1 bytes
> 2010-03-04 14:19:41.984 echo "$?" ; echo "WinSCP: this is end-of-file:0"
. 2010-03-04 14:19:41.984 Waiting for another 1 bytes
. 2010-03-04 14:19:42.046 Detected network event
. 2010-03-04 14:19:42.046 Received 2 bytes (0)
. 2010-03-04 14:19:42.046 Read 1 bytes (1 pending)
. 2010-03-04 14:19:42.046 Read 1 bytes (0 pending)
< 2010-03-04 14:19:42.046 0
. 2010-03-04 14:19:42.046 Waiting for another 1 bytes
. 2010-03-04 14:19:42.187 Detected network event
. 2010-03-04 14:19:42.187 Received 30 bytes (0)
. 2010-03-04 14:19:42.187 Read 1 bytes (29 pending)
. 2010-03-04 14:19:42.187 Read 29 bytes (0 pending)
< 2010-03-04 14:19:42.187 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:42.187 Return code variable "$?" selected.
. 2010-03-04 14:19:42.187 Clearing all aliases.
. 2010-03-04 14:19:42.187 Sent 52 bytes
. 2010-03-04 14:19:42.187 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:42.187 Sent 1 bytes
> 2010-03-04 14:19:42.187 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:42.187 Waiting for another 1 bytes
. 2010-03-04 14:19:42.250 Detected network event
. 2010-03-04 14:19:42.250 Received 38 bytes (1)
! 2010-03-04 14:19:42.250 -bash: line 4: unalias: ls: not found
. 2010-03-04 14:19:42.250 Waiting for another 1 bytes
. 2010-03-04 14:19:42.390 Detected network event
. 2010-03-04 14:19:42.390 Received 30 bytes (0)
. 2010-03-04 14:19:42.390 Read 1 bytes (29 pending)
. 2010-03-04 14:19:42.390 Read 29 bytes (0 pending)
< 2010-03-04 14:19:42.390 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:42.390 Sent 54 bytes
. 2010-03-04 14:19:42.390 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:42.390 Sent 1 bytes
> 2010-03-04 14:19:42.390 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:42.390 Waiting for another 1 bytes
. 2010-03-04 14:19:42.453 Detected network event
. 2010-03-04 14:19:42.453 Received 40 bytes (1)
! 2010-03-04 14:19:42.453 -bash: line 5: unalias: echo: not found
. 2010-03-04 14:19:42.453 Waiting for another 1 bytes
. 2010-03-04 14:19:42.593 Detected network event
. 2010-03-04 14:19:42.593 Received 30 bytes (0)
. 2010-03-04 14:19:42.593 Read 1 bytes (29 pending)
. 2010-03-04 14:19:42.593 Read 29 bytes (0 pending)
< 2010-03-04 14:19:42.593 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:42.593 Sent 53 bytes
. 2010-03-04 14:19:42.593 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:42.593 Sent 1 bytes
> 2010-03-04 14:19:42.593 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:42.593 Waiting for another 1 bytes
. 2010-03-04 14:19:42.656 Detected network event
. 2010-03-04 14:19:42.656 Received 39 bytes (1)
! 2010-03-04 14:19:42.656 -bash: line 6: unalias: pwd: not found
. 2010-03-04 14:19:42.656 Waiting for another 1 bytes
. 2010-03-04 14:19:42.796 Detected network event
. 2010-03-04 14:19:42.796 Received 30 bytes (0)
. 2010-03-04 14:19:42.796 Read 1 bytes (29 pending)
. 2010-03-04 14:19:42.796 Read 29 bytes (0 pending)
< 2010-03-04 14:19:42.796 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:42.796 Sent 52 bytes
. 2010-03-04 14:19:42.796 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:42.796 Sent 1 bytes
> 2010-03-04 14:19:42.796 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:42.796 Waiting for another 1 bytes
. 2010-03-04 14:19:42.859 Detected network event
. 2010-03-04 14:19:42.859 Received 30 bytes (0)
. 2010-03-04 14:19:42.859 Received 38 bytes (1)
! 2010-03-04 14:19:42.859 -bash: line 7: unalias: cd: not found
. 2010-03-04 14:19:42.859 Read 1 bytes (29 pending)
. 2010-03-04 14:19:42.859 Read 29 bytes (0 pending)
< 2010-03-04 14:19:42.859 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:42.859 Sent 56 bytes
. 2010-03-04 14:19:42.859 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:42.859 Sent 1 bytes
> 2010-03-04 14:19:42.859 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:42.859 Waiting for another 1 bytes
. 2010-03-04 14:19:42.921 Detected network event
. 2010-03-04 14:19:42.921 Received 30 bytes (0)
. 2010-03-04 14:19:42.921 Received 42 bytes (1)
! 2010-03-04 14:19:42.921 -bash: line 8: unalias: groups: not found
. 2010-03-04 14:19:42.921 Read 1 bytes (29 pending)
. 2010-03-04 14:19:42.921 Read 29 bytes (0 pending)
< 2010-03-04 14:19:42.921 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:42.921 Sent 53 bytes
. 2010-03-04 14:19:42.921 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:42.921 Sent 1 bytes
> 2010-03-04 14:19:42.921 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:42.921 Waiting for another 1 bytes
. 2010-03-04 14:19:43.203 Detected network event
. 2010-03-04 14:19:43.203 Received 30 bytes (0)
. 2010-03-04 14:19:43.203 Received 39 bytes (1)
! 2010-03-04 14:19:43.203 -bash: line 9: unalias: scp: not found
. 2010-03-04 14:19:43.203 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.203 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.203 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.203 Sent 52 bytes
. 2010-03-04 14:19:43.203 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.203 Sent 1 bytes
> 2010-03-04 14:19:43.203 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.203 Waiting for another 1 bytes
. 2010-03-04 14:19:43.265 Detected network event
. 2010-03-04 14:19:43.265 Received 30 bytes (0)
. 2010-03-04 14:19:43.265 Received 39 bytes (1)
! 2010-03-04 14:19:43.265 -bash: line 10: unalias: rm: not found
. 2010-03-04 14:19:43.265 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.265 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.265 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.265 Sent 52 bytes
. 2010-03-04 14:19:43.265 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.265 Sent 1 bytes
> 2010-03-04 14:19:43.265 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.265 Waiting for another 1 bytes
. 2010-03-04 14:19:43.328 Detected network event
. 2010-03-04 14:19:43.328 Received 30 bytes (0)
. 2010-03-04 14:19:43.328 Received 39 bytes (1)
! 2010-03-04 14:19:43.328 -bash: line 11: unalias: mv: not found
. 2010-03-04 14:19:43.328 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.328 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.328 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.328 Sent 55 bytes
. 2010-03-04 14:19:43.328 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.328 Sent 1 bytes
> 2010-03-04 14:19:43.328 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.328 Waiting for another 1 bytes
. 2010-03-04 14:19:43.375 Detected network event
. 2010-03-04 14:19:43.375 Received 30 bytes (0)
. 2010-03-04 14:19:43.375 Received 42 bytes (1)
! 2010-03-04 14:19:43.375 -bash: line 12: unalias: mkdir: not found
. 2010-03-04 14:19:43.375 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.375 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.375 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.375 Sent 55 bytes
. 2010-03-04 14:19:43.375 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.375 Sent 1 bytes
> 2010-03-04 14:19:43.375 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.375 Waiting for another 1 bytes
. 2010-03-04 14:19:43.437 Detected network event
. 2010-03-04 14:19:43.437 Received 30 bytes (0)
. 2010-03-04 14:19:43.437 Received 42 bytes (1)
! 2010-03-04 14:19:43.437 -bash: line 13: unalias: chmod: not found
. 2010-03-04 14:19:43.437 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.437 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.437 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.437 Sent 55 bytes
. 2010-03-04 14:19:43.437 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.437 Sent 1 bytes
> 2010-03-04 14:19:43.437 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.437 Waiting for another 1 bytes
. 2010-03-04 14:19:43.500 Detected network event
. 2010-03-04 14:19:43.500 Received 30 bytes (0)
. 2010-03-04 14:19:43.500 Received 42 bytes (1)
! 2010-03-04 14:19:43.500 -bash: line 14: unalias: chgrp: not found
. 2010-03-04 14:19:43.500 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.500 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.500 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.500 Sent 55 bytes
. 2010-03-04 14:19:43.500 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.500 Sent 1 bytes
> 2010-03-04 14:19:43.500 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.500 Waiting for another 1 bytes
. 2010-03-04 14:19:43.562 Detected network event
. 2010-03-04 14:19:43.562 Received 30 bytes (0)
. 2010-03-04 14:19:43.578 Received 42 bytes (1)
! 2010-03-04 14:19:43.578 -bash: line 15: unalias: chown: not found
. 2010-03-04 14:19:43.578 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.578 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.578 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.578 Sent 55 bytes
. 2010-03-04 14:19:43.578 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.578 Sent 1 bytes
> 2010-03-04 14:19:43.578 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.578 Waiting for another 1 bytes
. 2010-03-04 14:19:43.625 Detected network event
. 2010-03-04 14:19:43.625 Received 30 bytes (0)
. 2010-03-04 14:19:43.625 Received 42 bytes (1)
! 2010-03-04 14:19:43.625 -bash: line 16: unalias: unset: not found
. 2010-03-04 14:19:43.625 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.625 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.625 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.625 Sent 57 bytes
. 2010-03-04 14:19:43.625 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.625 Sent 1 bytes
> 2010-03-04 14:19:43.625 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.625 Waiting for another 1 bytes
. 2010-03-04 14:19:43.687 Detected network event
. 2010-03-04 14:19:43.687 Received 30 bytes (0)
. 2010-03-04 14:19:43.687 Received 44 bytes (1)
! 2010-03-04 14:19:43.687 -bash: line 17: unalias: unalias: not found
. 2010-03-04 14:19:43.687 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.687 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.687 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.687 Sent 52 bytes
. 2010-03-04 14:19:43.687 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.687 Sent 1 bytes
> 2010-03-04 14:19:43.687 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.687 Waiting for another 1 bytes
. 2010-03-04 14:19:43.750 Detected network event
. 2010-03-04 14:19:43.750 Received 30 bytes (0)
. 2010-03-04 14:19:43.750 Received 39 bytes (1)
! 2010-03-04 14:19:43.750 -bash: line 18: unalias: ln: not found
. 2010-03-04 14:19:43.750 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.750 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.750 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.750 Sent 52 bytes
. 2010-03-04 14:19:43.750 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.750 Sent 1 bytes
> 2010-03-04 14:19:43.750 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.750 Waiting for another 1 bytes
. 2010-03-04 14:19:43.812 Detected network event
. 2010-03-04 14:19:43.812 Received 30 bytes (0)
. 2010-03-04 14:19:43.812 Received 39 bytes (1)
! 2010-03-04 14:19:43.812 -bash: line 19: unalias: cp: not found
. 2010-03-04 14:19:43.812 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.812 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.812 WinSCP: this is end-of-file:1
. 2010-03-04 14:19:43.812 Clearing national user variables.
. 2010-03-04 14:19:43.812 Sent 52 bytes
. 2010-03-04 14:19:43.812 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.812 Sent 1 bytes
> 2010-03-04 14:19:43.812 unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.812 Waiting for another 1 bytes
. 2010-03-04 14:19:43.875 Detected network event
. 2010-03-04 14:19:43.875 Received 30 bytes (0)
. 2010-03-04 14:19:43.875 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.875 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.875 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:43.875 Sent 56 bytes
. 2010-03-04 14:19:43.875 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.875 Sent 1 bytes
> 2010-03-04 14:19:43.875 unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.875 Waiting for another 1 bytes
. 2010-03-04 14:19:43.937 Detected network event
. 2010-03-04 14:19:43.937 Received 30 bytes (0)
. 2010-03-04 14:19:43.937 Read 1 bytes (29 pending)
. 2010-03-04 14:19:43.937 Read 29 bytes (0 pending)
< 2010-03-04 14:19:43.937 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:43.937 Sent 56 bytes
. 2010-03-04 14:19:43.937 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:43.937 Sent 1 bytes
> 2010-03-04 14:19:43.937 unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:43.937 Waiting for another 1 bytes
. 2010-03-04 14:19:44.015 Detected network event
. 2010-03-04 14:19:44.015 Received 30 bytes (0)
. 2010-03-04 14:19:44.015 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.015 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.015 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.015 Sent 58 bytes
. 2010-03-04 14:19:44.015 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.015 Sent 1 bytes
> 2010-03-04 14:19:44.015 unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.015 Waiting for another 1 bytes
. 2010-03-04 14:19:44.062 Detected network event
. 2010-03-04 14:19:44.062 Received 30 bytes (0)
. 2010-03-04 14:19:44.062 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.062 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.062 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.062 Sent 59 bytes
. 2010-03-04 14:19:44.062 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.062 Sent 1 bytes
> 2010-03-04 14:19:44.062 unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.062 Waiting for another 1 bytes
. 2010-03-04 14:19:44.125 Detected network event
. 2010-03-04 14:19:44.125 Received 30 bytes (0)
. 2010-03-04 14:19:44.125 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.125 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.125 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.125 Sent 58 bytes
. 2010-03-04 14:19:44.125 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.125 Sent 1 bytes
> 2010-03-04 14:19:44.125 unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.125 Waiting for another 1 bytes
. 2010-03-04 14:19:44.187 Detected network event
. 2010-03-04 14:19:44.187 Received 30 bytes (0)
. 2010-03-04 14:19:44.187 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.187 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.187 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.187 Sent 55 bytes
. 2010-03-04 14:19:44.187 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.187 Sent 1 bytes
> 2010-03-04 14:19:44.187 unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.187 Waiting for another 1 bytes
. 2010-03-04 14:19:44.250 Detected network event
. 2010-03-04 14:19:44.250 Received 30 bytes (0)
. 2010-03-04 14:19:44.250 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.250 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.250 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.250 Sent 59 bytes
. 2010-03-04 14:19:44.250 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.250 Sent 1 bytes
> 2010-03-04 14:19:44.250 unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.250 Waiting for another 1 bytes
. 2010-03-04 14:19:44.312 Detected network event
. 2010-03-04 14:19:44.312 Received 30 bytes (0)
. 2010-03-04 14:19:44.312 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.312 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.312 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.312 Sent 54 bytes
. 2010-03-04 14:19:44.312 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.312 Sent 1 bytes
> 2010-03-04 14:19:44.312 unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.312 Waiting for another 1 bytes
. 2010-03-04 14:19:44.375 Detected network event
. 2010-03-04 14:19:44.375 Received 30 bytes (0)
. 2010-03-04 14:19:44.375 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.375 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.375 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.375 Sent 60 bytes
. 2010-03-04 14:19:44.375 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.375 Sent 1 bytes
> 2010-03-04 14:19:44.375 unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.375 Waiting for another 1 bytes
. 2010-03-04 14:19:44.421 Detected network event
. 2010-03-04 14:19:44.421 Received 30 bytes (0)
. 2010-03-04 14:19:44.421 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.421 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.421 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.421 Looking up groups and users.
. 2010-03-04 14:19:44.421 Sent 46 bytes
. 2010-03-04 14:19:44.421 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.421 Sent 1 bytes
> 2010-03-04 14:19:44.421 groups ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.421 Waiting for another 1 bytes
. 2010-03-04 14:19:44.500 Detected network event
. 2010-03-04 14:19:44.500 Received 5 bytes (0)
. 2010-03-04 14:19:44.500 Read 1 bytes (4 pending)
. 2010-03-04 14:19:44.500 Read 4 bytes (0 pending)
< 2010-03-04 14:19:44.500 root
. 2010-03-04 14:19:44.500 Waiting for another 1 bytes
. 2010-03-04 14:19:44.703 Detected network event
. 2010-03-04 14:19:44.703 Received 30 bytes (0)
. 2010-03-04 14:19:44.703 Read 1 bytes (29 pending)
. 2010-03-04 14:19:44.703 Read 29 bytes (0 pending)
< 2010-03-04 14:19:44.703 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.703 Following groups found:
. 2010-03-04 14:19:44.703 root
. 2010-03-04 14:19:44.703 No users found.
. 2010-03-04 14:19:44.703 Getting current directory name.
. 2010-03-04 14:19:44.703 Sent 43 bytes
. 2010-03-04 14:19:44.703 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.703 Sent 1 bytes
> 2010-03-04 14:19:44.703 pwd ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.703 Waiting for another 1 bytes
. 2010-03-04 14:19:44.781 Detected network event
. 2010-03-04 14:19:44.781 Received 42 bytes (0)
. 2010-03-04 14:19:44.781 Read 1 bytes (41 pending)
. 2010-03-04 14:19:44.781 Read 11 bytes (30 pending)
< 2010-03-04 14:19:44.781 /home/*********
. 2010-03-04 14:19:44.781 Read 30 bytes (0 pending)
< 2010-03-04 14:19:44.781 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:44.781 Listing current directory.
. 2010-03-04 14:19:44.781 Sent 58 bytes
. 2010-03-04 14:19:44.781 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:19:44.781 Sent 1 bytes
> 2010-03-04 14:19:44.781 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:19:44.781 Waiting for another 1 bytes
. 2010-03-04 14:19:44.859 Detected network event
. 2010-03-04 14:19:44.859 Received 1050 bytes (0)
. 2010-03-04 14:19:44.859 Read 1 bytes (1049 pending)
. 2010-03-04 14:19:44.859 Read 12 bytes (1037 pending)
< 2010-03-04 14:19:44.859 total 245024
. 2010-03-04 14:19:44.859 Read 81 bytes (956 pending)
< 2010-03-04 14:19:44.859 drwx------ 2 root root 4096 2010-03-04 12:15:42.000000000 +0200 .
. 2010-03-04 14:19:44.859 Read 82 bytes (874 pending)
< 2010-03-04 14:19:44.859 drwxr-xr-x 4 root root 4096 1996-02-06 23:04:01.000000000 +0200 ..
. 2010-03-04 14:19:44.859 Read 93 bytes (781 pending)
< 2010-03-04 14:19:44.859 -rw------- 1 root root 0 2010-03-04 13:37:15.000000000 +0200 .bash_history
. 2010-03-04 14:19:44.859 Read 92 bytes (689 pending)
< 2010-03-04 14:19:44.859 -rw-r--r-- 1 root root 24 2009-11-22 21:01:57.000000000 +0200 .bash_logout
. 2010-03-04 14:19:44.859 Read 93 bytes (596 pending)
< 2010-03-04 14:19:44.859 -rw-r--r-- 1 root root 191 2009-11-22 21:01:57.000000000 +0200 .bash_profile
. 2010-03-04 14:19:44.859 Read 87 bytes (509 pending)
< 2010-03-04 14:19:44.859 -rw-r--r-- 1 root root 124 2009-11-22 21:01:57.000000000 +0200 .bashrc
. 2010-03-04 14:19:44.859 Read 89 bytes (420 pending)
< 2010-03-04 14:19:44.859 -rwxr-x--- 1 root root 8242020 2010-02-09 10:34:41.000000000 +0200 file1
. 2010-03-04 14:19:44.859 Read 104 bytes (316 pending)
< 2010-03-04 14:19:44.859 -rw-rw---- 1 root root 16455069 2010-02-01 15:45:40.000000000 +0200 file2.tgz
. 2010-03-04 14:19:44.859 Read 104 bytes (212 pending)
< 2010-03-04 14:19:44.859 -rw-rw---- 1 root root 16458298 2010-02-09 16:01:47.000000000 +0200 file3.tgz
. 2010-03-04 14:19:44.859 Read 107 bytes (105 pending)
< 2010-03-04 14:19:44.859 -rw-rw---- 1 root root 104736069 2010-03-04 12:15:42.000000000 +0200 file4.tgz
. 2010-03-04 14:19:44.859 Read 105 bytes (0 pending)
< 2010-03-04 14:19:44.859 -rw-rw---- 1 root root 104713843 2010-02-15 17:03:53.000000000 +0200 file5.tgz
. 2010-03-04 14:19:44.859 Waiting for another 1 bytes
. 2010-03-04 14:19:45.109 Detected network event
. 2010-03-04 14:19:45.109 Received 30 bytes (0)
. 2010-03-04 14:19:45.109 Read 1 bytes (29 pending)
. 2010-03-04 14:19:45.109 Read 29 bytes (0 pending)
< 2010-03-04 14:19:45.109 WinSCP: this is end-of-file:0
. 2010-03-04 14:19:45.109 Directory listing with --full-time succeed, next time all errors during directory listing will be displayed immediatelly.
. 2010-03-04 14:19:45.109 Startup conversation with host finished.
. 2010-03-04 14:19:45.750 Session upkeep
. 2010-03-04 14:19:46.250 Session upkeep
. 2010-03-04 14:19:46.750 Session upkeep
. 2010-03-04 14:19:47.250 Session upkeep
. 2010-03-04 14:19:47.750 Session upkeep
. 2010-03-04 14:19:48.250 Session upkeep
. 2010-03-04 14:19:48.750 Session upkeep
. 2010-03-04 14:19:49.250 Session upkeep
. 2010-03-04 14:19:49.750 Session upkeep
. 2010-03-04 14:19:50.250 Session upkeep
. 2010-03-04 14:19:50.750 Session upkeep
. 2010-03-04 14:19:51.250 Session upkeep
. 2010-03-04 14:19:51.750 Session upkeep
. 2010-03-04 14:19:52.250 Session upkeep
. 2010-03-04 14:19:52.750 Session upkeep
. 2010-03-04 14:19:53.250 Session upkeep
. 2010-03-04 14:19:53.750 Session upkeep
. 2010-03-04 14:19:54.250 Session upkeep
. 2010-03-04 14:19:54.750 Session upkeep
. 2010-03-04 14:19:55.250 Session upkeep
. 2010-03-04 14:19:55.750 Session upkeep
. 2010-03-04 14:19:56.250 Session upkeep
. 2010-03-04 14:19:56.750 Session upkeep
. 2010-03-04 14:19:58.250 Session upkeep
. 2010-03-04 14:19:58.750 Session upkeep
. 2010-03-04 14:19:59.250 Session upkeep
. 2010-03-04 14:19:59.750 Session upkeep
. 2010-03-04 14:20:00.250 Session upkeep
. 2010-03-04 14:20:00.750 Session upkeep
. 2010-03-04 14:20:01.250 Session upkeep
. 2010-03-04 14:20:01.750 Session upkeep
. 2010-03-04 14:20:02.250 Session upkeep
. 2010-03-04 14:20:02.750 Session upkeep
. 2010-03-04 14:20:03.250 Session upkeep
. 2010-03-04 14:20:03.750 Session upkeep
. 2010-03-04 14:20:04.250 Session upkeep
. 2010-03-04 14:20:04.750 Session upkeep
. 2010-03-04 14:20:05.250 Session upkeep
. 2010-03-04 14:20:05.750 Session upkeep
. 2010-03-04 14:20:06.250 Session upkeep
. 2010-03-04 14:20:06.750 Session upkeep
. 2010-03-04 14:20:07.046 Copying 1 files/directories to local directory "D:\Directory-Name\"
. 2010-03-04 14:20:07.046 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: Yes; Mask: *.*
. 2010-03-04 14:20:07.046 TM: B; ClAr: No; CPS: 0; ExclM(No):
. 2010-03-04 14:20:07.046 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-03-04 14:20:07.046 Sent 123 bytes
. 2010-03-04 14:20:07.046 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:20:07.046 Sent 1 bytes
> 2010-03-04 14:20:07.046 echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "file2" ; echo "WinSCP: this is end-of-file:$?"
. 2010-03-04 14:20:07.046 Waiting for another 1 bytes
. 2010-03-04 14:20:07.109 Detected network event
. 2010-03-04 14:20:07.109 Received 30 bytes (0)
. 2010-03-04 14:20:07.109 Read 1 bytes (29 pending)
. 2010-03-04 14:20:07.109 Read 29 bytes (0 pending)
< 2010-03-04 14:20:07.109 WinSCP: this is begin-of-file
. 2010-03-04 14:20:07.109 Sending NULL.
. 2010-03-04 14:20:07.109 Sent 1 bytes
. 2010-03-04 14:20:07.109 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:20:07.109 Waiting for another 1 bytes
. 2010-03-04 14:20:07.125 Detected network event
. 2010-03-04 14:20:07.125 Received 27 bytes (0)
. 2010-03-04 14:20:07.125 Read 1 bytes (26 pending)
. 2010-03-04 14:20:07.125 Read 26 bytes (0 pending)
< 2010-03-04 14:20:07.125 T1267697742 0 1267704592 0
. 2010-03-04 14:20:07.125 Sending NULL.
. 2010-03-04 14:20:07.125 Sent 1 bytes
. 2010-03-04 14:20:07.125 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:20:07.125 Waiting for another 1 bytes
. 2010-03-04 14:20:07.140 Detected network event
. 2010-03-04 14:20:07.140 Received 43 bytes (0)
. 2010-03-04 14:20:07.140 Read 1 bytes (42 pending)
. 2010-03-04 14:20:07.140 Read 42 bytes (0 pending)
< 2010-03-04 14:20:07.140 C0660 104736069 omtime_backup_04032010.tgz
. 2010-03-04 14:20:07.140 Sending NULL.
. 2010-03-04 14:20:07.140 Sent 1 bytes
. 2010-03-04 14:20:07.140 There are 0 bytes remaining in the send buffer
. 2010-03-04 14:20:07.140 Binary transfer mode selected.
. 2010-03-04 14:20:07.140 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.218 Detected network event
. 2010-03-04 14:20:07.218 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.281 Detected network event
. 2010-03-04 14:20:07.281 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.343 Detected network event
. 2010-03-04 14:20:07.343 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.406 Detected network event
. 2010-03-04 14:20:07.406 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.437 Detected network event
. 2010-03-04 14:20:07.437 Received 16384 bytes (0)
. 2010-03-04 14:20:07.437 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:07.437 Session upkeep
. 2010-03-04 14:20:07.437 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:07.437 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:07.437 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:07.437 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.500 Detected network event
. 2010-03-04 14:20:07.500 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.515 Detected network event
. 2010-03-04 14:20:07.515 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.578 Detected network event
. 2010-03-04 14:20:07.578 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.625 Detected network event
. 2010-03-04 14:20:07.625 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.671 Detected network event
. 2010-03-04 14:20:07.671 Received 16384 bytes (0)
. 2010-03-04 14:20:07.671 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:07.687 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:07.687 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:07.687 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:07.687 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.734 Detected network event
. 2010-03-04 14:20:07.734 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.796 Detected network event
. 2010-03-04 14:20:07.796 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.812 Detected network event
. 2010-03-04 14:20:07.812 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.875 Detected network event
. 2010-03-04 14:20:07.875 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.937 Detected network event
. 2010-03-04 14:20:07.937 Received 16384 bytes (0)
. 2010-03-04 14:20:07.937 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:07.937 Session upkeep
. 2010-03-04 14:20:07.937 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:07.937 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:07.937 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:07.937 Waiting for another 4096 bytes
. 2010-03-04 14:20:07.953 Detected network event
. 2010-03-04 14:20:07.953 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.031 Detected network event
. 2010-03-04 14:20:08.031 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.093 Detected network event
. 2010-03-04 14:20:08.093 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.156 Detected network event
. 2010-03-04 14:20:08.156 Received 13608 bytes (0)
. 2010-03-04 14:20:08.156 Received 2776 bytes (0)
. 2010-03-04 14:20:08.156 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:08.156 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:08.156 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:08.156 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:08.156 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.187 Detected network event
. 2010-03-04 14:20:08.187 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.250 Detected network event
. 2010-03-04 14:20:08.250 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.312 Detected network event
. 2010-03-04 14:20:08.312 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.359 Detected network event
. 2010-03-04 14:20:08.359 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.421 Detected network event
. 2010-03-04 14:20:08.437 Received 16384 bytes (0)
. 2010-03-04 14:20:08.437 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:08.437 Session upkeep
. 2010-03-04 14:20:08.437 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:08.437 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:08.437 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:08.437 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.500 Detected network event
. 2010-03-04 14:20:08.500 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.546 Detected network event
. 2010-03-04 14:20:08.546 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.593 Detected network event
. 2010-03-04 14:20:08.593 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.656 Detected network event
. 2010-03-04 14:20:08.656 Received 16384 bytes (0)
. 2010-03-04 14:20:08.656 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:08.656 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:08.656 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:08.656 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:08.656 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.718 Detected network event
. 2010-03-04 14:20:08.718 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.750 Detected network event
. 2010-03-04 14:20:08.750 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.812 Detected network event
. 2010-03-04 14:20:08.812 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.875 Detected network event
. 2010-03-04 14:20:08.875 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.937 Detected network event
. 2010-03-04 14:20:08.937 Received 16384 bytes (0)
. 2010-03-04 14:20:08.937 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:08.937 Session upkeep
. 2010-03-04 14:20:08.937 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:08.937 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:08.937 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:08.937 Waiting for another 4096 bytes
. 2010-03-04 14:20:08.953 Detected network event
. 2010-03-04 14:20:08.953 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.015 Detected network event
. 2010-03-04 14:20:09.015 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.078 Detected network event
. 2010-03-04 14:20:09.078 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.125 Detected network event
. 2010-03-04 14:20:09.125 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.187 Detected network event
. 2010-03-04 14:20:09.187 Received 16384 bytes (0)
. 2010-03-04 14:20:09.187 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:09.203 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:09.203 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:09.203 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:09.203 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.250 Detected network event
. 2010-03-04 14:20:09.250 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.296 Detected network event
. 2010-03-04 14:20:09.296 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.359 Detected network event
. 2010-03-04 14:20:09.359 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.406 Detected network event
. 2010-03-04 14:20:09.406 Received 16384 bytes (0)
. 2010-03-04 14:20:09.406 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:09.406 Session upkeep
. 2010-03-04 14:20:09.406 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:09.406 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:09.406 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:09.406 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.484 Detected network event
. 2010-03-04 14:20:09.484 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.531 Detected network event
. 2010-03-04 14:20:09.531 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.578 Detected network event
. 2010-03-04 14:20:09.578 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.640 Detected network event
. 2010-03-04 14:20:09.640 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.703 Detected network event
. 2010-03-04 14:20:09.703 Received 16384 bytes (0)
. 2010-03-04 14:20:09.703 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:09.703 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:09.703 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:09.703 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:09.703 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.734 Detected network event
. 2010-03-04 14:20:09.734 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.812 Detected network event
. 2010-03-04 14:20:09.812 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.875 Detected network event
. 2010-03-04 14:20:09.875 Waiting for another 4096 bytes
. 2010-03-04 14:20:09.937 Detected network event
. 2010-03-04 14:20:09.937 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.000 Detected network event
. 2010-03-04 14:20:10.000 Received 16384 bytes (0)
. 2010-03-04 14:20:10.000 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:10.000 Session upkeep
. 2010-03-04 14:20:10.000 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:10.000 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:10.000 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:10.000 Waiting for another 4096 bytes
<--Omitted-->
. 2010-03-04 14:20:10.671 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.750 Detected network event
. 2010-03-04 14:20:10.750 Received 16384 bytes (0)
. 2010-03-04 14:20:10.750 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:10.750 Session upkeep
. 2010-03-04 14:20:10.750 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:10.750 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:10.750 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:10.750 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.781 Detected network event
. 2010-03-04 14:20:10.781 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.843 Detected network event
. 2010-03-04 14:20:10.843 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.937 Detected network event
. 2010-03-04 14:20:10.937 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.968 Detected network event
. 2010-03-04 14:20:10.968 Waiting for another 4096 bytes
. 2010-03-04 14:20:10.984 Detected network event
. 2010-03-04 14:20:10.984 Received 16384 bytes (0)
. 2010-03-04 14:20:10.984 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:10.984 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:10.984 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:10.984 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:10.984 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.046 Detected network event
. 2010-03-04 14:20:11.046 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.109 Detected network event
. 2010-03-04 14:20:11.109 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.171 Detected network event
. 2010-03-04 14:20:11.171 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.203 Detected network event
. 2010-03-04 14:20:11.203 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.296 Detected network event
. 2010-03-04 14:20:11.296 Received 16384 bytes (0)
. 2010-03-04 14:20:11.296 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:11.296 Session upkeep
. 2010-03-04 14:20:11.296 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:11.296 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:11.296 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:11.296 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.359 Detected network event
. 2010-03-04 14:20:11.359 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.390 Detected network event
. 2010-03-04 14:20:11.390 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.453 Detected network event
. 2010-03-04 14:20:11.453 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.546 Detected network event
. 2010-03-04 14:20:11.546 Received 16384 bytes (0)
. 2010-03-04 14:20:11.546 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:11.578 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:11.578 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:11.578 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:11.578 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.593 Detected network event
. 2010-03-04 14:20:11.593 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.656 Detected network event
. 2010-03-04 14:20:11.656 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.703 Detected network event
. 2010-03-04 14:20:11.703 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.765 Detected network event
. 2010-03-04 14:20:11.765 Waiting for another 4096 bytes
. 2010-03-04 14:20:11.781 Detected network event
. 2010-03-04 14:20:11.781 Received 16384 bytes (0)
. 2010-03-04 14:20:11.781 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:11.781 Session upkeep
. 2010-03-04 14:20:11.781 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:11.781 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:11.781 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:11.781 Waiting for another 4096 bytes
<--Omitted-->
. 2010-03-04 14:20:28.734 Detected network event
. 2010-03-04 14:20:28.734 Waiting for another 4096 bytes
. 2010-03-04 14:20:28.796 Detected network event
. 2010-03-04 14:20:28.796 Waiting for another 4096 bytes
. 2010-03-04 14:20:28.859 Detected network event
. 2010-03-04 14:20:28.859 Waiting for another 4096 bytes
. 2010-03-04 14:20:28.921 Detected network event
. 2010-03-04 14:20:28.921 Received 16384 bytes (0)
. 2010-03-04 14:20:28.921 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:28.921 Session upkeep
. 2010-03-04 14:20:28.921 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:28.921 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:28.921 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:28.921 Waiting for another 4096 bytes
. 2010-03-04 14:20:28.984 Detected network event
. 2010-03-04 14:20:28.984 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.031 Detected network event
. 2010-03-04 14:20:29.031 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.093 Detected network event
. 2010-03-04 14:20:29.093 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.156 Detected network event
. 2010-03-04 14:20:29.156 Received 16384 bytes (0)
. 2010-03-04 14:20:29.156 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:29.156 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:29.156 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:29.156 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:29.156 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.218 Detected network event
. 2010-03-04 14:20:29.218 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.281 Detected network event
. 2010-03-04 14:20:29.281 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.343 Detected network event
. 2010-03-04 14:20:29.343 Waiting for another 4096 bytes
. 2010-03-04 14:20:29.406 Detected network event
. 2010-03-04 14:20:29.406 Received 16384 bytes (0)
. 2010-03-04 14:20:29.406 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:29.406 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:29.406 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:29.406 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:29.406 Waiting for another 4096 bytes
<--Omitted-->
. 2010-03-04 14:20:31.765 Detected network event
. 2010-03-04 14:20:31.765 Received 16384 bytes (0)
. 2010-03-04 14:20:31.765 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:31.765 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:31.765 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:31.765 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:31.765 Waiting for another 4096 bytes
. 2010-03-04 14:20:31.828 Detected network event
. 2010-03-04 14:20:31.828 Waiting for another 4096 bytes
. 2010-03-04 14:20:31.890 Detected network event
. 2010-03-04 14:20:31.890 Waiting for another 4096 bytes
. 2010-03-04 14:20:31.937 Detected network event
. 2010-03-04 14:20:31.937 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.000 Detected network event
. 2010-03-04 14:20:32.015 Received 16384 bytes (0)
. 2010-03-04 14:20:32.015 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:32.015 Session upkeep
. 2010-03-04 14:20:32.015 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:32.015 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:32.015 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:32.015 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.062 Detected network event
. 2010-03-04 14:20:32.062 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.125 Detected network event
. 2010-03-04 14:20:32.125 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.187 Detected network event
. 2010-03-04 14:20:32.187 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.250 Detected network event
. 2010-03-04 14:20:32.250 Received 16384 bytes (0)
. 2010-03-04 14:20:32.250 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:32.250 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:32.250 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:32.250 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:32.250 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.312 Detected network event
. 2010-03-04 14:20:32.312 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.359 Detected network event
. 2010-03-04 14:20:32.359 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.421 Detected network event
. 2010-03-04 14:20:32.421 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.484 Detected network event
. 2010-03-04 14:20:32.500 Received 16384 bytes (0)
. 2010-03-04 14:20:32.500 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:32.500 Session upkeep
. 2010-03-04 14:20:32.500 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:32.500 Read 4096 bytes (4096 pending)
. 2010-03-04 14:20:32.500 Read 4096 bytes (0 pending)
. 2010-03-04 14:20:32.500 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.546 Detected network event
. 2010-03-04 14:20:32.546 Waiting for another 4096 bytes
. 2010-03-04 14:20:32.765 Detected network event
. 2010-03-04 14:20:32.765 Received 16384 bytes (0)
. 2010-03-04 14:20:32.765 Read 4096 bytes (12288 pending)
. 2010-03-04 14:20:32.765 Read 4096 bytes (8192 pending)
. 2010-03-04 14:20:32.765 Read 4096 bytes (4096
Anonymous wrote:
Here from 4.1.9
sunnyboy
I am having the same problem. It worked with the previous version, but the new version won't transfer large files.
When can we expect a new version with the fix?
reddflash
I've the same problem with version 4.2.7. All versions since 4.2.0beta have the same problem with larger files. I assume it could be somehow related to the
Quote:
- Improved flow control with SSH-2, what improved transfer speed, particularly for downloads.
(see version history), which was introduced in version 4.2.0beta? Just an idea... Maybe it helps?
Possibly. I'm checking all possibilities.
bitdust
Having the same Problem with transferring large files, but using V4.1.9 is a good workaround so far. Cool
Rene
I think its a problem winscp working with sunSSH. I have the same problem with winscp 4.2.6 and sunSSH but winscp 4.2.6 and openSSH it works fine.
somebodyHH
we are running OpenSSH 3.9 and having problems with WinSCP 4.2.x
WinSCP Versions 4.0x and 4.1.x work fine
reddflash
any news here Question
pbos
Idea
but i have found a workaround without using version 4.1.9 : forcing SSH 1.
I am facing the same issue.
Could you please let me know the associated bug number.
Have tried searching it in the tracker but no luck.
I have also upgraded to version 4.2.8 build 818 but the issue still persists.
pb
I just ran into this issue today with 4.2.7. I've just tried 4.3.0 and I get the same thing.
I downloaded 4.1.8 and it works fine.
reaper
something new on that one ?
Were running into the same problem. Tried 4.19 and it works fine. But as you know, language settings dont work with 4.19 on Windows 7 Sad
unpatented
It's a bug in OpenSSH that WinSCP is now triggering... I commented on it here:
http://winscp.net/forum/viewtopic.php?t=8762
Perhaps someone with privileges can add it to the bug tracker?
The workaround is to use version 4.1.9 or switch to sftp mode instead of using scp.
Thanks for your post. This issue has been added to tracker.
Marta Meyer
After testing WinSCP 4.3.2 I ould U that this issue still haven't been fixed.
...here:
http://winscp.net/forum/viewtopic.php?t=9360
Are you running OpenSSH on a non-standard port? Maybe there is some device in between the end points that is causing the issue.
pocaracas
Sorry for digging out such an old thread, but... I just tried v4.2.9 and 4.3.6 and the problem still exists! Sad
Went for 4.1.9 and this one works well! I'm using Win7 Home Premium.
Only large files are affected... large means >~10MB. I had an 11MB file that failed to go, but an 8MB file went through fine.
The strange thing is, I've been using that 4.2.9 for about 2 years and it has been working fine. Then I had a small problem with my HDD and had to replace it. New windows installation, new everything. And now it doesn't work. But 4.1.9 does!
Maybe it's the windows installation. I had the one ASUS built-into the laptop. And now I have one I downloaded from M$.
Have you checked the reference to tracker above? Does it help?
TJ
Go to Advanced Option > Connection > Under Connection, Clear the "Optimize connection buffer size" and try
Kimberly713 wrote:
I am having some trouble transferring large files (~19 MB) without getting a fatal failure error message. I am able to fully transfer smaller files successfully.
I am currently using the latest version of WinSCP, no upgrades. I'm running on a Windows XP OS, version 2002. The transfer protocol is SCP and I am using the GUI commander interface.
After signing in to WinSCP, I type in the directory that contains the .img files on the remote server that I would like to transfer. I click on the 19MB file and drag it over to my local directory on the C drive. The transfer starts to copy and upload to the local directory, but stops about 70,000B into the transfer with the following error:
Error:
Copying file 'filename.img' fatally failed.
The following is the logging information from the session.
Copying 1 files/directories to local directory "C:\Profiles\User\My Documents\SpecStudy\m029632\"
PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "m029632_090731sc_wat_13_1.img" ; echo "WinSCP: this is end-of-file:$status"
Sending NULL.
T1263476666 0 1263477107 0
Sending NULL.
C0664 19660800 m029632_090731sc_wat_13_1.img
Sending NULL.
(ESshFatal) Server unexpectedly closed network connection.
Copying file 'm029632_090731sc_wat_13_1.img' fatally failed.
Copying files from remote side failed.
Looking up host "godzilla.kennedykrieger.org"
Connecting to 12.110.104.149 port 22
Server version: SSH-2.0-Sun_SSH_1.1.2
We claim version: SSH-2.0-WinSCP_release_4.2.5
ssh-rsa 1024 14:94:3f:68:9a:2c:34:b2:57:36:28:90:59:33:fb:fc
Initialised AES-256 SDCTR client->server encryption
Initialised AES-256 SDCTR server->client encryption
Using username "malle".
Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
Access granted
Warning: no access to tty (Bad file number).
Thus no job control in this shell.
Sun Microsystems Inc. SunOS godzilla 5.10 Generic_141444-09
NOTICE!!!!!!!! ---PLEASE READ--- NOTICE!!!!!!!! ---PLEASE READ---
If you do not understand how files are stored on /g1 and /g2 please read
http://godzilla...... If you do not understand these
operations, contact Joe (j@.edu 443 923).
Tapes can be damaged and data lost by improper use of these filesystems.
Godzilla OS Upgrade - godzilla's operating system is upgraded to Solaris 10.
Please notify me of any problems or issues with applications or data access
Disk quota for /users is 2,000 MBytes.
---------- Total --------- ----- Online ------ ---- Offline ------
Volume MBytes Files Dirs MBytes Files MBytes Files
g1 3,223 409 9 3,223 409 0 0
g2 974,050 2,029,039 4,145 142,132 205,196 831,918 1,823,843
users 97 3,398 393
setenv: Syntax Error.
Trying "$status".
echo "$status" ; echo "WinSCP: this is end-of-file:$status"
0
Return code variable "$status" selected.
unalias "ls" ; echo "WinSCP: this is end-of-file:$status"
unalias "echo" ; echo "WinSCP: this is end-of-file:$status"
unalias "pwd" ; echo "WinSCP: this is end-of-file:$status"
unalias "cd" ; echo "WinSCP: this is end-of-file:$status"
unalias "groups" ; echo "WinSCP: this is end-of-file:$status"
unalias "scp" ; echo "WinSCP: this is end-of-file:$status"
unalias "rm" ; echo "WinSCP: this is end-of-file:$status"
unalias "mv" ; echo "WinSCP: this is end-of-file:$status"
unalias "mkdir" ; echo "WinSCP: this is end-of-file:$status"
unalias "chmod" ; echo "WinSCP: this is end-of-file:$status"
unalias "chgrp" ; echo "WinSCP: this is end-of-file:$status"
unalias "chown" ; echo "WinSCP: this is end-of-file:$status"
unalias "unset" ; echo "WinSCP: this is end-of-file:$status"
unalias "unalias" ; echo "WinSCP: this is end-of-file:$status"
unalias "ln" ; echo "WinSCP: this is end-of-file:$status"
unalias "cp" ; echo "WinSCP: this is end-of-file:$status"
unset "LANG" ; echo "WinSCP: this is end-of-file:$status"
unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$status"
unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$status"
unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$status"
Changing directory to "/g2/malle/rowland/m029632_090731".
cd "/g2/malle/rowland/m029632_090731" ; echo "WinSCP: this is end-of-file:$status"
pwd ; echo "WinSCP: this is end-of-file:$status"
Cached directory not reloaded.
The log goes on to list the current files in the directory.
Is there something else that I can try or some option I can change that will enable the transfer of these larger files?
[/b]
JamesBrown
I don't see this option anywhere in 4.3.7. I have the Advanced Option checkbox selected but when I go to the Connection tab on the left side, I see no "Optimize connection buffer size". Can you be more specific about where this is?
JamesBrown
Martin,
Like everyone else, I'm also seeing this problem. If I revert to 4.1.9, everything works fine. Every version I've tried past that has the problem (429, 432, 433, 435, 437).
In the tracker you say that you added an 'Auto' option to the "Optimize connection buffer size" option and that previously 'Off' was required to solve the problem.
I can't seem to find the "Optimize connection buffer size" option anywhere in 4.3.7. Is it hiding somewhere I'm not looking? Another poster, TJ, said to look under Advanced Options | Connection but I don't see it there. Can you give me a pointer to where I can set this option?
I would much prefer to use 4.3.7 instead of 4.1.9 but I need to be able to transfer large files. Any help would be appreciated.
- James
It's available in 5.0.6 beta only. Can you please try it?
YES! I can confirm that WinSCP 5.0.6 (build 2074) WORKS when connecting from Win 7 Enterprise 64-bit to CentOS 4.4 with the "Optimize connection buffer size" option off (unchecked).
I tried it with the "Optimize connection buffer size" option checked and unchecked. When the option is checked (on) WinSCP FAILS to download my test file (85 meg). When the option is unchecked (off) WinSCP WORKS using the same test file. I also confirmed (via md5sum) that the downloaded file is bit-identical with the source.
I don't, however, see an option of "auto" or anything other than on/off (checked / unchecked) for the "Optimize connection buffer size" option. Is that somewhere else or is that an option in a different version?
- James[/u]
Guest2
I tested it also in it worked! Transfer of large files.
But i normally use a batch file to copy my large files.
How can I disable this option "Optimize connection buffer size" in a batch file
The batch file is started like this.
winscp.exe /console /script=c:\scripts\copyfiles_script.txt /log="c:\scripts\copyfiles.log"
Regards
Jeffie
Can either of you (ideally both) post a log files with and without the Optimize connection buffer size set?
If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
JamesBrown
Your forum software wont let me post it (I don't know why it wont allow a 4M text post Shocked ) and it isn't worth the hassle to create an account just to get your email address. If you want a copy of the log files you can email me at amFtZXNBVGhtcGdET1RuZXQgDQo= (base64 encoded). I will also try to attach a zip with both files to this post.
- James
WinSCPlogs.zip (202.38 KB) [Download]
Description: Here are the log files you requested. The names should be obvious, but in case they are not, bad.log is the failed attempt; good.log is the one that worked.
[/b]
Try running it from the command line, find the WinSCP.com file, it's usually in C:\"Program Files"\WinSCP, so in a Windows Command Prompt window type
C:\"Program Files"\WinSCP\WinSCP.com
And it will give you a winscp prompt
winscp>
From there, it's basically the same as ftp from the command line
winscp>open username@server
After entering your password, use put to transfer a file to the server or get to transfer a file from the server. close closes the connection, and exit gets you out of WinSCP.
I couldn't figure out any way to transfer a 5 GB file through the gui, but it worked like a charm from the command line.
joeyjojo
I found a similar problem today transferring a 6 GB file over a LAN. Interestingly it happened with the old version I had installed (version 3 I think) and still with the newest release.
With the optimised buffer size I would get a variety of errors, and with it disabled I get a sustained transfer speed of 3,200 KiB/s or so.
Admin - I'll send some logs to your email address later which I hope will help you fix this bug.
Cheers
