Topic "returncode 12"
gandalf_gimli
I get the returncode 12, why ? The return code 1 is also not correct.
I use following command: get filename.
The file was copy to my local server.
I use the version 4.19.
Here is the logfile:
. 2010-01-07 14:18:39.481 Binary transfer mode selected.
. 2010-01-07 14:18:39.481 Checking existence of partially transfered file.
. 2010-01-07 14:18:39.481 Opening remote file.
> 2010-01-07 14:18:39.481 Type: SSH_FXP_OPEN, Size: 46, Number: 515
< 2010-01-07 14:18:39.496 Type: SSH_FXP_HANDLE, Size: 13, Number: 515
> 2010-01-07 14:18:39.496 Type: SSH_FXP_FSTAT, Size: 13, Number: 776
> 2010-01-07 14:18:39.496 Type: SSH_FXP_READ, Size: 25, Number: 1029
. 2010-01-07 14:18:39.528 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2010-01-07 14:18:39.528 Type: SSH_FXP_ATTRS, Size: 37, Number: 776
. 2010-01-07 14:18:39.528 Storing reserved response
< 2010-01-07 14:18:40.199 Status/error code: 1
. 2010-01-07 14:18:40.199 41 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-07 14:18:40.199 Type: SSH_FXP_CLOSE, Size: 13, Number: 7172
< 2010-01-07 14:18:40.199 Type: SSH_FXP_STATUS, Size: 28, Number: 6405
< 2010-01-07 14:18:40.215 Type: SSH_FXP_STATUS, Size: 28, Number: 6661
< 2010-01-07 14:18:40.231 Type: SSH_FXP_STATUS, Size: 28, Number: 6917
. 2010-01-07 14:18:40.231 Closing connection.
. 2010-01-07 14:18:40.231 Sending special code: 12
. 2010-01-07 14:18:40.231 Sent EOF message
Congratulations for finding support forum!
Do you refer to 12 and 1 in the log file? Or what do you mean by "returncode"?
I got to returncodes:
one "Sending special code: 12 "
and the second "Status/error code: 1".
The files are stored in the directory correctly.
Can you help me, please ?
Thanks.
Gandalf_Gimli
That's perfectly correct. Status/error code 1 means "end of file".
