Topic "Files self deleting"
siege.cg@...
I'm running version WinSCP 4.3.5 on Vista, SFTP into a Linux Server.
Opened files occasionally wipe themselves down to 0kb, and editing saves but doesn't change the file, nor show an error.
Deleting/creating a new file of the same name won't save, neither will copy/pasting the file. Both actions generate this error:
General failure (server should provide error description).
Error code: 4
Error message from server: Failure
Request code: 3
Please post a full log file showing the problem. Ideally focus on only one of the problems.
siege.cg@...
Issue solved -server side error.
