Topic "WinSCP Error"
Apocal
Hello, i have problem
WinSCP Error:
Illegal PORT command
Port: 21
Where is the problem?
jermlove
I seem to have the same problem. It's strange I'm able to connect using the exact same settings on Vista Ultimate. I've tried running 4.1.9 and the same error occurs.
OS: Windows 7 Ultimate N
WinSCP Version: 4.2.5
Error log:
. 2010-02-09 17:16:50.275 --------------------------------------------------------------------------
. 2010-02-09 17:16:50.275 WinSCP Version 4.2.5 (Build 624) (OS 6.1.7600)
. 2010-02-09 17:16:50.275 Login time: Tuesday, February 09, 2010 5:16:50 PM
. 2010-02-09 17:16:50.275 Session name: jermondftp@www.briosolutions.net
. 2010-02-09 17:16:50.275 Host name: www.briosolutions.net (Port: 21)
. 2010-02-09 17:16:50.276 User name: jermondftp (Password: Yes, Key file: No)
. 2010-02-09 17:16:50.276 Tunnel: No
. 2010-02-09 17:16:50.276 Transfer Protocol: FTP
. 2010-02-09 17:16:50.276 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-09 17:16:50.276 Proxy: none
. 2010-02-09 17:16:50.276 FTP: FTPS: None; Passive: No [Force IP: No]
. 2010-02-09 17:16:50.276 Local directory: C:\Users\Jermond\Documents, Remote directory: /wwwroot/DNN50, Update: Yes, Cache: Yes
. 2010-02-09 17:16:50.276 Cache directory changes: Yes, Permanent: Yes
. 2010-02-09 17:16:50.276 DST mode: 1
. 2010-02-09 17:16:50.276 --------------------------------------------------------------------------
. 2010-02-09 17:16:50.326 Connecting to www.briosolutions.net ...
. 2010-02-09 17:16:50.335 Connected with www.briosolutions.net. Waiting for welcome message...
< 2010-02-09 17:16:50.350 220 Microsoft FTP Service
> 2010-02-09 17:16:50.350 USER jermondftp
< 2010-02-09 17:16:50.371 331 Password required for jermondftp.
> 2010-02-09 17:16:50.371 PASS *******
< 2010-02-09 17:16:50.394 230 User jermondftp logged in.
> 2010-02-09 17:16:50.394 SYST
< 2010-02-09 17:16:50.414 215 Windows_NT
> 2010-02-09 17:16:50.414 FEAT
< 2010-02-09 17:16:50.435 211-FEAT
< 2010-02-09 17:16:50.651 SIZE
< 2010-02-09 17:16:50.651 MDTM
< 2010-02-09 17:16:50.651 211 END
. 2010-02-09 17:16:50.662 Connected
. 2010-02-09 17:16:50.663 --------------------------------------------------------------------------
. 2010-02-09 17:16:50.663 Using FTP protocol.
. 2010-02-09 17:16:50.679 Doing startup conversation with host.
> 2010-02-09 17:16:50.686 PWD
< 2010-02-09 17:16:50.707 257 "/" is current directory.
. 2010-02-09 17:16:50.714 Changing directory to "/wwwroot/DNN50".
> 2010-02-09 17:16:50.714 CWD /wwwroot/DNN50
< 2010-02-09 17:16:50.735 250 CWD command successful.
. 2010-02-09 17:16:50.735 Getting current directory name.
> 2010-02-09 17:16:50.736 PWD
< 2010-02-09 17:16:50.756 257 "/wwwroot/DNN50" is current directory.
. 2010-02-09 17:16:50.765 Retrieving directory listing...
> 2010-02-09 17:16:50.765 TYPE A
< 2010-02-09 17:16:50.778 200 Type set to A.
> 2010-02-09 17:16:50.780 PORT 10,1,3,105,194,49
< 2010-02-09 17:16:50.800 500 Invalid PORT Command.
. 2010-02-09 17:16:50.800 Could not retrieve directory listing
. 2010-02-09 17:16:50.811 Retrieving directory listing...
> 2010-02-09 17:16:50.811 TYPE A
< 2010-02-09 17:16:50.822 200 Type set to A.
> 2010-02-09 17:16:50.824 PORT 10,1,3,105,194,50
< 2010-02-09 17:16:50.846 500 Invalid PORT Command.
. 2010-02-09 17:16:50.846 Could not retrieve directory listing
* 2010-02-09 17:16:50.846 (ECommand) Error listing directory '/wwwroot/DNN50'.
* 2010-02-09 17:16:50.846 Could not retrieve directory listing
* 2010-02-09 17:16:50.846 Invalid PORT Command.
. 2010-02-09 17:16:52.252 Startup conversation with host finished.
. 2010-02-09 17:16:52.311 Disconnected from server
Have you tried passive mode?
Yeah I tried running in passive mode and still got the error.
Can you post a log file for that?
