PASSWD_CHANGEREQ not yet supported
herringpond1
I've recently started receiving messages from my WinSCP users that they are receiving a "PASSWD_CHANGEREQ not yet supported" message when their password needs to be changed. I am able to reset the users password directly on the server through Computer Management, but if I check the option to require them to change their password on their first log-in, they are getting this message and can not log in.
This process just started happening recently, and has not been a problem in the past.
Anyone have any idea why I'm seeing this message? Does it sound like a WinSCP or a sFTP server issue?
Re: PASSWD_CHANGEREQ not yet supported
