Topic "Error with displaying my directory"
Agnes
I can't connect to my server. I'm using WinSCP 4.0.5. If there's a newer version I can't upgrade cos I'm at work. I'm working under Citrix. I never used WinSCP before so it never worked. ^^ I just used FileZilla before but now it's no longer installed.
I'm using Win XP. The connection I want to establish is with FTP. So when I enter the IP-address and user and password, the connection is established, but an error occurs that says "error displaying the directory "mydirectoryname"".
As I said, with FileZilla it always worked fine, I tried it last week. So the directory exists and I have the rights to read and write there.
The server I want to connect to is an z/OS server.
Agnes
Here is the log but it contains german phrases:
. 2010-01-29 11:02:53.444 --------------------------------------------------------------------------
. 2010-01-29 11:02:53.460 WinSCP Version 4.0.5 (Build 354) (OS 5.2.3790 Service Pack 2)
. 2010-01-29 11:02:53.460 Login time: Freitag, 29. Januar 2010 11:02:53
. 2010-01-29 11:02:53.460 --------------------------------------------------------------------------
. 2010-01-29 11:02:53.475 Session name: *
. 2010-01-29 11:02:53.475 Host name: * (Port: 22)
. 2010-01-29 11:02:53.491 User name: * (Password: Yes, Key file: No)
. 2010-01-29 11:02:53.491 Tunnel: No
. 2010-01-29 11:02:53.491 Transfer Protocol: SFTP (SCP)
. 2010-01-29 11:02:53.507 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-01-29 11:02:53.507 Proxy: none
. 2010-01-29 11:02:53.522 SSH protocol version: 2; Compression: No
. 2010-01-29 11:02:53.522 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-01-29 11:02:53.522 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2010-01-29 11:02:53.538 SSH Bugs: -,-,-,-,-,-,-,-
. 2010-01-29 11:02:53.538 SFTP Bugs: -,-,-
. 2010-01-29 11:02:53.538 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-01-29 11:02:53.554 Shell: default, EOL: 0
. 2010-01-29 11:02:53.554 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-01-29 11:02:53.554 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2010-01-29 11:02:53.569 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-01-29 11:02:53.569 Cache directory changes: Yes, Permanent: Yes
. 2010-01-29 11:02:53.569 DST mode: 1
. 2010-01-29 11:02:53.585 --------------------------------------------------------------------------
. 2010-01-29 11:02:53.616 Looking up host "*"
. 2010-01-29 11:02:53.616 Connecting to * port 22
. 2010-01-29 11:02:54.522 Failed to connect to *: Network error: Connection refused
* 2010-01-29 11:02:54.538 (ESshFatal) Netzwerkfehler: Verbindung abgelehnt.
. 2010-01-29 11:03:08.928 --------------------------------------------------------------------------
. 2010-01-29 11:03:08.944 WinSCP Version 4.0.5 (Build 354) (OS 5.2.3790 Service Pack 2)
. 2010-01-29 11:03:08.944 Login time: Freitag, 29. Januar 2010 11:03:08
. 2010-01-29 11:03:08.944 --------------------------------------------------------------------------
. 2010-01-29 11:03:08.959 Session name: *
. 2010-01-29 11:03:08.959 Host name: * (Port: 21)
. 2010-01-29 11:03:08.959 User name: * (Password: Yes, Key file: No)
. 2010-01-29 11:03:08.975 Tunnel: No
. 2010-01-29 11:03:08.975 Transfer Protocol: FTP
. 2010-01-29 11:03:08.990 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-01-29 11:03:08.990 Proxy: none
. 2010-01-29 11:03:08.990 FTP: Passive: No
. 2010-01-29 11:03:09.006 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-01-29 11:03:09.006 Cache directory changes: Yes, Permanent: Yes
. 2010-01-29 11:03:09.006 DST mode: 1
. 2010-01-29 11:03:09.022 --------------------------------------------------------------------------
. 2010-01-29 11:03:09.053 Verbinde mit * ...
. 2010-01-29 11:03:09.069 Verbunden mit *. erwarte Willkommensnachricht ...
< 2010-01-29 11:03:09.069 220-FTPD1 IBM FTP CS V1R10 at sapb, 10:04:45 on 2010-01-29.
< 2010-01-29 11:03:09.178 220 Connection will close if idle for more than 5 minutes.
> 2010-01-29 11:03:09.178 USER *
< 2010-01-29 11:03:09.178 331 Send password please.
> 2010-01-29 11:03:09.194 PASS *******
< 2010-01-29 11:03:09.459 230 * is logged on. Working directory is "*.".
> 2010-01-29 11:03:09.459 SYST
< 2010-01-29 11:03:09.459 215 MVS is the operating system of this server. FTP Server is running on z/OS.
> 2010-01-29 11:03:09.475 FEAT
< 2010-01-29 11:03:09.475 211 no Extensions supported
. 2010-01-29 11:03:09.490 Verbunden
. 2010-01-29 11:03:09.490 --------------------------------------------------------------------------
. 2010-01-29 11:03:09.490 Using FTP protocol.
. 2010-01-29 11:03:09.506 Doing startup conversation with host.
> 2010-01-29 11:03:09.506 PWD
< 2010-01-29 11:03:09.506 257 "'*.'" is working directory.
. 2010-01-29 11:03:09.522 Getting current directory name.
. 2010-01-29 11:03:09.522 Rufe Verzeichnisinhalt ab...
> 2010-01-29 11:03:09.537 CWD /'*.'/'*.'/
< 2010-01-29 11:03:09.537 550 CWD cmd failed : EDC5129I No such file or directory. (errno2=0x0594003D)
. 2010-01-29 11:03:09.537 Konnte Verzeichnisinhalt nicht abrufen
. 2010-01-29 11:03:09.553 Rufe Verzeichnisinhalt ab...
> 2010-01-29 11:03:09.553 CWD /'*.'/'*.'/
< 2010-01-29 11:03:09.553 550 CWD cmd failed : EDC5129I No such file or directory. (errno2=0x0594003D)
. 2010-01-29 11:03:09.569 Konnte Verzeichnisinhalt nicht abrufen
* 2010-01-29 11:03:09.569 (ECommand) Fehler beim Anzeigen des Verzeichnisses "'*.'".
* 2010-01-29 11:03:09.569 Konnte Verzeichnisinhalt nicht abrufen
* 2010-01-29 11:03:09.584 CWD cmd failed : EDC5129I No such file or directory. (errno2=0x0594003D)
. 2010-01-29 11:03:11.443 Startup conversation with host finished.
Everything personal I marked with a *.
I cannot tell for sure without the information you have removed from the log. But I suspect that WinSCP is not compatible with your remote file system.
Agnes
Yes, I think the same. However, I'm now using FileZillaPortable, that works. ^^
