Topic "WinSCP 4.2.5 Build 624) No buffer space available"
johncp1962
Greetings all,
I'm running WinSCP on 4 Windows servers (Windows Server 2003 R2). All running WinSCP 4.2.1 Build 428 with the exception of the "problem server". I recently upgraded that one to 4.2.5 in the hopes of fixing the problem.
The problem begain with 4.2.1 and continues with 4.2.5
After launching WinSCP, I simply type in the server I want to contact and enter a username. On all of the other servers, I'm prompted for a password and I'm "on my way". On the problem server, I immediately get the error "Network Error: No buffer space available"
Request assist - Thanks!
John
I haven't seen the problem before. Are you able to connect with any other SSH client? (I suppose you are using SFTP/SCP) Can you try PuTTY?
Also please post a full log file showing the problem.
johncp1962
<snipped>
prikryl: As soon as you mentioned "PuTTY", I immediately tried it and got the same error. This is not a WinSCP problem. I'll work on it on my end here. Thanks!
John
