Topic "WinSCP cannot accept special characters (@ or %) in password"
Farhana
I am using WINSCP3. In the script, if I use any special characters(.i.e @), it fails to upload. I am using hexadecimal ASCII code for special character, but still is not working
for an example:
pwd: abcd@123
and I changed to abcd%40123 in the script.
Could someone please tell me what's the correct procedure to use special characters in password in the script?
Many Thanks,
Farhana
It works for me. What version of WinSCP are you using? Make sure you use the latest version.
Thanks for the quick reply! I am using 4.2.5. It does not take "%" or "/" as password. Could you please tell me which version are you using?
The same. Can you a post a full example of the script command. Also where do you run the command from? Script or command-line (with /command parameter)?
I am using Java to create the stript to synchronize local folder.
The java program takes the password as an input. I have created jar file for the program.
The following is the sample code:
ftpUrl = ftpLoginName + ":" + ftpLoginPass + "@" + ftpDomainUrl;
// Create file
fstream = new FileWriter("SiteExportImport3.cmd");
out = new BufferedWriter(fstream);
out.write("@echo off\r\n" +
"echo option batch on>SFTP_Script.txt\r\n" +
"echo option confirm off>>SFTP_Script.txt\r\n" +
"echo open " + ftpUrl + ">>SFTP_Script.txt\r\n" +
"echo option transfer binary>>SFTP_Script.txt\r\n" +
"echo synchronizelocal "+localDirectoryName+">>SFTP_Script.txt\r\n" +
"echo close >>SFTP_Script.txt\r\n" +
"echo exit>>SFTP_Script.txt\r\n" +
"call \"C:\\Program Files\\WinSCP\\WinSCP.com\" / hostkey=\"XXX\"/script=\"SFTP_Script.txt\">log.txt\r\n" );
out.close();
in the command prompt I execute the jar file with the parameter:
MYFTP.jar password
It works fine when I don't use "%" or "/" in my password
Farhana
Possibly the echo shell command interpret the % its own way. Why don't you generate the SFTP_Script.txt directly from JScript?
You are right about echo command! It does interpret the % in different way! Thanks a lot for your help! Smile
