Topic "Odd text file transfer result"
srushing
Hi all, I'm using an automated script to sync several directories from remote sites back to my SFTP server. Today I was opening a few of the text files, and while almost all of them were fine, one specific set of files that are generated out of an electronic data capture too (the process auto-generates the files on the fly) come over total screwed. For example:
here's a few lines of a file on the remote machine before it is moved:
*** Header Start ***
VersionPersist: 1
LevelName: Session
LevelName: Block
LevelName: Trial
And here's what they look like once I get them after they've been transfered:
਍嘀攀爀猀椀漀渀倀攀爀猀椀猀琀㨀 ㄀ഀഀ
LevelName: Session
਍䰀攀瘀攀氀一愀洀攀㨀 䈀氀漀挀欀ഀഀ
LevelName: Trial
Every other line seems to be trashed.
In my current script I'm not doing anything to change any default settings for the transfer so I assumed they'd be set to auto for transfer type. But All the other text files come over just fine. Even ones created on the fly just before the transfer.
All my script does is this:
open mysavedsession
option batch on
ls
synchronize remote "c:\life Upload" \Computer1\Upload
synchronize remote "c:\life Eprime" \Computer1\ePrime
synchronize remote "c:\life MAT-SF" \Computer1\MAT-SF
synchronize remote "c:\life AccelerometryData" \Computer1\AccelerometryData
close
Any thoughts?
If you download single file you are having problems with manually, does it corrupt it as well?
srushing
Yes. Even when I transfer a single file it corrupts as well. If I zip the file and transfer the zip, everything is fine. ANd I've tried the tranfering the file as text and binary, and both ways it's corrupt.
Please post Debug-2 level log file showing download of the one (and only the one) file.
srushing
Here you go: (it's also posted at www.atark.com/winscplog.txt )
. 2010-02-24 16:20:19.063 --------------------------------------------------------------------------
. 2010-02-24 16:20:19.063 WinSCP Version 4.2.4 (Build 610) (OS 5.1.2600 Service Pack 3)
. 2010-02-24 16:20:19.063 Login time: Wednesday, February 24, 2010 4:20:19 PM
. 2010-02-24 16:20:19.063 Session name: life@ftp-server.wfubmc.edu
. 2010-02-24 16:20:19.063 Host name: ftp-server.wfubmc.edu (Port: 22)
. 2010-02-24 16:20:19.063 User name: life_Northwestern (Password: Yes, Key file: No)
. 2010-02-24 16:20:19.063 Tunnel: No
. 2010-02-24 16:20:19.063 Transfer Protocol: SFTP (SCP)
. 2010-02-24 16:20:19.063 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-24 16:20:19.063 Proxy: none
. 2010-02-24 16:20:19.063 SSH protocol version: 2; Compression: No
. 2010-02-24 16:20:19.063 Bypass authentication: No
. 2010-02-24 16:20:19.063 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-02-24 16:20:19.063 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-02-24 16:20:19.063 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-02-24 16:20:19.063 SFTP Bugs: -,-
. 2010-02-24 16:20:19.063 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-02-24 16:20:19.063 Shell: default, EOL: 0
. 2010-02-24 16:20:19.063 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-02-24 16:20:19.063 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-02-24 16:20:19.063 Local directory: default, Remote directory: \LIFE, Update: No, Cache: Yes
. 2010-02-24 16:20:19.063 Cache directory changes: Yes, Permanent: Yes
. 2010-02-24 16:20:19.063 DST mode: 1
. 2010-02-24 16:20:19.094 Looking up host "ftp-server.wfubmc.edu"
. 2010-02-24 16:20:19.094 Connecting to port 22
. 2010-02-24 16:20:19.094 Selecting events 63 for socket 820
. 2010-02-24 16:20:19.094 Waiting for the server to continue with the initialisation
. 2010-02-24 16:20:19.094 Looking for incoming data
. 2010-02-24 16:20:19.094 Looking for network events
. 2010-02-24 16:20:19.094 Detected network event
. 2010-02-24 16:20:19.094 Enumerating network events for socket 820
. 2010-02-24 16:20:19.094 Enumerated 18 network events making 18 cumulative events for socket 820
. 2010-02-24 16:20:19.094 Handling network write event on socket 820 with error 0
. 2010-02-24 16:20:19.094 Handling network connect event on socket 820 with error 0
. 2010-02-24 16:20:19.094 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.094 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:19.094 Server version: SSH-2.0-1.36_sshlib GlobalSCAPE
. 2010-02-24 16:20:19.094 We believe remote version ignores SSH-2 maximum packet size
. 2010-02-24 16:20:19.094 Using SSH protocol version 2
. 2010-02-24 16:20:19.094 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2010-02-24 16:20:19.094 Doing Diffie-Hellman group exchange
. 2010-02-24 16:20:19.282 Detected network event
. 2010-02-24 16:20:19.282 Enumerating network events for socket 820
. 2010-02-24 16:20:19.282 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.282 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:19.282 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-02-24 16:20:19.344 Waiting for the server to continue with the initialisation
. 2010-02-24 16:20:19.344 Looking for incoming data
. 2010-02-24 16:20:19.344 Looking for network events
. 2010-02-24 16:20:19.375 Detected network event
. 2010-02-24 16:20:19.375 Enumerating network events for socket 820
. 2010-02-24 16:20:19.375 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.375 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:19.453 Selecting events 63 for socket 820
. 2010-02-24 16:20:19.453 Host key fingerprint is:
. 2010-02-24 16:20:19.453 ssh-dss 1024 4f:d5:34:ce:bb:10:e8:76:40:68:d4:c9:f6:f2:9e:81
. 2010-02-24 16:20:19.453 Initialised AES-256 CBC client->server encryption
. 2010-02-24 16:20:19.453 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-02-24 16:20:19.453 Initialised AES-256 CBC server->client encryption
. 2010-02-24 16:20:19.453 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-02-24 16:20:19.453 Waiting for the server to continue with the initialisation
. 2010-02-24 16:20:19.453 Looking for incoming data
. 2010-02-24 16:20:19.453 Looking for network events
. 2010-02-24 16:20:19.610 Detected network event
. 2010-02-24 16:20:19.610 Enumerating network events for socket 820
. 2010-02-24 16:20:19.610 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.610 Handling network read event on socket 820 with error 0
! 2010-02-24 16:20:19.610 Using username "life_Northwestern".
. 2010-02-24 16:20:19.610 Waiting for the server to continue with the initialisation
. 2010-02-24 16:20:19.610 Looking for incoming data
. 2010-02-24 16:20:19.610 Looking for network events
! 2010-02-24 16:20:19.610 Further authentication required
. 2010-02-24 16:20:19.610 Further authentication required
. 2010-02-24 16:20:19.610 Prompt (6, SSH password, , &Password: )
. 2010-02-24 16:20:19.610 Using stored password.
. 2010-02-24 16:20:19.610 Sent password
. 2010-02-24 16:20:19.672 Detected network event
. 2010-02-24 16:20:19.672 Enumerating network events for socket 820
. 2010-02-24 16:20:19.672 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.672 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:19.672 Access granted
. 2010-02-24 16:20:19.672 Waiting for the server to continue with the initialisation
. 2010-02-24 16:20:19.672 Looking for incoming data
. 2010-02-24 16:20:19.672 Looking for network events
. 2010-02-24 16:20:19.672 Opened channel for session
. 2010-02-24 16:20:19.828 Detected network event
. 2010-02-24 16:20:19.828 Enumerating network events for socket 820
. 2010-02-24 16:20:19.828 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.828 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:19.828 Started a shell/command
. 2010-02-24 16:20:19.828 --------------------------------------------------------------------------
. 2010-02-24 16:20:19.828 Using SFTP protocol.
. 2010-02-24 16:20:19.828 Doing startup conversation with host.
> 2010-02-24 16:20:19.828 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2010-02-24 16:20:19.828 01,00,00,00,05,
. 2010-02-24 16:20:19.828 Sent 9 bytes
. 2010-02-24 16:20:19.828 There are 0 bytes remaining in the send buffer
. 2010-02-24 16:20:19.828 Looking for network events
. 2010-02-24 16:20:19.828 Timeout waiting for network events
. 2010-02-24 16:20:19.828 Waiting for another 4 bytes
. 2010-02-24 16:20:19.828 Looking for incoming data
. 2010-02-24 16:20:19.828 Received 9 bytes (0)
. 2010-02-24 16:20:19.828 Read 4 bytes (5 pending)
. 2010-02-24 16:20:19.828 Read 5 bytes (0 pending)
< 2010-02-24 16:20:19.828 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2010-02-24 16:20:19.828 02,00,00,00,03,
. 2010-02-24 16:20:19.828 SFTP version 3 negotiated.
. 2010-02-24 16:20:19.828 We believe the server has signed timestamps bug
. 2010-02-24 16:20:19.828 We will use UTF-8 strings for status messages only
. 2010-02-24 16:20:19.828 Changing directory to "\LIFE".
. 2010-02-24 16:20:19.828 Getting real path for '\LIFE'
> 2010-02-24 16:20:19.828 Type: SSH_FXP_REALPATH, Size: 14, Number: 16
> 2010-02-24 16:20:19.828 10,00,00,00,10,00,00,00,05,5C,4C,49,46,45,
. 2010-02-24 16:20:19.828 Sent 18 bytes
. 2010-02-24 16:20:19.828 Received 35 bytes (0)
. 2010-02-24 16:20:19.828 Read 4 bytes (31 pending)
. 2010-02-24 16:20:19.828 Read 31 bytes (0 pending)
< 2010-02-24 16:20:19.828 Type: SSH_FXP_NAME, Size: 31, Number: 16
< 2010-02-24 16:20:19.828 68,00,00,00,10,00,00,00,01,00,00,00,05,2F,4C,49,46,45,00,00,00,05,2F,4C,49,
< 2010-02-24 16:20:19.828 46,45,00,00,00,00,
. 2010-02-24 16:20:19.828 Real path is '/LIFE'
. 2010-02-24 16:20:19.828 Trying to open directory "/LIFE".
> 2010-02-24 16:20:19.828 Type: SSH_FXP_LSTAT, Size: 14, Number: 263
> 2010-02-24 16:20:19.828 07,00,00,01,07,00,00,00,05,2F,4C,49,46,45,
. 2010-02-24 16:20:19.828 Received 25 bytes (0)
. 2010-02-24 16:20:19.844 Read 4 bytes (21 pending)
. 2010-02-24 16:20:19.844 Read 21 bytes (0 pending)
< 2010-02-24 16:20:19.844 Type: SSH_FXP_ATTRS, Size: 21, Number: 263
< 2010-02-24 16:20:19.844 69,00,00,01,07,00,00,00,0C,00,00,41,64,4B,7A,C7,05,4B,7A,C7,05,
. 2010-02-24 16:20:19.844 Getting current directory name.
. 2010-02-24 16:20:19.844 Listing directory "/LIFE".
> 2010-02-24 16:20:19.844 Type: SSH_FXP_OPENDIR, Size: 14, Number: 523
> 2010-02-24 16:20:19.844 0B,00,00,02,0B,00,00,00,05,2F,4C,49,46,45,
. 2010-02-24 16:20:19.844 Sent 18 bytes
. 2010-02-24 16:20:19.844 There are 0 bytes remaining in the send buffer
. 2010-02-24 16:20:19.844 Looking for network events
. 2010-02-24 16:20:19.844 Timeout waiting for network events
. 2010-02-24 16:20:19.844 Waiting for another 4 bytes
. 2010-02-24 16:20:19.844 Looking for incoming data
. 2010-02-24 16:20:19.844 Detected network event
. 2010-02-24 16:20:19.844 Enumerating network events for socket 820
. 2010-02-24 16:20:19.844 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:19.844 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:19.844 Received 14 bytes (0)
. 2010-02-24 16:20:19.844 Read 4 bytes (10 pending)
. 2010-02-24 16:20:19.844 Read 10 bytes (0 pending)
< 2010-02-24 16:20:19.844 Type: SSH_FXP_HANDLE, Size: 10, Number: 523
< 2010-02-24 16:20:19.844 66,00,00,02,0B,00,00,00,01,31,
> 2010-02-24 16:20:19.844 Type: SSH_FXP_READDIR, Size: 10, Number: 780
> 2010-02-24 16:20:19.844 0C,00,00,03,0C,00,00,00,01,31,
. 2010-02-24 16:20:19.844 Sent 14 bytes
. 2010-02-24 16:20:19.844 Received 806 bytes (0)
. 2010-02-24 16:20:19.844 Read 4 bytes (802 pending)
. 2010-02-24 16:20:19.844 Read 802 bytes (0 pending)
< 2010-02-24 16:20:19.844 Type: SSH_FXP_NAME, Size: 802, Number: 780
< 2010-02-24 16:20:19.844 68,00,00,03,0C,00,00,00,09,00,00,00,02,4E,57,00,00,00,39,64,72,77,78,72,77,
< 2010-02-24 16:20:19.844 2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,
< 2010-02-24 16:20:19.844 20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,32,34,20,31,36,3A,31,36,20,4E,
< 2010-02-24 16:20:19.844 57,00,00,00,0C,00,00,41,F6,4B,85,97,15,4B,85,97,15,00,00,00,04,50,42,52,43,
< 2010-02-24 16:20:19.844 00,00,00,3B,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,
< 2010-02-24 16:20:19.844 20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,
< 2010-02-24 16:20:19.844 31,36,20,31,34,3A,33,35,20,50,42,52,43,00,00,00,0C,00,00,41,F6,4B,7A,F3,95,
< 2010-02-24 16:20:19.844 4B,7A,F3,95,00,00,00,04,50,69,74,74,00,00,00,3B,64,72,77,78,72,77,2D,72,77,
< 2010-02-24 16:20:19.844 2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,
< 2010-02-24 16:20:19.844 20,20,20,20,20,20,30,20,46,65,62,20,32,34,20,31,36,3A,31,33,20,50,69,74,74,
< 2010-02-24 16:20:19.844 00,00,00,0C,00,00,41,F6,4B,85,96,70,4B,85,96,70,00,00,00,08,53,74,61,6E,66,
< 2010-02-24 16:20:19.844 6F,72,64,00,00,00,3F,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,
< 2010-02-24 16:20:19.844 72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,
< 2010-02-24 16:20:19.844 65,62,20,31,37,20,31,32,3A,32,34,20,53,74,61,6E,66,6F,72,64,00,00,00,0C,00,
< 2010-02-24 16:20:19.844 00,41,F6,4B,7C,26,4B,4B,7C,26,4B,00,00,00,05,54,75,66,74,73,00,00,00,3C,64,
< 2010-02-24 16:20:19.844 72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,
< 2010-02-24 16:20:19.844 6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,31,37,20,31,31,
< 2010-02-24 16:20:19.844 3A,35,33,20,54,75,66,74,73,00,00,00,0C,00,00,41,F6,4B,7C,1E,FC,4B,7C,1E,FC,
< 2010-02-24 16:20:19.844 00,00,00,02,55,46,00,00,00,39,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,
< 2010-02-24 16:20:19.844 75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,
< 2010-02-24 16:20:19.844 30,20,46,65,62,20,31,36,20,31,31,3A,32,36,20,55,46,00,00,00,0C,00,00,41,F6,
< 2010-02-24 16:20:19.844 4B,7A,C7,2C,4B,7A,C7,2C,00,00,00,08,55,46,42,72,6F,6F,6B,73,00,00,00,3F,64,
< 2010-02-24 16:20:19.844 6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,31,36,20,31,31,
< 2010-02-24 16:20:19.844 3A,32,36,20,55,46,42,72,6F,6F,6B,73,00,00,00,0C,00,00,41,F6,4B,7A,C7,39,4B,
< 2010-02-24 16:20:19.844 7A,C7,39,00,00,00,04,57,41,4B,45,00,00,00,3B,64,72,77,78,72,77,2D,72,77,2D,
< 2010-02-24 16:20:19.844 20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,
< 2010-02-24 16:20:19.844 20,20,20,20,20,30,20,46,65,62,20,31,36,20,31,31,3A,31,31,20,57,41,4B,45,00,
< 2010-02-24 16:20:19.844 00,00,0C,00,00,41,F6,4B,7A,C3,C4,4B,7A,C3,C4,00,00,00,04,59,61,6C,65,00,00,
< 2010-02-24 16:20:19.844 00,3B,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,
< 2010-02-24 16:20:19.844 20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,32,34,
< 2010-02-24 16:20:19.844 20,31,36,3A,31,32,20,59,61,6C,65,00,00,00,0C,00,00,41,F6,4B,85,96,41,4B,85,
< 2010-02-24 16:20:19.844 96,41,
> 2010-02-24 16:20:19.844 Type: SSH_FXP_READDIR, Size: 10, Number: 1036
> 2010-02-24 16:20:19.844 0C,00,00,04,0C,00,00,00,01,31,
. 2010-02-24 16:20:19.844 Read file 'NW' from listing
. 2010-02-24 16:20:19.844 Read file 'PBRC' from listing
. 2010-02-24 16:20:19.844 Read file 'Pitt' from listing
. 2010-02-24 16:20:19.844 Read file 'Stanford' from listing
. 2010-02-24 16:20:19.844 Read file 'Tufts' from listing
. 2010-02-24 16:20:19.844 Read file 'UF' from listing
. 2010-02-24 16:20:19.844 Read file 'UFBrooks' from listing
. 2010-02-24 16:20:19.844 Read file 'WAKE' from listing
. 2010-02-24 16:20:19.844 Read file 'Yale' from listing
. 2010-02-24 16:20:19.844 Received 26 bytes (0)
. 2010-02-24 16:20:19.844 Read 4 bytes (22 pending)
. 2010-02-24 16:20:19.844 Read 22 bytes (0 pending)
< 2010-02-24 16:20:19.844 Type: SSH_FXP_STATUS, Size: 22, Number: 1036
< 2010-02-24 16:20:19.844 65,00,00,04,0C,00,00,00,01,00,00,00,03,65,6F,66,00,00,00,02,65,6E,
< 2010-02-24 16:20:19.844 Status code: 1
> 2010-02-24 16:20:19.844 Type: SSH_FXP_CLOSE, Size: 10, Number: 1284
> 2010-02-24 16:20:19.844 04,00,00,05,04,00,00,00,01,31,
. 2010-02-24 16:20:19.844 Startup conversation with host finished.
. 2010-02-24 16:20:20.469 Session upkeep
. 2010-02-24 16:20:20.469 Looking for network events
. 2010-02-24 16:20:20.469 Detected network event
. 2010-02-24 16:20:20.469 Enumerating network events for socket 820
. 2010-02-24 16:20:20.469 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:20.469 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:20.469 Received 25 bytes (0)
. 2010-02-24 16:20:20.969 Session upkeep
. 2010-02-24 16:20:20.969 Looking for network events
. 2010-02-24 16:20:20.969 Timeout waiting for network events
. 2010-02-24 16:20:21.469 Session upkeep
. 2010-02-24 16:20:21.469 Looking for network events
. 2010-02-24 16:20:21.469 Timeout waiting for network events
. 2010-02-24 16:20:21.969 Session upkeep
. 2010-02-24 16:20:21.969 Looking for network events
. 2010-02-24 16:20:21.969 Timeout waiting for network events
. 2010-02-24 16:20:22.469 Session upkeep
. 2010-02-24 16:20:22.469 Looking for network events
. 2010-02-24 16:20:22.469 Timeout waiting for network events
. 2010-02-24 16:20:22.969 Session upkeep
. 2010-02-24 16:20:22.969 Looking for network events
. 2010-02-24 16:20:22.969 Timeout waiting for network events
. 2010-02-24 16:20:23.469 Session upkeep
. 2010-02-24 16:20:23.469 Looking for network events
. 2010-02-24 16:20:23.469 Timeout waiting for network events
. 2010-02-24 16:20:23.969 Session upkeep
. 2010-02-24 16:20:23.969 Looking for network events
. 2010-02-24 16:20:23.969 Timeout waiting for network events
. 2010-02-24 16:20:24.469 Session upkeep
. 2010-02-24 16:20:24.469 Looking for network events
. 2010-02-24 16:20:24.469 Timeout waiting for network events
. 2010-02-24 16:20:24.969 Session upkeep
. 2010-02-24 16:20:24.969 Looking for network events
. 2010-02-24 16:20:24.969 Timeout waiting for network events
. 2010-02-24 16:20:25.469 Session upkeep
. 2010-02-24 16:20:25.469 Looking for network events
. 2010-02-24 16:20:25.469 Timeout waiting for network events
. 2010-02-24 16:20:25.969 Session upkeep
. 2010-02-24 16:20:25.969 Looking for network events
. 2010-02-24 16:20:25.969 Timeout waiting for network events
. 2010-02-24 16:20:26.704 Session upkeep
. 2010-02-24 16:20:26.704 Looking for network events
. 2010-02-24 16:20:26.704 Timeout waiting for network events
. 2010-02-24 16:20:27.626 Session upkeep
. 2010-02-24 16:20:27.626 Looking for network events
. 2010-02-24 16:20:27.626 Timeout waiting for network events
. 2010-02-24 16:20:27.969 Session upkeep
. 2010-02-24 16:20:27.969 Looking for network events
. 2010-02-24 16:20:27.969 Timeout waiting for network events
. 2010-02-24 16:20:28.469 Session upkeep
. 2010-02-24 16:20:28.469 Looking for network events
. 2010-02-24 16:20:28.469 Timeout waiting for network events
. 2010-02-24 16:20:28.969 Session upkeep
. 2010-02-24 16:20:28.969 Looking for network events
. 2010-02-24 16:20:28.969 Timeout waiting for network events
. 2010-02-24 16:20:29.469 Session upkeep
. 2010-02-24 16:20:29.469 Looking for network events
. 2010-02-24 16:20:29.469 Timeout waiting for network events
. 2010-02-24 16:20:29.969 Session upkeep
. 2010-02-24 16:20:29.969 Looking for network events
. 2010-02-24 16:20:29.969 Timeout waiting for network events
. 2010-02-24 16:20:30.469 Session upkeep
. 2010-02-24 16:20:30.469 Looking for network events
. 2010-02-24 16:20:30.469 Timeout waiting for network events
. 2010-02-24 16:20:30.969 Session upkeep
. 2010-02-24 16:20:30.969 Looking for network events
. 2010-02-24 16:20:30.969 Timeout waiting for network events
. 2010-02-24 16:20:31.469 Session upkeep
. 2010-02-24 16:20:31.469 Looking for network events
. 2010-02-24 16:20:31.469 Timeout waiting for network events
. 2010-02-24 16:20:31.969 Session upkeep
. 2010-02-24 16:20:31.969 Looking for network events
. 2010-02-24 16:20:31.969 Timeout waiting for network events
. 2010-02-24 16:20:32.469 Session upkeep
. 2010-02-24 16:20:32.469 Looking for network events
. 2010-02-24 16:20:32.469 Timeout waiting for network events
. 2010-02-24 16:20:32.969 Session upkeep
. 2010-02-24 16:20:32.969 Looking for network events
. 2010-02-24 16:20:32.969 Timeout waiting for network events
. 2010-02-24 16:20:33.469 Session upkeep
. 2010-02-24 16:20:33.469 Looking for network events
. 2010-02-24 16:20:33.469 Timeout waiting for network events
. 2010-02-24 16:20:33.969 Session upkeep
. 2010-02-24 16:20:33.969 Looking for network events
. 2010-02-24 16:20:33.969 Timeout waiting for network events
. 2010-02-24 16:20:34.469 Session upkeep
. 2010-02-24 16:20:34.469 Looking for network events
. 2010-02-24 16:20:34.469 Timeout waiting for network events
. 2010-02-24 16:20:34.970 Session upkeep
. 2010-02-24 16:20:34.970 Looking for network events
. 2010-02-24 16:20:34.970 Timeout waiting for network events
. 2010-02-24 16:20:35.470 Session upkeep
. 2010-02-24 16:20:35.470 Looking for network events
. 2010-02-24 16:20:35.470 Timeout waiting for network events
. 2010-02-24 16:20:35.970 Session upkeep
. 2010-02-24 16:20:35.970 Looking for network events
. 2010-02-24 16:20:35.970 Timeout waiting for network events
. 2010-02-24 16:20:36.470 Session upkeep
. 2010-02-24 16:20:36.470 Looking for network events
. 2010-02-24 16:20:36.470 Timeout waiting for network events
. 2010-02-24 16:20:36.970 Session upkeep
. 2010-02-24 16:20:36.970 Looking for network events
. 2010-02-24 16:20:36.970 Timeout waiting for network events
. 2010-02-24 16:20:37.470 Session upkeep
. 2010-02-24 16:20:37.470 Looking for network events
. 2010-02-24 16:20:37.470 Timeout waiting for network events
. 2010-02-24 16:20:37.970 Session upkeep
. 2010-02-24 16:20:37.970 Looking for network events
. 2010-02-24 16:20:37.970 Timeout waiting for network events
. 2010-02-24 16:20:38.470 Session upkeep
. 2010-02-24 16:20:38.470 Looking for network events
. 2010-02-24 16:20:38.470 Timeout waiting for network events
. 2010-02-24 16:20:38.970 Session upkeep
. 2010-02-24 16:20:38.970 Looking for network events
. 2010-02-24 16:20:38.970 Timeout waiting for network events
. 2010-02-24 16:20:39.470 Session upkeep
. 2010-02-24 16:20:39.470 Looking for network events
. 2010-02-24 16:20:39.470 Timeout waiting for network events
. 2010-02-24 16:20:39.970 Session upkeep
. 2010-02-24 16:20:39.970 Looking for network events
. 2010-02-24 16:20:39.970 Timeout waiting for network events
. 2010-02-24 16:20:40.470 Session upkeep
. 2010-02-24 16:20:40.470 Looking for network events
. 2010-02-24 16:20:40.470 Timeout waiting for network events
. 2010-02-24 16:20:40.970 Session upkeep
. 2010-02-24 16:20:40.970 Looking for network events
. 2010-02-24 16:20:40.970 Timeout waiting for network events
. 2010-02-24 16:20:41.470 Session upkeep
. 2010-02-24 16:20:41.470 Looking for network events
. 2010-02-24 16:20:41.470 Timeout waiting for network events
. 2010-02-24 16:20:41.970 Session upkeep
. 2010-02-24 16:20:41.970 Looking for network events
. 2010-02-24 16:20:41.970 Timeout waiting for network events
. 2010-02-24 16:20:42.470 Session upkeep
. 2010-02-24 16:20:42.470 Looking for network events
. 2010-02-24 16:20:42.470 Timeout waiting for network events
. 2010-02-24 16:20:42.970 Session upkeep
. 2010-02-24 16:20:42.970 Looking for network events
. 2010-02-24 16:20:42.970 Timeout waiting for network events
. 2010-02-24 16:20:43.470 Session upkeep
. 2010-02-24 16:20:43.470 Looking for network events
. 2010-02-24 16:20:43.470 Timeout waiting for network events
. 2010-02-24 16:20:43.970 Session upkeep
. 2010-02-24 16:20:43.970 Looking for network events
. 2010-02-24 16:20:43.970 Timeout waiting for network events
. 2010-02-24 16:20:44.470 Session upkeep
. 2010-02-24 16:20:44.470 Looking for network events
. 2010-02-24 16:20:44.470 Timeout waiting for network events
. 2010-02-24 16:20:44.970 Session upkeep
. 2010-02-24 16:20:44.970 Looking for network events
. 2010-02-24 16:20:44.970 Timeout waiting for network events
. 2010-02-24 16:20:45.470 Session upkeep
. 2010-02-24 16:20:45.470 Looking for network events
. 2010-02-24 16:20:45.470 Timeout waiting for network events
. 2010-02-24 16:20:45.970 Session upkeep
. 2010-02-24 16:20:45.970 Looking for network events
. 2010-02-24 16:20:45.970 Timeout waiting for network events
. 2010-02-24 16:20:46.032 Copying 1 files/directories to remote directory "/LIFE/"
. 2010-02-24 16:20:46.032 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2010-02-24 16:20:46.032 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-02-24 16:20:46.032 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-02-24 16:20:46.032 File: "C:\Documents and Settings\srushing\Desktop\1_flanker-1000136-1.txt"
. 2010-02-24 16:20:46.032 Copying "C:\Documents and Settings\srushing\Desktop\1_flanker-1000136-1.txt" to remote directory started.
. 2010-02-24 16:20:46.032 Ascii transfer mode selected.
. 2010-02-24 16:20:46.032 Opening remote file.
> 2010-02-24 16:20:46.032 Type: SSH_FXP_OPEN, Size: 54, Number: 1539
> 2010-02-24 16:20:46.032 03,00,00,06,03,00,00,00,1D,2F,4C,49,46,45,2F,31,5F,66,6C,61,6E,6B,65,72,2D,
> 2010-02-24 16:20:46.032 31,30,30,30,31,33,36,2D,31,2E,74,78,74,00,00,00,3A,00,00,00,01,00,00,00,00,
> 2010-02-24 16:20:46.032 00,00,10,C2,
. 2010-02-24 16:20:46.032 Sent 58 bytes
. 2010-02-24 16:20:46.032 There are 0 bytes remaining in the send buffer
. 2010-02-24 16:20:46.032 Looking for network events
. 2010-02-24 16:20:46.032 Timeout waiting for network events
. 2010-02-24 16:20:46.032 Read 4 bytes (21 pending)
. 2010-02-24 16:20:46.032 Read 21 bytes (0 pending)
< 2010-02-24 16:20:46.032 Type: SSH_FXP_STATUS, Size: 21, Number: 1284
< 2010-02-24 16:20:46.032 65,00,00,05,04,00,00,00,00,00,00,00,02,4F,6B,00,00,00,02,65,6E,
. 2010-02-24 16:20:46.032 Discarding reserved response
. 2010-02-24 16:20:46.032 Waiting for another 4 bytes
. 2010-02-24 16:20:46.032 Looking for incoming data
. 2010-02-24 16:20:46.048 Detected network event
. 2010-02-24 16:20:46.048 Enumerating network events for socket 820
. 2010-02-24 16:20:46.048 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:46.048 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:46.048 Received 14 bytes (0)
. 2010-02-24 16:20:46.048 Read 4 bytes (10 pending)
. 2010-02-24 16:20:46.048 Read 10 bytes (0 pending)
< 2010-02-24 16:20:46.048 Type: SSH_FXP_HANDLE, Size: 10, Number: 1539
< 2010-02-24 16:20:46.048 66,00,00,06,03,00,00,00,01,31,
. 2010-02-24 16:20:46.048 Write request offset: 0, len: 4096
> 2010-02-24 16:20:46.048 Type: SSH_FXP_WRITE, Size: 4118, Number: 2054
> 2010-02-24 16:20:46.048 06,00,00,08,06,00,00,00,01,31,00,00,00,00,00,00,00,00,00,00,10,00,FF,FE,2A,
> 2010-02-24 16:20:46.048 00,2A,00,2A,00,20,00,48,00,65,00,61,00,64,00,65,00,72,00,20,00,53,00,74,00,
> 2010-02-24 16:20:46.048 61,00,72,00,74,00,20,00,2A,00,2A,00,2A,00,0D,00,0A,00,56,00,65,00,72,00,73,
> 2010-02-24 16:20:46.048 00,69,00,6F,00,6E,00,50,00,65,00,72,00,73,00,69,00,73,00,74,00,3A,00,20,00,
> 2010-02-24 16:20:46.048 31,00,0D,00,0A,00,4C,00,65,00,76,00,65,00,6C,00,4E,00,61,00,6D,00,65,00,3A,
> 2010-02-24 16:20:46.048 00,20,00,53,00,65,00,73,00,73,00,69,00,6F,00,6E,00,0D,00,0A,00,4C,00,65,00,
> 2010-02-24 16:20:46.048 76,00,65,00,6C,00,4E,00,61,00,6D,00,65,00,3A,00,20,00,42,00,6C,00,6F,00,63,
> 2010-02-24 16:20:46.048 00,6B,00,0D,00,0A,00,4C,00,65,00,76,00,65,00,6C,00,4E,00,61,00,6D,00,65,00,
> 2010-02-24 16:20:46.048 3A,00,20,00,54,00,72,00,69,00,61,00,6C,00,0D,00,0A,00,4C,00,65,00,76,00,65,
> 2010-02-24 16:20:46.048 00,6C,00,4E,00,61,00,6D,00,65,00,3A,00,20,00,53,00,75,00,62,00,54,00,72,00,
> 2010-02-24 16:20:46.048 69,00,61,00,6C,00,0D,00,0A,00,4C,00,65,00,76,00,65,00,6C,00,4E,00,61,00,6D,
> 2010-02-24 16:20:46.048 00,65,00,3A,00,20,00,4C,00,6F,00,67,00,4C,00,65,00,76,00,65,00,6C,00,35,00,
> 2010-02-24 16:20:46.048 0D,00,0A,00,4C,00,65,00,76,00,65,00,6C,00,4E,00,61,00,6D,00,65,00,3A,00,20,
> 2010-02-24 16:20:46.048 00,4C,00,6F,00,67,00,4C,00,65,00,76,00,65,00,6C,00,36,00,0D,00,0A,00,4C,00,
> 2010-02-24 16:20:46.048 65,00,76,00,65,00,6C,00,4E,00,61,00,6D,00,65,00,3A,00,20,00,4C,00,6F,00,67,
> 2010-02-24 16:20:46.048 00,4C,00,65,00,76,00,65,00,6C,00,37,00,0D,00,0A,00,4C,00,65,00,76,00,65,00,
> 2010-02-24 16:20:46.048 6C,00,4E,00,61,00,6D,00,65,00,3A,00,20,00,4C,00,6F,00,67,00,4C,00,65,00,76,
> 2010-02-24 16:20:46.048 00,65,00,6C,00,38,00,0D,00,0A,00,4C,00,65,00,76,00,65,00,6C,00,4E,00,61,00,
> 2010-02-24 16:20:46.048 6D,00,65,00,3A,00,20,00,4C,00,6F,00,67,00,4C,00,65,00,76,00,65,00,6C,00,39,
> 2010-02-24 16:20:46.048 00,0D,00,0A,00,4C,00,65,00,76,00,65,00,6C,00,4E,00,61,00,6D,00,65,00,3A,00,
> 2010-02-24 16:20:46.048 20,00,4C,00,6F,00,67,00,4C,00,65,00,76,00,65,00,6C,00,31,00,30,00,0D,00,0A,
> 2010-02-24 16:20:46.048 00,45,00,78,00,70,00,65,00,72,00,69,00,6D,00,65,00,6E,00,74,00,3A,00,20,00,
> 2010-02-24 16:20:46.048 31,00,5F,00,66,00,6C,00,61,00,6E,00,6B,00,65,00,72,00,0D,00,0A,00,53,00,65,
> 2010-02-24 16:20:46.048 00,73,00,73,00,69,00,6F,00,6E,00,44,00,61,00,74,00,65,00,3A,00,20,00,30,00,
> 2010-02-24 16:20:46.048 32,00,2D,00,31,00,37,00,2D,00,32,00,30,00,31,00,30,00,0D,00,0A,00,53,00,65,
> 2010-02-24 16:20:46.048 00,73,00,73,00,69,00,6F,00,6E,00,54,00,69,00,6D,00,65,00,3A,00,20,00,31,00,
> 2010-02-24 16:20:46.048 34,00,3A,00,35,00,36,00,3A,00,32,00,39,00,0D,00,0A,00,53,00,65,00,73,00,73,
> 2010-02-24 16:20:46.048 00,69,00,6F,00,6E,00,54,00,69,00,6D,00,65,00,55,00,74,00,63,00,3A,00,20,00,
> 2010-02-24 16:20:46.048 37,00,3A,00,35,00,36,00,3A,00,32,00,39,00,20,00,50,00,4D,00,0D,00,0A,00,53,
> 2010-02-24 16:20:46.048 00,75,00,62,00,6A,00,65,00,63,00,74,00,3A,00,20,00,31,00,30,00,30,00,30,00,
> 2010-02-24 16:20:46.048 31,00,33,00,36,00,0D,00,0A,00,41,00,63,00,72,00,6F,00,73,00,74,00,69,00,63,
> 2010-02-24 16:20:46.048 00,3A,00,20,00,73,00,64,00,72,00,0D,00,0A,00,53,00,65,00,73,00,73,00,69,00,
> 2010-02-24 16:20:46.048 6F,00,6E,00,3A,00,20,00,31,00,0D,00,0A,00,52,00,61,00,6E,00,64,00,6F,00,6D,
> 2010-02-24 16:20:46.048 00,53,00,65,00,65,00,64,00,3A,00,20,00,2D,00,31,00,37,00,35,00,31,00,35,00,
> 2010-02-24 16:20:46.048 31,00,36,00,34,00,37,00,36,00,0D,00,0A,00,47,00,72,00,6F,00,75,00,70,00,3A,
> 2010-02-24 16:20:46.048 00,20,00,31,00,0D,00,0A,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,2E,00,
> 2010-02-24 16:20:46.048 52,00,65,00,66,00,72,00,65,00,73,00,68,00,52,00,61,00,74,00,65,00,3A,00,20,
> 2010-02-24 16:20:46.048 00,35,00,39,00,2E,00,34,00,36,00,36,00,0D,00,0A,00,2A,00,2A,00,2A,00,20,00,
> 2010-02-24 16:20:46.048 48,00,65,00,61,00,64,00,65,00,72,00,20,00,45,00,6E,00,64,00,20,00,2A,00,2A,
> 2010-02-24 16:20:46.048 00,2A,00,0D,00,0A,00,09,00,4C,00,65,00,76,00,65,00,6C,00,3A,00,20,00,32,00,
> 2010-02-24 16:20:46.048 0D,00,0A,00,09,00,2A,00,2A,00,2A,00,20,00,4C,00,6F,00,67,00,46,00,72,00,61,
> 2010-02-24 16:20:46.048 00,6D,00,65,00,20,00,53,00,74,00,61,00,72,00,74,00,20,00,2A,00,2A,00,2A,00,
> 2010-02-24 16:20:46.048 0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,00,54,00,72,
> 2010-02-24 16:20:46.048 00,69,00,61,00,6C,00,73,00,3A,00,20,00,32,00,0D,00,0A,00,09,00,50,00,72,00,
> 2010-02-24 16:20:46.048 6F,00,63,00,65,00,64,00,75,00,72,00,65,00,3A,00,20,00,74,00,72,00,69,00,61,
> 2010-02-24 16:20:46.048 00,6C,00,70,00,72,00,6F,00,63,00,0D,00,0A,00,09,00,63,00,6F,00,6E,00,67,00,
> 2010-02-24 16:20:46.048 72,00,75,00,65,00,6E,00,63,00,79,00,3A,00,20,00,69,00,6E,00,63,00,6F,00,6E,
> 2010-02-24 16:20:46.048 00,67,00,0D,00,0A,00,09,00,63,00,6F,00,72,00,72,00,65,00,63,00,74,00,72,00,
> 2010-02-24 16:20:46.048 65,00,73,00,70,00,6F,00,6E,00,73,00,65,00,3A,00,20,00,7A,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 00,73,00,74,00,69,00,6D,00,66,00,69,00,6C,00,65,00,3A,00,20,00,3E,00,20,00,
> 2010-02-24 16:20:46.048 3E,00,20,00,3C,00,20,00,3E,00,20,00,3E,00,0D,00,0A,00,09,00,50,00,72,00,61,
> 2010-02-24 16:20:46.048 00,63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,2E,00,
> 2010-02-24 16:20:46.048 43,00,79,00,63,00,6C,00,65,00,3A,00,20,00,31,00,0D,00,0A,00,09,00,50,00,72,
> 2010-02-24 16:20:46.048 00,61,00,63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,
> 2010-02-24 16:20:46.048 2E,00,53,00,61,00,6D,00,70,00,6C,00,65,00,3A,00,20,00,31,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 00,52,00,75,00,6E,00,6E,00,69,00,6E,00,67,00,3A,00,20,00,50,00,72,00,61,00,
> 2010-02-24 16:20:46.048 63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,0D,00,0A,
> 2010-02-24 16:20:46.048 00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,
> 2010-02-24 16:20:46.048 35,00,2E,00,54,00,69,00,6D,00,69,00,6E,00,67,00,4D,00,6F,00,64,00,65,00,3A,
> 2010-02-24 16:20:46.048 00,20,00,30,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,
> 2010-02-24 16:20:46.048 70,00,6C,00,61,00,79,00,35,00,2E,00,41,00,43,00,43,00,3A,00,20,00,31,00,0D,
> 2010-02-24 16:20:46.048 00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,
> 2010-02-24 16:20:46.048 79,00,35,00,2E,00,52,00,54,00,3A,00,20,00,39,00,33,00,35,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,
> 2010-02-24 16:20:46.048 2E,00,52,00,45,00,53,00,50,00,3A,00,20,00,7A,00,0D,00,0A,00,09,00,54,00,65,
> 2010-02-24 16:20:46.048 00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,43,00,
> 2010-02-24 16:20:46.048 52,00,45,00,53,00,50,00,3A,00,20,00,7A,00,0D,00,0A,00,09,00,2A,00,2A,00,2A,
> 2010-02-24 16:20:46.048 00,20,00,4C,00,6F,00,67,00,46,00,72,00,61,00,6D,00,65,00,20,00,45,00,6E,00,
> 2010-02-24 16:20:46.048 64,00,20,00,2A,00,2A,00,2A,00,0D,00,0A,00,09,00,4C,00,65,00,76,00,65,00,6C,
> 2010-02-24 16:20:46.048 00,3A,00,20,00,32,00,0D,00,0A,00,09,00,2A,00,2A,00,2A,00,20,00,4C,00,6F,00,
> 2010-02-24 16:20:46.048 67,00,46,00,72,00,61,00,6D,00,65,00,20,00,53,00,74,00,61,00,72,00,74,00,20,
> 2010-02-24 16:20:46.048 00,2A,00,2A,00,2A,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,69,00,
> 2010-02-24 16:20:46.048 63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,3A,00,20,00,38,00,0D,00,0A,
> 2010-02-24 16:20:46.048 00,09,00,50,00,72,00,6F,00,63,00,65,00,64,00,75,00,72,00,65,00,3A,00,20,00,
> 2010-02-24 16:20:46.048 74,00,72,00,69,00,61,00,6C,00,70,00,72,00,6F,00,63,00,0D,00,0A,00,09,00,63,
> 2010-02-24 16:20:46.048 00,6F,00,6E,00,67,00,72,00,75,00,65,00,6E,00,63,00,79,00,3A,00,20,00,63,00,
> 2010-02-24 16:20:46.048 6F,00,6E,00,67,00,72,00,75,00,65,00,6E,00,74,00,0D,00,0A,00,09,00,63,00,6F,
> 2010-02-24 16:20:46.048 00,72,00,72,00,65,00,63,00,74,00,72,00,65,00,73,00,70,00,6F,00,6E,00,73,00,
> 2010-02-24 16:20:46.048 65,00,3A,00,20,00,6D,00,0D,00,0A,00,09,00,73,00,74,00,69,00,6D,00,66,00,69,
> 2010-02-24 16:20:46.048 00,6C,00,65,00,3A,00,20,00,3E,00,20,00,3E,00,20,00,3E,00,20,00,3E,00,20,00,
> 2010-02-24 16:20:46.048 3E,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,00,54,
> 2010-02-24 16:20:46.048 00,72,00,69,00,61,00,6C,00,73,00,2E,00,43,00,79,00,63,00,6C,00,65,00,3A,00,
> 2010-02-24 16:20:46.048 20,00,31,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,
> 2010-02-24 16:20:46.048 00,54,00,72,00,69,00,61,00,6C,00,73,00,2E,00,53,00,61,00,6D,00,70,00,6C,00,
> 2010-02-24 16:20:46.048 65,00,3A,00,20,00,32,00,0D,00,0A,00,09,00,52,00,75,00,6E,00,6E,00,69,00,6E,
> 2010-02-24 16:20:46.048 00,67,00,3A,00,20,00,50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,00,54,00,
> 2010-02-24 16:20:46.048 72,00,69,00,61,00,6C,00,73,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,
> 2010-02-24 16:20:46.048 00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,54,00,69,00,6D,00,69,00,
> 2010-02-24 16:20:46.048 6E,00,67,00,4D,00,6F,00,64,00,65,00,3A,00,20,00,30,00,0D,00,0A,00,09,00,54,
> 2010-02-24 16:20:46.048 00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,
> 2010-02-24 16:20:46.048 41,00,43,00,43,00,3A,00,20,00,30,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,
> 2010-02-24 16:20:46.048 00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,52,00,54,00,3A,00,
> 2010-02-24 16:20:46.048 20,00,31,00,30,00,37,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,
> 2010-02-24 16:20:46.048 00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,52,00,45,00,53,00,50,00,3A,00,
> 2010-02-24 16:20:46.048 20,00,7A,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,
> 2010-02-24 16:20:46.048 00,6C,00,61,00,79,00,35,00,2E,00,43,00,52,00,45,00,53,00,50,00,3A,00,20,00,
> 2010-02-24 16:20:46.048 6D,00,0D,00,0A,00,09,00,2A,00,2A,00,2A,00,20,00,4C,00,6F,00,67,00,46,00,72,
> 2010-02-24 16:20:46.048 00,61,00,6D,00,65,00,20,00,45,00,6E,00,64,00,20,00,2A,00,2A,00,2A,00,0D,00,
> 2010-02-24 16:20:46.048 0A,00,09,00,4C,00,65,00,76,00,65,00,6C,00,3A,00,20,00,32,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 00,2A,00,2A,00,2A,00,20,00,4C,00,6F,00,67,00,46,00,72,00,61,00,6D,00,65,00,
> 2010-02-24 16:20:46.048 20,00,53,00,74,00,61,00,72,00,74,00,20,00,2A,00,2A,00,2A,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 00,50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,
> 2010-02-24 16:20:46.048 6C,00,73,00,3A,00,20,00,36,00,0D,00,0A,00,09,00,50,00,72,00,6F,00,63,00,65,
> 2010-02-24 16:20:46.048 00,64,00,75,00,72,00,65,00,3A,00,20,00,74,00,72,00,69,00,61,00,6C,00,70,00,
> 2010-02-24 16:20:46.048 72,00,6F,00,63,00,0D,00,0A,00,09,00,63,00,6F,00,6E,00,67,00,72,00,75,00,65,
> 2010-02-24 16:20:46.048 00,6E,00,63,00,79,00,3A,00,20,00,69,00,6E,00,63,00,6F,00,6E,00,67,00,0D,00,
> 2010-02-24 16:20:46.048 0A,00,09,00,63,00,6F,00,72,00,72,00,65,00,63,00,74,00,72,00,65,00,73,00,70,
> 2010-02-24 16:20:46.048 00,6F,00,6E,00,73,00,65,00,3A,00,20,00,7A,00,0D,00,0A,00,09,00,73,00,74,00,
> 2010-02-24 16:20:46.048 69,00,6D,00,66,00,69,00,6C,00,65,00,3A,00,20,00,3E,00,20,00,3E,00,20,00,3C,
> 2010-02-24 16:20:46.048 00,20,00,3E,00,20,00,3E,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,
> 2010-02-24 16:20:46.048 69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,2E,00,43,00,79,00,63,
> 2010-02-24 16:20:46.048 00,6C,00,65,00,3A,00,20,00,31,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,
> 2010-02-24 16:20:46.048 74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,2E,00,53,00,61,
> 2010-02-24 16:20:46.048 00,6D,00,70,00,6C,00,65,00,3A,00,20,00,33,00,0D,00,0A,00,09,00,52,00,75,00,
> 2010-02-24 16:20:46.048 6E,00,6E,00,69,00,6E,00,67,00,3A,00,20,00,50,00,72,00,61,00,63,00,74,00,69,
> 2010-02-24 16:20:46.048 00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,0D,00,0A,00,09,00,54,00,
> 2010-02-24 16:20:46.048 65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,54,
> 2010-02-24 16:20:46.048 00,69,00,6D,00,69,00,6E,00,67,00,4D,00,6F,00,64,00,65,00,3A,00,20,00,30,00,
> 2010-02-24 16:20:46.048 0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,
> 2010-02-24 16:20:46.048 00,79,00,35,00,2E,00,41,00,43,00,43,00,3A,00,20,00,30,00,0D,00,0A,00,09,00,
> 2010-02-24 16:20:46.048 54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,
> 2010-02-24 16:20:46.048 00,52,00,54,00,3A,00,20,00,37,00,35,00,0D,00,0A,00,09,00,54,00,65,00,78,00,
> 2010-02-24 16:20:46.048 74,00,44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,52,00,45,00,53,
> 2010-02-24 16:20:46.048 00,50,00,3A,00,20,00,6D,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,
> 2010-02-24 16:20:46.048 69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,43,00,52,00,45,00,53,00,50,
> 2010-02-24 16:20:46.048 00,3A,00,20,00,7A,00,0D,00,0A,00,09,00,2A,00,2A,00,2A,00,20,00,4C,00,6F,00,
> 2010-02-24 16:20:46.048 67,00,46,00,72,00,61,00,6D,00,65,00,20,00,45,00,6E,00,64,00,20,00,2A,00,2A,
> 2010-02-24 16:20:46.048 00,69,00,61,00,6C,00,73,00,3A,00,20,00,31,00,0D,00,0A,00,09,00,50,00,72,00,
> 2010-02-24 16:20:46.048 72,00,75,00,65,00,6E,00,63,00,79,00,3A,00,20,00,63,00,6F,00,6E,00,67,00,72,
> 2010-02-24 16:20:46.048 00,75,00,65,00,6E,00,74,00,0D,00,0A,00,09,00,63,00,6F,00,72,00,72,00,65,00,
> 2010-02-24 16:20:46.048 63,00,74,00,72,00,65,00,73,00,70,00,6F,00,6E,00,73,00,65,00,3A,00,20,00,7A,
> 2010-02-24 16:20:46.048 00,0D,00,0A,00,09,00,73,00,74,00,69,00,6D,00,66,00,69,00,6C,00,65,00,3A,00,
> 2010-02-24 16:20:46.048 20,00,3C,00,20,00,3C,00,20,00,3C,00,20,00,3C,00,20,00,3C,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 6C,00,73,00,2E,00,43,00,79,00,63,00,6C,00,65,00,3A,00,20,00,31,00,0D,00,0A,
> 2010-02-24 16:20:46.048 00,09,00,50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,
> 2010-02-24 16:20:46.048 61,00,6C,00,73,00,2E,00,53,00,61,00,6D,00,70,00,6C,00,65,00,3A,00,20,00,34,
> 2010-02-24 16:20:46.048 00,0D,00,0A,00,09,00,52,00,75,00,6E,00,6E,00,69,00,6E,00,67,00,3A,00,20,00,
> 2010-02-24 16:20:46.048 50,00,72,00,61,00,63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,
> 2010-02-24 16:20:46.048 00,73,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,
> 2010-02-24 16:20:46.048 6C,00,61,00,79,00,35,00,2E,00,54,00,69,00,6D,00,69,00,6E,00,67,00,4D,00,6F,
> 2010-02-24 16:20:46.048 00,64,00,65,00,3A,00,20,00,30,00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,
> 2010-02-24 16:20:46.048 44,00,69,00,73,00,70,00,6C,00,61,00,79,00,35,00,2E,00,41,00,43,00,43,00,3A,
> 2010-02-24 16:20:46.048 70,00,6C,00,61,00,79,00,35,00,2E,00,52,00,54,00,3A,00,20,00,31,00,30,00,31,
> 2010-02-24 16:20:46.048 00,0D,00,0A,00,09,00,54,00,65,00,78,00,74,00,44,00,69,00,73,00,70,00,6C,00,
> 2010-02-24 16:20:46.048 61,00,79,00,35,00,2E,00,52,00,45,00,53,00,50,00,3A,00,20,00,6D,00,0D,00,0A,
> 2010-02-24 16:20:46.048 35,00,2E,00,43,00,52,00,45,00,53,00,50,00,3A,00,20,00,7A,00,0D,00,0A,00,09,
> 2010-02-24 16:20:46.048 20,00,45,00,6E,00,64,00,20,00,2A,00,2A,00,2A,00,0D,00,0A,00,09,00,4C,00,65,
> 2010-02-24 16:20:46.048 00,76,00,65,00,6C,00,3A,00,20,00,32,00,0D,00,0A,00,09,00,2A,00,2A,00,2A,00,
> 2010-02-24 16:20:46.048 20,00,4C,00,6F,00,67,00,46,00,72,00,61,00,6D,00,65,00,20,00,53,00,74,00,61,
> 2010-02-24 16:20:46.048 00,72,00,74,00,20,00,2A,00,2A,00,2A,00,0D,00,0A,00,09,00,50,00,72,00,61,00,
> 2010-02-24 16:20:46.048 63,00,74,00,69,00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,3A,00,20,
> 2010-02-24 16:20:46.048 00,33,00,0D,00,0A,00,09,00,50,00,72,00,6F,00,63,00,65,00,64,00,75,00,72,00,
> 2010-02-24 16:20:46.048 65,00,3A,00,20,00,74,00,72,00,69,00,61,00,6C,00,70,00,72,00,6F,00,63,00,0D,
> 2010-02-24 16:20:46.048 00,0A,00,09,00,63,00,6F,00,6E,00,67,00,72,00,75,00,65,00,6E,00,63,00,79,00,
> 2010-02-24 16:20:46.048 3A,00,20,00,69,00,6E,00,63,00,6F,00,6E,00,67,00,0D,00,
. 2010-02-24 16:20:46.048 Sent 4122 bytes
. 2010-02-24 16:20:46.048 There are 0 bytes remaining in the send buffer
. 2010-02-24 16:20:46.048 Looking for network events
. 2010-02-24 16:20:46.048 Timeout waiting for network events
. 2010-02-24 16:20:46.048 Write request offset: 4096, len: 194
> 2010-02-24 16:20:46.048 Type: SSH_FXP_WRITE, Size: 216, Number: 2310
> 2010-02-24 16:20:46.048 06,00,00,09,06,00,00,00,01,31,00,00,00,00,00,00,10,00,00,00,00,C2,0A,00,09,
> 2010-02-24 16:20:46.048 00,63,00,6F,00,72,00,72,00,65,00,63,00,74,00,72,00,65,00,73,00,70,00,6F,00,
> 2010-02-24 16:20:46.048 6E,00,73,00,65,00,3A,00,20,00,6D,00,0D,00,0A,00,09,00,73,00,74,00,69,00,6D,
> 2010-02-24 16:20:46.048 00,66,00,69,00,6C,00,65,00,3A,00,20,00,3C,00,20,00,3C,00,20,00,3E,00,20,00,
> 2010-02-24 16:20:46.048 3C,00,20,00,3C,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,69,00,63,
> 2010-02-24 16:20:46.048 00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,2E,00,43,00,79,00,63,00,6C,00,
> 2010-02-24 16:20:46.048 65,00,3A,00,20,00,31,00,0D,00,0A,00,09,00,50,00,72,00,61,00,63,00,74,00,69,
> 2010-02-24 16:20:46.048 00,63,00,65,00,54,00,72,00,69,00,61,00,6C,00,73,00,2E,00,53,00,61,00,6D,00,
> 2010-02-24 16:20:46.048 70,00,6C,00,65,00,3A,00,20,00,35,00,0D,00,0A,00,
. 2010-02-24 16:20:46.048 Sent 220 bytes
> 2010-02-24 16:20:46.048 Type: SSH_FXP_CLOSE, Size: 10, Number: 2564
> 2010-02-24 16:20:46.048 04,00,00,0A,04,00,00,00,01,31,
. 2010-02-24 16:20:46.048 Sent 14 bytes
> 2010-02-24 16:20:46.048 Type: SSH_FXP_SETSTAT, Size: 50, Number: 1801
> 2010-02-24 16:20:46.048 09,00,00,07,09,00,00,00,1D,2F,4C,49,46,45,2F,31,5F,66,6C,61,6E,6B,65,72,2D,
> 2010-02-24 16:20:46.048 31,30,30,30,31,33,36,2D,31,2E,74,78,74,00,00,00,08,4B,85,97,E9,4B,7C,4A,0C,
. 2010-02-24 16:20:46.048 Sent 54 bytes
. 2010-02-24 16:20:46.048 Waiting for another 4 bytes
. 2010-02-24 16:20:46.048 Looking for incoming data
. 2010-02-24 16:20:46.048 Received 25 bytes (0)
. 2010-02-24 16:20:46.048 Read 4 bytes (21 pending)
. 2010-02-24 16:20:46.048 Read 21 bytes (0 pending)
< 2010-02-24 16:20:46.048 Type: SSH_FXP_STATUS, Size: 21, Number: 2054
< 2010-02-24 16:20:46.048 65,00,00,08,06,00,00,00,00,00,00,00,02,4F,4B,00,00,00,02,65,6E,
< 2010-02-24 16:20:46.048 Type: SSH_FXP_STATUS, Size: 21, Number: 2310
< 2010-02-24 16:20:46.048 65,00,00,09,06,00,00,00,00,00,00,00,02,4F,4B,00,00,00,02,65,6E,
. 2010-02-24 16:20:46.064 Detected network event
. 2010-02-24 16:20:46.064 Enumerating network events for socket 820
. 2010-02-24 16:20:46.064 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:46.064 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:46.064 Received 25 bytes (0)
. 2010-02-24 16:20:46.064 Read 4 bytes (46 pending)
. 2010-02-24 16:20:46.064 Read 21 bytes (25 pending)
< 2010-02-24 16:20:46.064 Type: SSH_FXP_STATUS, Size: 21, Number: 2564
< 2010-02-24 16:20:46.064 65,00,00,0A,04,00,00,00,00,00,00,00,02,4F,6B,00,00,00,02,65,6E,
< 2010-02-24 16:20:46.064 Status code: 0
. 2010-02-24 16:20:46.064 Read 4 bytes (21 pending)
. 2010-02-24 16:20:46.064 Read 21 bytes (0 pending)
< 2010-02-24 16:20:46.064 Type: SSH_FXP_STATUS, Size: 21, Number: 1801
< 2010-02-24 16:20:46.064 65,00,00,07,09,00,00,00,00,00,00,00,02,4F,4B,00,00,00,02,65,6E,
. 2010-02-24 16:20:46.064 Listing directory "/LIFE".
> 2010-02-24 16:20:46.064 Type: SSH_FXP_OPENDIR, Size: 14, Number: 2827
> 2010-02-24 16:20:46.064 0B,00,00,0B,0B,00,00,00,05,2F,4C,49,46,45,
. 2010-02-24 16:20:46.064 Sent 18 bytes
. 2010-02-24 16:20:46.064 There are 0 bytes remaining in the send buffer
. 2010-02-24 16:20:46.064 Looking for network events
. 2010-02-24 16:20:46.064 Timeout waiting for network events
. 2010-02-24 16:20:46.064 Waiting for another 4 bytes
. 2010-02-24 16:20:46.064 Looking for incoming data
. 2010-02-24 16:20:46.064 Received 14 bytes (0)
. 2010-02-24 16:20:46.064 Read 4 bytes (10 pending)
. 2010-02-24 16:20:46.064 Read 10 bytes (0 pending)
< 2010-02-24 16:20:46.064 Type: SSH_FXP_HANDLE, Size: 10, Number: 2827
< 2010-02-24 16:20:46.064 66,00,00,0B,0B,00,00,00,01,31,
> 2010-02-24 16:20:46.064 Type: SSH_FXP_READDIR, Size: 10, Number: 3084
> 2010-02-24 16:20:46.064 0C,00,00,0C,0C,00,00,00,01,31,
. 2010-02-24 16:20:46.064 Sent 14 bytes
. 2010-02-24 16:20:46.064 Received 939 bytes (0)
. 2010-02-24 16:20:46.064 Read 4 bytes (935 pending)
. 2010-02-24 16:20:46.064 Read 935 bytes (0 pending)
< 2010-02-24 16:20:46.064 Type: SSH_FXP_NAME, Size: 935, Number: 3084
< 2010-02-24 16:20:46.064 68,00,00,0C,0C,00,00,00,0A,00,00,00,17,31,5F,66,6C,61,6E,6B,65,72,2D,31,30,
< 2010-02-24 16:20:46.064 30,30,31,33,36,2D,31,2E,74,78,74,00,00,00,4E,2D,72,77,2D,72,77,2D,72,77,2D,
< 2010-02-24 16:20:46.064 20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,
< 2010-02-24 16:20:46.064 20,20,34,32,39,30,20,46,65,62,20,32,34,20,31,36,3A,32,30,20,31,5F,66,6C,61,
< 2010-02-24 16:20:46.064 6E,6B,65,72,2D,31,30,30,30,31,33,36,2D,31,2E,74,78,74,00,00,00,0D,00,00,00,
< 2010-02-24 16:20:46.064 00,00,00,10,C2,00,00,81,B6,4B,85,98,2D,4B,85,98,2D,00,00,00,02,4E,57,00,00,
< 2010-02-24 16:20:46.064 00,39,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,
< 2010-02-24 16:20:46.064 20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,32,34,
< 2010-02-24 16:20:46.064 20,31,36,3A,31,36,20,4E,57,00,00,00,0C,00,00,41,F6,4B,85,97,15,4B,85,97,15,
< 2010-02-24 16:20:46.064 00,00,00,04,50,42,52,43,00,00,00,3B,64,72,77,78,72,77,2D,72,77,2D,20,20,20,
< 2010-02-24 16:20:46.064 31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,
< 2010-02-24 16:20:46.064 20,20,30,20,46,65,62,20,31,36,20,31,34,3A,33,35,20,50,42,52,43,00,00,00,0C,
< 2010-02-24 16:20:46.064 00,00,41,F6,4B,7A,F3,95,4B,7A,F3,95,00,00,00,04,50,69,74,74,00,00,00,3B,64,
< 2010-02-24 16:20:46.064 72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,
< 2010-02-24 16:20:46.064 6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,32,34,20,31,36,
< 2010-02-24 16:20:46.064 3A,31,33,20,50,69,74,74,00,00,00,0C,00,00,41,F6,4B,85,96,70,4B,85,96,70,00,
< 2010-02-24 16:20:46.064 00,00,08,53,74,61,6E,66,6F,72,64,00,00,00,3F,64,72,77,78,72,77,2D,72,77,2D,
< 2010-02-24 16:20:46.064 20,20,20,20,20,30,20,46,65,62,20,31,37,20,31,32,3A,32,34,20,53,74,61,6E,66,
< 2010-02-24 16:20:46.064 6F,72,64,00,00,00,0C,00,00,41,F6,4B,7C,26,4B,4B,7C,26,4B,00,00,00,05,54,75,
< 2010-02-24 16:20:46.064 66,74,73,00,00,00,3C,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,
< 2010-02-24 16:20:46.064 72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,
< 2010-02-24 16:20:46.064 65,62,20,31,37,20,31,31,3A,35,33,20,54,75,66,74,73,00,00,00,0C,00,00,41,F6,
< 2010-02-24 16:20:46.064 4B,7C,1E,FC,4B,7C,1E,FC,00,00,00,02,55,46,00,00,00,39,64,72,77,78,72,77,2D,
< 2010-02-24 16:20:46.064 72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,
< 2010-02-24 16:20:46.064 20,20,20,20,20,20,20,20,30,20,46,65,62,20,31,36,20,31,31,3A,32,36,20,55,46,
< 2010-02-24 16:20:46.064 00,00,00,0C,00,00,41,F6,4B,7A,C7,2C,4B,7A,C7,2C,00,00,00,08,55,46,42,72,6F,
< 2010-02-24 16:20:46.064 6F,6B,73,00,00,00,3F,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,
< 2010-02-24 16:20:46.064 65,62,20,31,36,20,31,31,3A,32,36,20,55,46,42,72,6F,6F,6B,73,00,00,00,0C,00,
< 2010-02-24 16:20:46.064 00,41,F6,4B,7A,C7,39,4B,7A,C7,39,00,00,00,04,57,41,4B,45,00,00,00,3B,64,72,
< 2010-02-24 16:20:46.064 77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,
< 2010-02-24 16:20:46.064 75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,46,65,62,20,31,36,20,31,31,3A,
< 2010-02-24 16:20:46.064 31,31,20,57,41,4B,45,00,00,00,0C,00,00,41,F6,4B,7A,C3,C4,4B,7A,C3,C4,00,00,
< 2010-02-24 16:20:46.064 00,04,59,61,6C,65,00,00,00,3B,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,
< 2010-02-24 16:20:46.064 75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,
< 2010-02-24 16:20:46.064 30,20,46,65,62,20,32,34,20,31,36,3A,31,32,20,59,61,6C,65,00,00,00,0C,00,00,
< 2010-02-24 16:20:46.064 41,F6,4B,85,96,41,4B,85,96,41,
> 2010-02-24 16:20:46.064 Type: SSH_FXP_READDIR, Size: 10, Number: 3340
> 2010-02-24 16:20:46.064 0C,00,00,0D,0C,00,00,00,01,31,
. 2010-02-24 16:20:46.064 Read file '1_flanker-1000136-1.txt' from listing
. 2010-02-24 16:20:46.064 Read file 'NW' from listing
. 2010-02-24 16:20:46.064 Read file 'PBRC' from listing
. 2010-02-24 16:20:46.064 Read file 'Pitt' from listing
. 2010-02-24 16:20:46.064 Read file 'Stanford' from listing
. 2010-02-24 16:20:46.064 Read file 'Tufts' from listing
. 2010-02-24 16:20:46.064 Read file 'UF' from listing
. 2010-02-24 16:20:46.064 Read file 'UFBrooks' from listing
. 2010-02-24 16:20:46.064 Read file 'WAKE' from listing
. 2010-02-24 16:20:46.064 Read file 'Yale' from listing
. 2010-02-24 16:20:46.064 Received 26 bytes (0)
. 2010-02-24 16:20:46.064 Read 4 bytes (22 pending)
. 2010-02-24 16:20:46.064 Read 22 bytes (0 pending)
< 2010-02-24 16:20:46.064 Type: SSH_FXP_STATUS, Size: 22, Number: 3340
< 2010-02-24 16:20:46.064 65,00,00,0D,0C,00,00,00,01,00,00,00,03,65,6F,66,00,00,00,02,65,6E,
< 2010-02-24 16:20:46.064 Status code: 1
> 2010-02-24 16:20:46.064 Type: SSH_FXP_CLOSE, Size: 10, Number: 3588
> 2010-02-24 16:20:46.064 04,00,00,0E,04,00,00,00,01,31,
. 2010-02-24 16:20:46.079 Session upkeep
. 2010-02-24 16:20:46.079 Looking for network events
. 2010-02-24 16:20:46.079 Detected network event
. 2010-02-24 16:20:46.079 Enumerating network events for socket 820
. 2010-02-24 16:20:46.079 Enumerated 1 network events making 1 cumulative events for socket 820
. 2010-02-24 16:20:46.079 Handling network read event on socket 820 with error 0
. 2010-02-24 16:20:46.079 Received 25 bytes (0)
. 2010-02-24 16:20:46.470 Session upkeep
. 2010-02-24 16:20:46.470 Looking for network events
. 2010-02-24 16:20:46.470 Timeout waiting for network events
. 2010-02-24 16:20:46.970 Session upkeep
. 2010-02-24 16:20:46.970 Looking for network events
. 2010-02-24 16:20:46.970 Timeout waiting for network events
. 2010-02-24 16:20:47.470 Session upkeep
. 2010-02-24 16:20:47.470 Looking for network events
. 2010-02-24 16:20:47.470 Timeout waiting for network events
. 2010-02-24 16:20:47.970 Session upkeep
. 2010-02-24 16:20:47.970 Looking for network events
. 2010-02-24 16:20:47.970 Timeout waiting for network events
. 2010-02-24 16:20:48.470 Session upkeep
. 2010-02-24 16:20:48.470 Looking for network events
. 2010-02-24 16:20:48.470 Timeout waiting for network events
. 2010-02-24 16:20:48.970 Session upkeep
. 2010-02-24 16:20:48.970 Looking for network events
. 2010-02-24 16:20:48.970 Timeout waiting for network events
. 2010-02-24 16:20:49.470 Session upkeep
. 2010-02-24 16:20:49.470 Looking for network events
. 2010-02-24 16:20:49.470 Timeout waiting for network events
. 2010-02-24 16:20:49.970 Session upkeep
. 2010-02-24 16:20:49.970 Looking for network events
. 2010-02-24 16:20:49.970 Timeout waiting for network events
. 2010-02-24 16:20:50.001 File: "/LIFE/1_flanker-1000136-1.txt"
. 2010-02-24 16:20:50.001 Copying "/LIFE/1_flanker-1000136-1.txt" to local directory started.
. 2010-02-24 16:20:50.001 Ascii transfer mode selected.
. 2010-02-24 16:20:50.001 Opening remote file.
> 2010-02-24 16:20:50.001 Type: SSH_FXP_OPEN, Size: 46, Number: 3843
> 2010-02-24 16:20:50.001 03,00,00,0F,03,00,00,00,1D,2F,4C,49,46,45,2F,31,5F,66,6C,61,6E,6B,65,72,2D,
> 2010-02-24 16:20:50.001 31,30,30,30,31,33,36,2D,31,2E,74,78,74,00,00,00,01,00,00,00,00,
. 2010-02-24 16:20:50.001 Sent 50 bytes
. 2010-02-24 16:20:50.001 There are 0 bytes remaining in the send buffer
. 2010-02-24 16:20:50.001 Looking for network events
. 2010-02-24 16:20:50.001 Timeout waiting for network events
. 2010-02-24 16:20:50.001 Read 4 bytes (21 pending)
. 2010-02-24 16:20:50.001 Read 21 bytes (0 pending)
< 2010-02-24 16:20:50.001 Type: SSH_FXP_STATUS, Size: 21, Number: 3588
< 2010-02-24 16:20:50.001 65,00,00,0E,04,00,00,00,00,00,00,00,02,4F,6B,00,00,00,02,65,6E,
. 2010-02-24 16:20:50.001 Discarding reserved response
. 2010-02-24 16:20:50.001 Waiting for another 4 bytes
. 2010-02-24 16:20:50.001 Looking for incoming data
Thanks for your post. This issue is being tracked already.
