Topic "random_active >= 0"
Max
Assertion failed: random_active >= 0, file putty\SSHRAND.C, line 242
WinSCP was loaded, then Windows 7 was sleep, and after wake up we have this error.
martinml
This just happened to me when closing WinSCP 4.2.6 (I updated yesterday). I was conected to a FTP server, clicked the close button, and this message appeared, followed by "Abnormal program termination". Everything was working fine with last version (4.2.5?). I am using Windows XP.
dandvd
I got the same error on Windows XP SP3. Here is what I did:
1. Edit a remote file
2. Put the laptop on standby (network connection lost)
3. Resume from standby
Today I am getting the same error - worked yesterday with win7 connecting to minimal ubuntu karmic
Klxxx
HI, I have the same problem, i have installed openSSH and SBsettings, everything works fine but when i go to my computer and i open WinSCP with the logs i have 'Assertion failed: random_active >= 0, file putty\SSHRAND.C, line 242' too
What can we do ?
Thx
djc1309
I ran into the same problem running WinSCP 4.2.6 on an XP SP3 machine. I created a batch file that runs WinSCP using a script.
My PC went to sleep and when I came back and tried to run the batch file again, I got this error. My script looks like this:
option batch abort
option transfer binary
open [ftp site]
cd ReceiveFiles
synchronize local .\files ./
bye
I need to add that the FTP server I was trying to access had been pulled down for maintenance at some point while I was away from the computer. However, WinSCP was not open in GUI mode during the time that I was away.
I believe I have fixed the problem. I'm going to send testing version to those on this thread that registered before posting.
fatim
Same problem, usualy happens when closing application but also if network is unavailable.
mdmower
I'm interested in this testing version as well. I can always reproduce the error on my end, so it will be easy to test whether the issue is resolved.
Jorozz
WOuld oyu be able to send me that version as well, only used winscp tp transfer apps to my iphone. dont wants to use otheres as this is much easier. cheers
dandvd
Development build appears to have fixed the problem. I have resumed from standby and WinSCP has transparently re-established the connection. Will continue using this version to test.
This bug has been added to tracker.
ericjs
The bug tracker description is "Failure when closing application after failed connection". I've gotten this error without closing or attempting to close the application (and from the comments in this topic, so have others).
Also, I first attempted to find this issue in your bug tracker before I came here to report it. It did not come up because you do not have any of the text from the error message (Assertion failed: random_active >= 0, etc) in it.
dandvd
Full support for ericjs's post - I get the error without closing WinSCP, and the bug should include the error text.
sridhar721
I am still getting this error. did you fix it or can I use older version?
tobisnet
I have this error too !
Can I get the update also ?
Regards,
tobisnet
Fix will be included into 4.2.7, coming out this week. You can downgrade to 4.2.5.
