Topic "Version 4.2.6 (721) / Connection lost on moving file"
Just installed new version. Tried to copy/move a file (34 MB) from aix server to my local pc with ssh. With new version i got a message that the session was broken from source. Same file with version 4.1.9 no problem.
One thing i mentioned: after installing new version the installer told me to reboot my pc. Older version said nothing.
Please post a full log file showing the problem (both from 4.2.6 and 4.1.9).
