Topic "Log Connection Problem when using Automated Scripting."
jata
Hi
I am using Automated Scripts to using 'OPEN' command to connect to an SFTP Server. I turned off the SFTP Server to make sure that I dont connect to trap the connection Error. Who can I have the connection error be written to the XML Log file that I turned on.
JV
Do you mean that the connection failure does not get recorded in XML log?
jata
Yep.... When the connection is not established for whatever reason I dont see any indication in the XML Log File. Appreciate all your help.
JV
