Topic "Regarding winscp backward compatibility!"
gopikrishnakomanduri
I have used winscp382.exe for my project . My intention is to automate even security prompt for the user , when using winscp for the first time. I am copy pasting the script file , which I have used to transfer . Can I use the same script file for automation , even for later versions of winscp ? with my current script , can I say as I have generalized the winscp version , and can I say as user can choose any version of winscp and using my script , I can transfer like? Please let me know if I am not clear.
script I am using is,
option batch continue
option confirm on
open paraccel:paraccel@10.233.13.43
cd /home/paraccel
mkdir infa
cd infa
option transfer binary
put .\author2010-02-2218_19_38.228881.txt_1
close
and launching winscp as
.\\winscp382.exe /script=.\\script.scr /log=.\\winscplog.txt"
You can use the same script with later versions of WinSCP.
Thanks. But When I used the same script from winscp382.exe , it worked perfectly . But when tried with winscp4.2.6 (latest version) , it is not working . in winscp log file , I could see some logs like
. 2010-02-19 10:03:51.687 --------------------------------------------------------------------------
. 2010-02-19 10:03:51.687 WinSCP Version 4.2.6 (Build 721) (OS 5.2.3790 Service Pack 2)
. 2010-02-19 10:03:51.687 Login time: Friday, February 19, 2010 10:03:51 AM
. 2010-02-19 10:03:51.687 Session name: paraccel@192.168.159.102
. 2010-02-19 10:03:51.687 Host name: 192.168.159.102 (Port: 22)
. 2010-02-19 10:03:51.687 User name: paraccel (Password: Yes, Key file: No)
. 2010-02-19 10:03:51.687 Tunnel: No
. 2010-02-19 10:03:51.687 Transfer Protocol: SFTP (SCP)
. 2010-02-19 10:03:51.687 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-19 10:03:51.687 Proxy: none
. 2010-02-19 10:03:51.687 SSH protocol version: 2; Compression: No
. 2010-02-19 10:03:51.687 Bypass authentication: No
. 2010-02-19 10:03:51.687 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-02-19 10:03:51.687 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-02-19 10:03:51.687 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-02-19 10:03:51.687 SFTP Bugs: -,-
. 2010-02-19 10:03:51.687 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-02-19 10:03:51.687 Shell: default, EOL: 0
. 2010-02-19 10:03:51.687 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-02-19 10:03:51.687 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-02-19 10:03:51.687 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-02-19 10:03:51.687 Cache directory changes: Yes, Permanent: Yes
. 2010-02-19 10:03:51.687 DST mode: 1
. 2010-02-19 10:03:51.687 Looking up host "192.168.159.102"
. 2010-02-19 10:03:51.687 Connecting to 192.168.159.102 port 22
. 2010-02-19 10:03:51.718 Server version: SSH-1.99-OpenSSH_3.9p1
. 2010-02-19 10:03:51.718 Using SSH protocol version 2
. 2010-02-19 10:03:51.718 We claim version: SSH-2.0-WinSCP_release_4.2.6
. 2010-02-19 10:03:51.734 Doing Diffie-Hellman group exchange
. 2010-02-19 10:03:51.796 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-02-19 10:03:51.937 Asking user:
. 2010-02-19 10:03:51.937 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2010-02-19 10:03:51.937 The server's rsa2 key fingerprint is:
. 2010-02-19 10:03:51.937 ssh-rsa 1024 6d:f6:59:c7:42:e4:3d:51:00:56:13:48:40:c9:66:e8
. 2010-02-19 10:03:51.937 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. 2010-02-19 10:03:51.937 Continue connecting and add host key to the cache? ()
. 2010-02-19 10:03:51.937 Attempt to close connection due to fatal exception:
* 2010-02-19 10:03:51.937 Host key wasn't verified!
. 2010-02-19 10:03:51.937 Closing connection.
. 2010-02-19 10:03:51.937 Sending special code: 12
May I know is this the bug in winscp4.2.6 or am I doing any thing wrong? Please correct me if I am wromg .
Thx,
--Gopi
I suppose you are running 4.2.6 on different machine than the old version. Or you run it under different user or with different configuration (INI file).
