Topic "error directory"
centoasa
I use winscp from my usb key, when I try to connect via ftp to my website: error directory listing "/"
Always
. 2010-02-24 21:54:29.678 --------------------------------------------------------------------------
. 2010-02-24 21:54:29.678 WinSCP Version 4.2.6 (Build 721) (OS 6.1.7600)
. 2010-02-24 21:54:29.678 Login time: mercoled 24 febbraio 2010 21:54:29
. 2010-02-24 21:54:29.678 Session name: centoasa@ftp.100asa.it
. 2010-02-24 21:54:29.678 Host name: ftp.100asa.it (Port: 21)
. 2010-02-24 21:54:29.694 User name: centoasa (Password: Yes, Key file: No)
. 2010-02-24 21:54:29.694 Tunnel: No
. 2010-02-24 21:54:29.694 Transfer Protocol: FTP
. 2010-02-24 21:54:29.694 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-24 21:54:29.694 Proxy: none
. 2010-02-24 21:54:29.694 FTP: FTPS: None; Passive: No [Force IP: No]
. 2010-02-24 21:54:29.694 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-02-24 21:54:29.694 Cache directory changes: Yes, Permanent: Yes
. 2010-02-24 21:54:29.694 DST mode: 1
. 2010-02-24 21:54:29.694 --------------------------------------------------------------------------
. 2010-02-24 21:54:29.772 Connecting to ftp.100asa.it ...
. 2010-02-24 21:54:29.913 Connected with ftp.100asa.it. Waiting for welcome message...
< 2010-02-24 21:54:30.085 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 2010-02-24 21:54:30.085 220-You are user number 4 of 50 allowed.
< 2010-02-24 21:54:30.085 220-Local time is now 14:54. Server port: 21.
< 2010-02-24 21:54:30.085 220 You will be disconnected after 15 minutes of inactivity.
> 2010-02-24 21:54:30.085 USER centoasa
< 2010-02-24 21:54:30.272 331 User centoasa OK. Password required
> 2010-02-24 21:54:30.272 PASS **********
< 2010-02-24 21:54:30.506 230-User centoasa has group access to: centoasa
< 2010-02-24 21:54:30.506 230 OK. Current restricted directory is /
> 2010-02-24 21:54:30.506 SYST
< 2010-02-24 21:54:30.694 215 UNIX Type: L8
> 2010-02-24 21:54:30.694 FEAT
< 2010-02-24 21:54:30.881 211-Extensions supported:
< 2010-02-24 21:54:30.881 EPRT
< 2010-02-24 21:54:30.881 IDLE
< 2010-02-24 21:54:30.881 MDTM
< 2010-02-24 21:54:30.881 SIZE
< 2010-02-24 21:54:30.881 REST STREAM
< 2010-02-24 21:54:30.881 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
< 2010-02-24 21:54:30.881 MLSD
< 2010-02-24 21:54:30.881 AUTH TLS
< 2010-02-24 21:54:30.881 PBSZ
< 2010-02-24 21:54:30.881 PROT
< 2010-02-24 21:54:30.881 ESTA
< 2010-02-24 21:54:30.881 PASV
< 2010-02-24 21:54:30.881 EPSV
< 2010-02-24 21:54:30.881 SPSV
< 2010-02-24 21:54:30.881 ESTP
< 2010-02-24 21:54:30.881 211 End.
. 2010-02-24 21:54:30.881 Connected
. 2010-02-24 21:54:30.881 --------------------------------------------------------------------------
. 2010-02-24 21:54:30.881 Using FTP protocol.
. 2010-02-24 21:54:30.897 Doing startup conversation with host.
> 2010-02-24 21:54:30.897 PWD
< 2010-02-24 21:54:31.085 257 "/" is your current location
. 2010-02-24 21:54:31.100 Getting current directory name.
. 2010-02-24 21:54:31.100 Retrieving directory listing...
> 2010-02-24 21:54:31.100 TYPE A
< 2010-02-24 21:54:31.288 200 TYPE is now ASCII
> 2010-02-24 21:54:31.288 PORT 192,168,1,14,199,39
< 2010-02-24 21:54:31.475 200 PORT command successful
> 2010-02-24 21:54:31.475 LIST -a
. 2010-02-24 21:54:46.694 Timeout detected.
. 2010-02-24 21:54:46.694 Could not retrieve directory listing
* 2010-02-24 21:54:46.694 (ESshFatal) Lost connection.
* 2010-02-24 21:54:46.694 Timeout detected.
* 2010-02-24 21:54:46.694 Could not retrieve directory listing
* 2010-02-24 21:54:46.694 PORT command successful
* 2010-02-24 21:54:46.694 Error listing directory '/'.
