Topic "Upgrading core to 4.2.x"
przemoc
Hi Martin,
Are you planning to upgrade core of the WinSCP Far Manager plugin to match current WinSCP's one?
There was a bunch of bug fixes and improvements (especially notable is introducing long awaited FTPS), so IMHO even from security PoV it deserves to be updated.
Bringing Far 2.0 fully compatible version (unicode, etc.) would be nice, but it's a secondary thing. So if you have some spare time, then upgrading core is much more important than upgrading Far scaffolding, which, I believe, will be done eventually anyway.
Regards.
I'll do it sooner or later. But I have fixed date set yet.
przemoc wrote:
Hi Martin,
I can only second this. This plugin is one of the most important for me personally and I am glad such exists. I am looking forward to seeing an update... as you have time.
dmitriy
I will also ask and appreciate to update with last core and bugfixes.
petr.pavel
Hi Martin,
I would also like to add a notch to this voting thread. I would like to see FTPS support in the FAR plugin.
Thanks a bunch for your time and WinSCP.
Petr
Life is what you make it.
MortenMacFly
Hi Martin,
I recently switched to Far 2.0 (as it has become stable). I would therefore also "vote" for an update...
Version 1.6.2 seems to work though, but I am a bit worried about security updates in the WinSCP core.
Any chance to get an update due to the security bug that affects PuTTY 0.6.1? BTW: Meanwhile, Far 3.0 starts to be official. An update for Far 2.0 would really be nice (not pushing anything though...).
No news yet, sorry. Bugs in PuTTY 0.61 do not affect FAR plugin.
aguest
Well, there is actually a new plugin for Far 2, which is based on latest WinSCP supporting all protocols + WebDAV + unicode + x64.
http://forum.farmanager.com/viewtopic.php?p=88014#p88014
