Topic "WinSCP and Code::Blocks - multiple instances issue"
I have WinSCP Version 4.1.6 (Build 412) running on Windows Vista (Home edition).
I use CodeBlocks Version 8.02 on windows for editing my remote C,C++ files.
In Codeblocks, I enabled the the Environment->Settings to "Allow only one running instance" and restarted Codeblocks.
In WinSCP, under Editor preferences, for *.c, *.cc files I enabled the option "External editor opens multiple files in one window (process)".
When I edit the first C file, codeblocks opens it correctly. However, the second edit fails with the message "Another program instance is already running. code::blocks is currently configured to allow only one running instance"
With previous versions of Code::Blocks and WinSCP on this same windows Vista machine, I have been able to open multiple files in the same instance of Code::Blocks.
Now something has changed, either on the WinSCP configuration side or Codeblock side and I am unable to open multiple files in one Code::Blocks instance - I can ofcourse open each file in separace Code::Blocks instance - but I'd like to avoid this.
Any tips on how to overcome this problem is appreciated.
I do not think this has anything to do with WinSCP. There was no change in a way how to launches the external editors.
