Topic "Size wildcard in scripts"
crishog
I'm trying to download a series of .tgz files overnight & I have a working script
One or two are very large & sometimes fail. Not really a big problem, but what I'd like to do is download the many small ones & then attempt the bigger files - at least if it fails I've only a couple to deal with.
I've tried using a mask on the get
get *.tgz<100M
to get then smaller files, but this simply does nothing at all
Am I misunderstanding this mask or does it not work with a script?
Thanks for your post. This issue is being tracked already.
Meanwhile this should work:
option exclude >100M
get *.tgz
crishog
get *.tgz
I'm relatively new to using WinSCP, so I should have checked the issues first, my apologies.
Thanks for the alternative, much appreciated.
Chris
