Topic "ask password, trying to reconnec and ask password again"
Max
WinSCP 4.2.7
Steps:
1. connect to server over SCP (password do not saved)
2. do not touch it some long time
WinSCP ask enter passsword again
3. enter password
WinSCP show:
'Server close connection:
Using username "*".
Authentication failed.'
4. press Reconnect
it try reconnect and ask password again...
Can you do not ask password if WinSCP lost connection, or remember password from step 3?
thank you.
