issue with winscp when running under windows xp task
errouji15
hello,
I'm using winscp 4.2.7(build 758) (portable version), and I've a windows shudeled task which execute a batch file with the command bellow at 5:00AM each day:
C:\WinSCPPortable\WinSCPPortable.exe merprod /synchronize E:\EXPORTS\others_va\aba /home/mer/conts /defaults
the issu is that winscp seems doesn't work even if I can see his process in task manager in the morning when I check the result, winscp stay runing all the night without doing anything. Nothing also in the winscp logfile.
could you send me the debug version to trace this issue please?
Regards
errouji15
Re: issue with winscp when running under windows xp task
errouji15 wrote:
hello,
Regards
I've found the root issue, winscp doesn't work properly when there are not an active session in windows, is it a bug ?
You obviously cannot run it in GUI mode without active session. But you can use scripting mode.
errouji15
yes I've used winscp.com wich works perfectly.
Anyway I thnik that it will be nice if we czn use the gui version as scripting one.
Why?
errouji15
because the sentence bellow worked perfectly before
It is more logic to have one tool which work for both: gui and command line.
You have one tool.
