Topic "Can't login to any domain"
tyankee
i've had this problem for about a year but put it aside since i can login fine with ws_ftp.. but i'd like to get it fixed now if i can.. i just updated to the latest release and still have the problem when trying to log into any of my servers.
Here is the error i get..
Timeout detected.
PORT command successful
Error listing directory '/'.
Can you post a log file from WinSCP and WS_FTP?
Also see this FAQ.
tyankee
i checked the firewalls on my system and they both allow winscp.. here is the winscp log file:
. 2010-03-19 13:14:11.718 --------------------------------------------------------------------------
. 2010-03-19 13:14:11.718 WinSCP Version 4.2.7 (Build 758) (OS 5.1.2600 Service Pack 3)
. 2010-03-19 13:14:11.718 Login time: Friday, March 19, 2010 1:14:11 PM
. 2010-03-19 13:14:11.718 Session name: mustangt@mustangtraderonline.com
. 2010-03-19 13:14:11.718 Host name: mustangtraderonline.com (Port: 21)
. 2010-03-19 13:14:11.718 User name: mustangt (Password: No, Key file: No)
. 2010-03-19 13:14:11.718 Tunnel: No
. 2010-03-19 13:14:11.718 Transfer Protocol: FTP
. 2010-03-19 13:14:11.718 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-03-19 13:14:11.718 Proxy: none
. 2010-03-19 13:14:11.718 FTP: FTPS: None; Passive: No [Force IP: No]
. 2010-03-19 13:14:11.718 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-03-19 13:14:11.718 Cache directory changes: Yes, Permanent: Yes
. 2010-03-19 13:14:11.718 DST mode: 1
. 2010-03-19 13:14:11.718 Password prompt (no password provided or last login attempt failed)
. 2010-03-19 13:14:19.421 Connecting to mustangtraderonline.com ...
. 2010-03-19 13:14:19.436 Connected with mustangtraderonline.com. Waiting for welcome message...
< 2010-03-19 13:14:19.577 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 2010-03-19 13:14:19.577 220-You are user number 4 of 50 allowed.
< 2010-03-19 13:14:19.577 220-Local time is now 13:14. Server port: 21.
< 2010-03-19 13:14:19.577 220 You will be disconnected after 15 minutes of inactivity.
> 2010-03-19 13:14:19.577 USER mustangt
< 2010-03-19 13:14:19.655 331 User mustangt OK. Password required
> 2010-03-19 13:14:19.702 PASS ********
< 2010-03-19 13:14:19.796 230-User mustangt has group access to: mustangt
< 2010-03-19 13:14:19.796 230 OK. Current restricted directory is /
> 2010-03-19 13:14:19.796 SYST
< 2010-03-19 13:14:19.874 215 UNIX Type: L8
> 2010-03-19 13:14:19.874 FEAT
< 2010-03-19 13:14:19.952 211-Extensions supported:
< 2010-03-19 13:14:20.014 EPRT
< 2010-03-19 13:14:20.014 IDLE
< 2010-03-19 13:14:20.014 MDTM
< 2010-03-19 13:14:20.014 SIZE
< 2010-03-19 13:14:20.014 REST STREAM
< 2010-03-19 13:14:20.014 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
< 2010-03-19 13:14:20.014 MLSD
< 2010-03-19 13:14:20.014 AUTH TLS
< 2010-03-19 13:14:20.014 PBSZ
< 2010-03-19 13:14:20.014 PROT
< 2010-03-19 13:14:20.014 ESTA
< 2010-03-19 13:14:20.014 PASV
< 2010-03-19 13:14:20.014 EPSV
< 2010-03-19 13:14:20.014 SPSV
< 2010-03-19 13:14:20.014 ESTP
< 2010-03-19 13:14:20.014 211 End.
. 2010-03-19 13:14:20.030 Connected
. 2010-03-19 13:14:20.030 --------------------------------------------------------------------------
. 2010-03-19 13:14:20.030 Using FTP protocol.
. 2010-03-19 13:14:20.030 Doing startup conversation with host.
> 2010-03-19 13:14:20.030 PWD
< 2010-03-19 13:14:20.093 257 "/" is your current location
. 2010-03-19 13:14:20.108 Getting current directory name.
. 2010-03-19 13:14:20.108 Retrieving directory listing...
> 2010-03-19 13:14:20.108 TYPE A
< 2010-03-19 13:14:20.186 200 TYPE is now ASCII
> 2010-03-19 13:14:20.186 PORT 192,168,2,3,15,232
< 2010-03-19 13:14:20.264 200 PORT command successful
> 2010-03-19 13:14:20.671 LIST -a
. 2010-03-19 13:14:35.718 Timeout detected.
. 2010-03-19 13:14:35.749 Could not retrieve directory listing
* 2010-03-19 13:14:35.749 (ESshFatal) Lost connection.
* 2010-03-19 13:14:35.764 Timeout detected.
* 2010-03-19 13:14:35.764 Could not retrieve directory listing
* 2010-03-19 13:14:35.764 PORT command successful
* 2010-03-19 13:14:35.764 Error listing directory '/'.
tyankee
here is the ws_ftp log file for the same domain...
Connecting to 74.52.155.66:21
Connected to 74.52.155.66:21 in 0.000000 seconds, Waiting for Server Response
220-Local time is now 13:25. Server port: 21.
Host type (1): Automatic detect
USER mustangt
PASS (hidden)
SYST
215 UNIX Type: L8
Host type (2): UNIX (standard)
PWD
CWD /www
250 OK. Current directory is /www
PWD
257 "/www" is your current location
TYPE A
PASV
227 Entering Passive Mode (74,52,155,66,155,74)
connecting data channel to 74.52.155.66:155,74(39754)
data channel connected to 74.52.155.66:155,74(39754)
LIST
150 Accepted data connection
transferred 35038 bytes in 0.531 seconds, 515.265 Kbps ( 64.408 KBps), transfer succeeded.
226-Options: -a -l
226 452 matches total
QUIT
221-Goodbye. You uploaded 0 and downloaded 0 kbytes.
221 Logout.
Connection closed. Ready for next connection.
You use passive mode with WS_FTP, while active with WinSCP. Please read documentation. If that does not help, come back.
tyankee
WOW - THANK YOU.. it works now... and to think i was struggling with that for over a year.. i still can't understand how my settings changed though as it worked fine up until last year..
