Topic "Cannot create ini file"
TelltoK
When I execute winscp script, I am getting "Cannot create ini file - C:\program files\winscp\winscp.ini"
Please help me to resolve the problem.
prikryl
ashokmu
Same erro occuring for me too...
"cannot create file C:\program files\winscp\winscp.ini"
this error , occuring for me too..
prikryl
Are you sure you have write permissions to the directory?
ashokmu
I ran the script through WINSCP.exe and the error "cannot create file C:\program files\winscp\winscp.ini" is displayed, then i given the permission to the directory. but Now the same error occuring in "Winscp.com" while executing the script, below mentioned the two scripts running in different winscp
Script executing in winscp.exe:
open test
option transfer binary
mv /outgoing/BDF/*.zip /outgoing/BDF/TEMP/
get /Outgoing/BDF/TEMP/*.ZIP D:\apps\Incoming\FTP\
rm /Outgoing/BDF/TEMP/*.*
close
Script executing in winscp.com:
option batch abort
open test
option transfer bin
option batch on
put "D:\apps\incoming\FTP\ACK\WORK\*.*" /Incoming/Recon/
# Disconnect
close
now the error occuring in winscp.com.
"cannot create file C:\program files\winscp\winscp.ini" error
can u please provide the solution for the above mentioned error.
prikryl
Are you running both winscp.exe and winscp.com on the same machine and under the same account?
ashokmu
Yes..
I am using same machine to run both the script and same account as well.
As i created two seperate "BAT" file and executed through two seperate scheduled task in "Control panel".
And the log file details contains ,
recorded by system personnel.---WARNINGFurther authentication required
. 2010-08-16 01:15:21.399 Further authentication required
. 2010-08-16 01:15:21.399 Session password prompt (combined@sftp.divintech.com's password: )
. 2010-08-16 01:15:21.399 Using stored password.
. 2010-08-16 01:15:21.399 Sent password
. 2010-08-16 01:15:21.431 Access granted
. 2010-08-16 01:15:21.478 Opened channel for session
. 2010-08-16 01:15:21.509 Started a shell/command
. 2010-08-16 01:15:21.509 --------------------------------------------------------------------------
. 2010-08-16 01:15:21.509 Using SFTP protocol.
. 2010-08-16 01:15:21.524 Doing startup conversation with host.
> 2010-08-16 01:15:21.524 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-08-16 01:15:21.556 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-08-16 01:15:21.556 SFTP version 3 negotiated.
. 2010-08-16 01:15:21.556 We believe the server has signed timestamps bug
. 2010-08-16 01:15:21.556 We will use UTF-8 strings for status messages only
. 2010-08-16 01:15:21.556 Getting current directory name.
. 2010-08-16 01:15:21.556 Getting real path for '.'
> 2010-08-16 01:15:21.556 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-08-16 01:15:21.603 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2010-08-16 01:15:21.603 Real path is '/'
. 2010-08-16 01:15:21.603 Startup conversation with host finished.
. 2010-08-16 01:15:21.634 Copying 0 files/directories to remote directory "/Incoming/Recon/"
. 2010-08-16 01:15:21.634 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-08-16 01:15:21.634 TM: B; ClAr: No; ExclM(No):
. 2010-08-16 01:15:21.634 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-08-16 01:15:21.634 Closing connection.
prikryl
I'm sorry, I do not know how to help you.
ashokmu
hi,
can u please check the log file attached here...
Actually the Erro occurs in the line "put "D:\apps\incoming\FTP\ACK\WORK\*.*" /Incoming/Recon/"..
please help using these details
