Topic "Help::Move Latest(Todays) .dat File between folders on SFTP."
Vk
Hi EveryOne,
I am a SSIS Developer. I am creating a package which connects to a SFTP Server, for that I am using WINSCP with Stored Session, and accomplishes the below 2 Tasks.
1. get the latest.dat file (i.e. Todays date) from Home/XXX/latest.dat (SFTP Server) to my local directory D:\XXX\latest.dat and
2. I have to rename the file from latest.dat to latest.log and move the file to a Home/XXX/log/ folder on the remote server (i.e SFTP Server).
can somebody please help me with this.
Vk
Hi prikryl
Thanks for your reply. Actually I am able to create a batch file with date and time stamp using a script task in my SSIS Package. And In that batch File my commands are::
CD PPP
get ABC_20100331.dat
mv ABC_20100331.dat ABC_20100330.ack /XXX/Ack/
(Rename file by changing extension and move to ACK folder)
mv ABC_20100331.dat /XXX/Processed/
mv ABC_20100331.dat ABC_20100330.log /XXX/Log/
(Rename file by changing extension and move to LOG folder)
I tried till get command, Its working fine. I am able to bring the file which I wanted. The only thing is the next 3 steps. I jus wanna make sure that the 3 move commands as said above will work fine while moving the files between folders after renaming them. I cant check them because the SFTP server is the Production server. Please confirm me that these 3 move comands are correct or not? If not please suggest me some Ideas on this.
Thanks In Advance
Possibly you wanted to do:
mv ABC_20100331.dat /XXX/Ack/ABC_20100330.ack
Also you cannot move the same file again, as it is not there anymore.
Vk
Hi prikryl
Thanks for your valuable suggestion. I was waiting for your reply. that really helped me. One final question prikryl. Since you told that I cannot use the same file agian in my further steps, Can I use a Copy command to do my required Task?
I mean can I use these following steps shown below::
cp ABC_20100331.dat ABC_20100330.ack
mv ABC_20100330.ack /XXX/Ack/ABC_20100330.ack
cp ABC_20100331.dat ABC_20100330.log
mv ABC_20100330.log /XXX/log/ABC_20100330.log
mv ABC_20100331.dat /XXX/Processed/ABC_20100330.dat
If not can you please suggest me another alternative approach for my task.
Thanks in Advance.
You cannot duplicate remote file from script. All you can do is to download it and upload back to a different path.
