Topic "File must be specified by library/file.member ???"
When trying to send a file to my FTP server I get the following. I have no issues downloading a file from the server, only when i'm sending. Any suggestions would be greatly appreciated. Please let me know if there is more information you might need.
Error Occured: Sending file to FMS.
winscp> option batch abort
batch abort
winscp> option confirm off
confirm off
winscp> open ftp://USer:Password@ftpServer
Connecting to ftpServer ...
Connected with ftpServer. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] User@ftpServer
winscp> lcd C:\Test
C:\Test
winscp> cd OUT
OUT
winscp> put C:\Test\Test.txt
C:\Test\Test.txt | 0 KiB | 0.0 KiB/s | binary | 0%
Error transferring file 'C:\Test\Test.txt'.
File must be specified by library/file.member.
Is it VMS?
I'm kind of new to this, can you please explain what VMS is?
prikryl wrote:
Is it VMS?
Being that I pretty much have no idea what VMS is, I'm going to go out on a limb and say no.
I'm using Windows XP, and I am trying to send to an IBM AS/400 server. Does this answer the question?
LCross
prikryl wrote:
Is it VMS?
Let me also add that I get this error message as well when I use the "ls" command. It almost seems like some type of configuration issue, but i have uninstalled and reinstalled the software with no success. Also after reading further on the subject of VMS, i do not believe that the server is VMS.
I'm afraid WinSCP cannot deal with IBM AS/400 (nor with VMS).
This issue is being tracked already.
I am using this on iSeries and it works on some of the systems but not all of them.
I am checking to see if this has an update to correct.
Please attach a full log file both from a system where WinSCP works and where it does not? (using the latest version of WinSCP).
Just for info about "File must be specified by library/file.member"
and "I am using this on iSeries and it works on some of the systems but not all of them."
The FTP server on IBMi (successor of model AS/400, but everyone uses the old name) has lots of attributes.
One of them sets the FTP default target: from/into the DB2 database library system, or from/into the Unix file system on the machine.
The error message indicates that DB2 is set, but a Unix path is set in WinSCP.
Check and change this with command CHGFTPA +F4 to prompt the settings. Switch all parameters on using F9. Display the parameter names with F11. Page down to NAMEFMT and CURDIR.
Cursorposition plus F1 explains allways everything.
"NAMEFMT = *PATH" sends all incoming FTP connections at startup into IBMi's Unix server.
"CURDIR = *HOMEDIR" means: use user's home directory from his user profile. To check it, use "DSPUSRPRF username", and page down to the very end. You'll see e.g. /home. Use CHGUSRPRF to change it.
If you log in from WinSCP now, you will be in /home, and the error message above will not show up.
Of course, like on any Unix based system, there is a fancy-mousy-clicky surface for all of this, as software or for browser. But command line is faster.
Thanks for sharing the instructions.
Hello, a way to solve this temporarily is to execute the command SITE NAMEFMT 1 and that will shift the remote iSeries into the expected naming mode.
This is documented here:
https://winscp.net/eng/docs/ui_login_ftp#post_login
